千找万找终于找到了一个USB转串口的小工具~~~~
安卓的限制实在太多了,查询了小半天的armbian系统,觉得应该也是极好的。晚上吃饱后,找到了串口工具,参考芯灵思给的镜像直接烧录armbian系统。
Password: You are required to change your password immediately (root enforced) Changing password for root. (current) UNIX password: Enter new UNIX password: Retype new UNIX password: Linux sinlinx 4.14.53-sunxi #30 SMP Sat Jul 7 00:07:52 PDT 2018 armv7l ____ ___ _ _ _ ___ _ ___ __ ____ ___ _ _ _ _ _____ / ___|_ _| \ | | | |_ _| \ | \ \/ / / ___|_ _| \ | | | | | |___ / \___ \| || \| | | | || \| |\ / \___ \| || \| |_____| |_| | |_ \ ___) | || |\ | |___ | || |\ |/ \ ___) | || |\ |_____| _ |___) | |____/___|_| \_|_____|___|_| \_/_/\_\ |____/___|_| \_| |_| |_|____/ Welcome to ARMBIAN 5.46 user-built Debian GNU/Linux 8 (jessie) 4.14.53-sunxi System load: 1.39 0.85 0.37 Up time: 3 min Memory usage: 5 % of 1000MB IP: CPU temp: 35°C Usage of /: 7% of 15G New to Armbian? Check the documentation first: https://docs.armbian.com Thank you for choosing Armbian! Support: www.armbian.com Creating a new user account. Press <Ctrl-C> to abort Please provide a username (eg. your forename): jobs Trying to add user jobs Adding user `jobs' ... Adding new group `jobs' (1000) ... Adding new user `jobs' (1000) with group `jobs' ... Creating home directory `/home/jobs' ... Copying files from `/etc/skel' ... Enter new UNIX password: Retype new UNIX password: passwd: password updated successfully Changing the user information for jobs Enter the new value, or press ENTER for the default Full Name []: jobs zheng Room Number []: 906 Work Phone []: 01088886666 Home Phone []: 01088668866 Other []: Is the information correct? [Y/n] y Dear jobs zheng, your account jobs has been created and is sudo enabled. Please use this account for your daily work from now on. root@sinlinx:~#
烧录过程还是非常简单的——主要按照官方的参考手册执行。
接下来,将TF卡的镜像烧录进入eMMC,之后就可以轻松畅游Armbian了
