代老师的arm9板子上,我想编译boot_loader,已经按照代老师网站上的说明建立好交叉编译环境(arm-linux-gcc -v 命令可以正常执行),但是在arm9\lom-arm9\arm\LOM-ARM9-Boot\loader目录下执行make命令时遇到错误:
[root@localhost loader]# make /usr/local/arm/2.95.3/bin/arm-linux-gcc -Os -fno-builtin -fomit-frame-pointer -fno-strict-aliasing -fno-inline -fno-common -mshort-load-bytes -msoft-float -D__arm__ -D__FLASHED__ -I/home/taichi/arm9/lom-arm9/arm/LOM-ARM9 -Boot/loader/include -c entry.S arm-linux-gcc: installation problem, cannot exec `cpp0': No such file or directory make: *** [entry.o] Error 1
请代老师和诸位高手指教!
