电子产品世界 » 论坛首页 » 嵌入式开发 » MCU » 求教:编译blob的问题
求教:编译blob的问题
2004-09-16 05:24:04     打赏
重新编译blob出错:
main.c:374:15: missing terminating " character main.c: In function `Go': main.c:376: error: syntax error at '@' token main.c:376: error: parse error before "drain" main.c:380: error: syntax error at '#' token main.c:382: error: syntax error at '#' token main.c:382: error: syntax error at '@' token main.c:383: error: syntax error at '@' token main.c:386: error: syntax error at '#' token main.c:389:9: missing terminating " character main.c:368: warning: unused variable `unused' make[3]: *** [main.o] Error 1 make[3]: Leaving directory `/usr/local/blob-xscale/src/blob' make[2]: *** [all] Error 2 make[2]: Leaving directory `/usr/local/blob-xscale/src/blob' make[1]: *** [all-recursive] Error 1 make[1]: Leaving directory `/usr/local/blob-xscale/src' make: *** [all-recursive] Error 1
相应代码如下:
//-------------------------------------------------- 373 strtou32(argv[1], (unsigned long*)(&go)); 374 __asm(" 375 376 @ drain pending loads and stores 377 mcr p15, 0, r0, c7, c10, 4 378 mrc p15,0,%1,c2,c0,0 379 mov %1,%1 380 sub pc,pc,#4 381 382 mov %1, #0x78 @turn everything off 383 mcr p15, 0, %1, c1, c0, 0 @(caches off, MMU off, etc.) 384 mrc p15,0,%1,c2,c0,0 385 mov %1,%1 386 sub pc,pc,#4 387 388 mov pc, %0 389 " 390 391 :"r"(go), "r"(unused) 392 ); 393 return 0;
求各位大侠看看错在哪里
[align=right][color=#000066][此贴子已经被作者于2004-9-17 23:59:07编辑过][/color][/align]
关键词: 求教     编译     问题     error
