将按键、数码管、蜂鸣器、DS18B20结合到一起可以做成一个温度报警器很简单的逻辑,使用按键配合数码管设定报警温度值(超过设定值报警),报警时蜂鸣器持续鸣叫简单写个汇总的程序
void dis_pro(void)
	static uint32_t timer_dis;
	if (work.timer_ms - timer_dis < 9) // 10ms进入一次
		return;
	timer_dis = work.timer_ms;
	if (work.set_flag == 0) // 非设置模式
		smg_pro(work.tem, 0);
		if (work.tem > work.set_tem) // 报警
			BEEP_Start(10, 10, 0);
		else
			BEEP_Stop();
		if (work.key == 0x31)
			work.set_flag = 1; // 进入设置模式
	else
		smg_pro(work.set_tem, 1);
		if (work.key == 0x11)
			work.set_tem++;
			if (work.set_tem > 999)
				work.set_tem = 0;
		else if (work.key == 0x21)
			work.set_tem--;
			if (work.set_tem == 0XFFFF)
				work.set_tem = 999;
		else if (work.key == 0x31)
			work.set_flag = 0; // 退出设置模式
	work.key = 0;
}下边就是汇总的视频链接
https://www.bilibili.com/video/BV1dM4m1C7PS/?vd_source=ed86e3379cd61e3a01b5fb82fc649e60
