我把uclinux-samsung-20020318.tar.gz下载于/home/,tar xzvf uclinux-samsung-20020318.tar.gz
编译器业已安装。arm-elf-tools-20030314.sh下载于/home/user/ 运行 sh ./arm-elf-tools-20030314.sh.
然后的操作是:#cd uclinux-samsung
#make menuconfig
这一步就出错:config/mkconfig > config.in make -C /home/uClinux-Samsung/config/scripts/lxdialog all make[1]: Entering directory `/home/uClinux-Samsung/config/scripts/lxdialog' /bin/sh: line 1: cc: command not found >> Unable to find the Ncurses libraries. >>>> You must have Ncurses installed in order >> to use 'make menuconfig' make[1]: *** [ncurses] Error 1 make[1]: Leaving directory `/home/uClinux-Samsung/config/scripts/lxdialog' make: *** [menuconfig] Error 2
不知是什么情况?我给rh9。03G的空间。
请教高手帮帮忙。
