现在的板子有两块声卡,一块是5640,一块是hdmi
所以发现直接发声有时候会发不出声音
这个默认声卡有配置文件可以设置么?希望能设置成5640,哪位大神指点一下?
Firstly use this to define sound cards
pactl list short sinks
You will get a list as;
module-alsa-card.c s16le 2ch 44100Hz SUSPENDED
1
alsa_output.usb-Blue_Microphones_Yeti_Stereo_Microphone_REV8-00.analog-stereo
2 alsa_output.usb-FiiO_DigiHug_USB_Audio-01.analog-stereo
3 alsa_output.pci-0000_00_1f.3.analog-stereo module-alsa-card.c s16le 2ch 48000Hz RUNNING
Then select you have to use hdmi and to set it use this command;
pactl set-default-sink 'alsa_output.pci-0000_00_1f.3.analog-stereo'
open /etc/pulse/default.pa and change the related lines as;
### Make some devices default
set-default-sink 3
set-default-source 3
Pls use index numbers and names as your output values.
| 2026年“我要开发板活动”第三季,开始了! | |
