在上一篇我们测试了基于Ctimer定时的PWM输出,相对来说功能还是比较少的,只能边沿对齐,这次我们使用SCtimer定时器,让PWM有更多可能!
从零配置SCtimer的PWM输出
创建组件:
定时器基础配置:
需要配置的内容不多,只要配置时钟就好;
通道配置:
可以看到配置你想要的若干通道,在这里遇到了两个问题,一个是配置SCTIMER out 0时连接到P1_4引脚无输出,连接到P2_2则输出正常;另一个就是上图的感叹号问题,要求PWM信号必须被分配到一个初始化的状态,可是并没有相关设置项,我们带着问题进行“更新源代码”,可以看到初始化内容("peripherals.C")中:
const sctimer_config_t SCT0_initConfig = {
  .enableCounterUnify = true,
  .clockMode = kSCTIMER_System_ClockMode,
  .clockSelect = kSCTIMER_Clock_On_Rise_Input_0,
  .enableBidirection_l = false,
  .enableBidirection_h = false,
  .prescale_l = 0U,
  .prescale_h = 0U,
  .outInitState = (uint8_t)(SCT0_OUTPUT_1 | SCT0_OUTPUT_3),
  .inputsync = 0U
const sctimer_pwm_signal_param_t SCT0_pwmSignalsConfig[2] = {
    .output = kSCTIMER_Out_0,
    .level = kSCTIMER_HighTrue,
    .dutyCyclePercent = 50U
    .output = kSCTIMER_Out_1,
    .level = kSCTIMER_LowTrue,
    .dutyCyclePercent = 20U
uint32_t SCT0_pwmEvent[2];
static void SCT0_init(void) {
  SCTIMER_Init(SCT0_PERIPHERAL, &SCT0_initConfig);
  /* Initialization of state 0 */
  SCTIMER_SetupPwm(SCT0_PERIPHERAL, &SCT0_pwmSignalsConfig[0], kSCTIMER_EdgeAlignedPwm, 20000U, SCT0_CLOCK_FREQ, &SCT0_pwmEvent[0]);
  SCTIMER_StartTimer(SCT0_PERIPHERAL, kSCTIMER_Counter_U);
}发现相关配置文件已经创建,只是在初始化(SCT0_init(void))中未对有问题的通达进行初始化配置,我们可以通过在外面添加相应的SCTIMER_SetupPwm()重新配置对应的PWM通道。
接下来我们在外部进行对PWM通道进行从新配置:
sctimer_config_t sctimerInfo;
sctimer_pwm_signal_param_t pwmParam;
uint32_t sctimerClock;
uint32_t event;
sctimerClock = CLOCK_GetFreq(kCLOCK_BusClk);
SCTIMER_GetDefaultConfig(&sctimerInfo);
SCTIMER_Init(SCT0, &sctimerInfo);
    /* Configure first PWM with frequency 24kHZ from first output */
    pwmParam.output           = kSCTIMER_Out_0;
    pwmParam.level            = kSCTIMER_HighTrue;
    pwmParam.dutyCyclePercent = 50;
    if (SCTIMER_SetupPwm(SCT0, &pwmParam, kSCTIMER_CenterAlignedPwm, 20000U, sctimerClock, &event) == kStatus_Fail)
    return -1;
    /* Configure second PWM with different duty cycle but same frequency as before */
    pwmParam.output           = kSCTIMER_Out_1;
    pwmParam.dutyCyclePercent = 20;
    return -1;
    SCTIMER_StartTimer(SCT0, kSCTIMER_Counter_U);效果如下:
由上图可以看出当前PWM输出处于中心对称模式,也可以配置为边缘对齐。
