废话不多说了,下面和大家分享一下扣丁学堂Java在线学习课程:LeetCode -- Path Sum III分析及实现方法,希望可以帮到对Java开发感兴趣的小伙伴们。
题目描述:
You are given a binary tree in which each node contains an integer value. Find the number of paths that sum to a given value. The path does not need to start or end at the root or a leaf, but it must go downwards (traveling only from parent nodes to child nodes). The tree has no more than 1,000 nodes and the values are in the range -1,000,000 to 1,000,000.
给定一个二叉树,遍历过程中收集所有可能路径的和,找出和等于X的路径树。
思路:
设当前节点为root,分别收集左右节点路径和的集合,merge到当前集合中;
将当前节点添加到数组中,构成新的可能路径。
实现代码:
* Definition for a binary tree node.
* public class TreeNode {
* public int val;
* public TreeNode left;
* public TreeNode right;
* public TreeNode(int x) { val = x; }
public class Solution {
private int _sum;
private int _count;
public int PathSum(TreeNode root, int sum)
_count = 0;
_sum = sum;
Travel(root, new List<int>());
return _count;
private void Travel(TreeNode current, List<int> ret){
if(current == null){
return ;
if(current.val == _sum){
_count ++;
var left = new List<int>();
Travel(current.left, left);
var right = new List<int>();
Travel(current.right, right);
ret.AddRange(left);
ret.AddRange(right);
for(var i = 0;i < ret.Count; i++){
ret[i] += current.val;
if(ret[i] == _sum){
_count ++;
ret.Add(current.val);
//Console.WriteLine(ret);
好了,以上就是小编给大家分享的Java在线学习课程:LeetCode -- Path Sum III分析及实现方法,想要学好Java开发的小伙伴一定要选择专业的Java培训机构,小编给大家推荐专业的Java培训机构扣丁学堂,扣丁学堂不仅有专业的老师和与时俱进的课程体系还有大量的Java在线教程供学员观看学习,心动的小伙伴快快行动吧。扣丁学堂java技术交流群:487098661。微信号:codingbb
