接触NXP的单片机比较少,前面使用RTT,只需要修改少量的代码即可以完成。
今天读了一下他的驱动,发现跟STM32的驱动有很多的不同点。
他的驱动使用结构来定义读取的对一个GPIO的定义如下:
#if defined(FSL_FEATURE_PORT_PCR_MUX_WIDTH) && FSL_FEATURE_PORT_PCR_MUX_WIDTH
/*! @brief PORT pin configuration structure */
typedef struct _port_pin_config
#if defined(FSL_FEATURE_PORT_HAS_PULL_ENABLE) && FSL_FEATURE_PORT_HAS_PULL_ENABLE
uint16_t pullSelect : 2; /*!< No-pull/pull-down/pull-up select */
#else
uint16_t : 2;
#endif /* FSL_FEATURE_PORT_HAS_PULL_ENABLE */
#if defined(FSL_FEATURE_PORT_PCR_HAS_PULL_VALUE) && FSL_FEATURE_PORT_PCR_HAS_PULL_VALUE
uint16_t pullValueSelect : 1; /*!< Pull value select */
#endif /* FSL_FEATURE_PORT_PCR_HAS_PULL_VALUE */
#if defined(FSL_FEATURE_PORT_HAS_SLEW_RATE) && FSL_FEATURE_PORT_HAS_SLEW_RATE
uint16_t slewRate : 1; /*!< Fast/slow slew rate Configure */
#else
uint16_t : 1;
#endif /* FSL_FEATURE_PORT_HAS_SLEW_RATE */
#if !(defined(FSL_FEATURE_PORT_PCR_HAS_PULL_VALUE) && FSL_FEATURE_PORT_PCR_HAS_PULL_VALUE)
uint16_t : 1;
#if defined(FSL_FEATURE_PORT_HAS_PASSIVE_FILTER) && FSL_FEATURE_PORT_HAS_PASSIVE_FILTER
uint16_t passiveFilterEnable : 1; /*!< Passive filter enable/disable */
#else
uint16_t : 1;
#endif /* FSL_FEATURE_PORT_HAS_PASSIVE_FILTER */
#if defined(FSL_FEATURE_PORT_HAS_OPEN_DRAIN) && FSL_FEATURE_PORT_HAS_OPEN_DRAIN
uint16_t openDrainEnable : 1; /*!< Open drain enable/disable */
#else
uint16_t : 1;
#endif /* FSL_FEATURE_PORT_HAS_OPEN_DRAIN */
#if defined(FSL_FEATURE_PORT_HAS_DRIVE_STRENGTH) && FSL_FEATURE_PORT_HAS_DRIVE_STRENGTH
uint16_t driveStrength : 1; /*!< Fast/slow drive strength configure */
#else
uint16_t : 1;
#endif
#if defined(FSL_FEATURE_PORT_HAS_DRIVE_STRENGTH1) && FSL_FEATURE_PORT_HAS_DRIVE_STRENGTH1
uint16_t driveStrength1 : 1; /*!< Normal/Double drive strength enable/disable */
#else
uint16_t : 1;
#endif /* FSL_FEATURE_PORT_HAS_DRIVE_STRENGTH1 */
#if defined(FSL_FEATURE_PORT_PCR_MUX_WIDTH) && (FSL_FEATURE_PORT_PCR_MUX_WIDTH == 3)
uint16_t mux : 3; /*!< Pin mux Configure */
uint16_t : 1;
#elif defined(FSL_FEATURE_PORT_PCR_MUX_WIDTH) && (FSL_FEATURE_PORT_PCR_MUX_WIDTH == 4)
uint16_t mux : 4; /*!< Pin mux Configure */
#else
uint16_t : 4;
#endif
#if defined(FSL_FEATURE_PORT_HAS_INPUT_BUFFER) && FSL_FEATURE_PORT_HAS_INPUT_BUFFER
uint16_t inputBuffer : 1; /*!< Input Buffer Configure */
#else
uint16_t : 1;
#endif /* FSL_FEATURE_PORT_HAS_INPUT_BUFFER */
#if defined(FSL_FEATURE_PORT_HAS_INVERT_INPUT) && FSL_FEATURE_PORT_HAS_INVERT_INPUT
uint16_t invertInput : 1; /*!< Invert Input Configure */
#else
uint16_t : 1;
#endif /* FSL_FEATURE_PORT_HAS_INVERT_INPUT */
uint16_t : 1;
#if defined(FSL_FEATURE_PORT_HAS_PIN_CONTROL_LOCK) && FSL_FEATURE_PORT_HAS_PIN_CONTROL_LOCK
uint16_t lockRegister : 1; /*!< Lock/unlock the PCR field[15:0] */
#else
uint16_t : 1;
#endif /* FSL_FEATURE_PORT_HAS_PIN_CONTROL_LOCK */
} port_pin_config_t;
#endif /* FSL_FEATURE_PORT_PCR_MUX_WIDTH */去除掉条件编译,简化如下:
uint16_t pullSelect : 2; /*!< No-pull/pull-down/pull-up select 先择上下拉方式 */
uint16_t pullValueSelect : 1; /*!< Pull value select 上下位的值 */
uint16_t slewRate : 1; /*!< Fast/slow slew rate Configure 速率*/
uint16_t openDrainEnable : 1; /*!< Open drain enable/disable 开漏是否启用 */
uint16_t driveStrength : 1; /*!< Fast/slow drive strength configure 快/慢驱动 */
uint16_t driveStrength1 : 1; /*!< Normal/Double drive strength enable/disable 正常或双部驱动 */
uint16_t mux : 4; /*!< Pin mux Configure 复用选择*/
uint16_t inputBuffer : 1; /*!< Input Buffer Configure 输入缓冲*/
uint16_t invertInput : 1; /*!< Invert Input Configure 中断是否开启*/
uint16_t : 1;
根据编译条件,结构体优化下来是只是占用了uint16_t的空间,
在管脚的初始化时,示例工程中配置如下:const port_pin_config_t LED_RED = {/* Internal pull-up/down resistor is disabled */
kPORT_PullDisable,
/* Low internal pull resistor value is selected. */
kPORT_LowPullResistor,
/* Fast slew rate is configured */
kPORT_FastSlewRate,
/* Passive input filter is disabled */
kPORT_PassiveFilterDisable,
/* Open drain output is disabled */
kPORT_OpenDrainDisable,
/* Low drive strength is configured */
kPORT_LowDriveStrength,
/* Normal drive strength is configured */
kPORT_NormalDriveStrength,
/* Pin is configured as P3_12 */
kPORT_MuxAlt0,
/* Digital input enabled */
kPORT_InputBufferEnable,
/* Digital input is not inverted */
kPORT_InputNormal,
/* Pin Control Register fields [15:0] are not locked */
kPORT_UnlockRegister};官方的库中,对每个寄存器的配置都给出了枚举,使得阅读方便。
其实大家也不需要太多的去记,因为官方给出的图形化配置工具,给出了详细的中文界,点点就可以配置好:
在这里可以添加一行,对所需的GPIO进行配置,然后自动生成代码。
