前一篇通过MicroPython实现DFRobot盖革模块与wifi连接,本篇通过MicroPython实现DFRobot盖革模块与蓝牙连接。使用ESP32自带的蓝牙模块,与手机蓝牙通讯,读取盖革计数器的值。
源代码如下
DFrobot 盖革计数器实验
接线说明:DFrobot Geiger模块-->ESP32 IO
(D)-->(14)
(+)-->(5V)
(-)-->(GND)
OLED(IIC)液晶模块-->ESP32 IO
GND-->(GND)
VCC-->(5V)
SCL-->(18)
SDA-->(23)
#导入Pin模块
from machine import Pin
from machine import Timer
import time
from machine import SoftI2C
from ssd1306 import SSD1306_I2C #I2C的oled选该方法
from time import sleep_ms
import bluetooth
BLE_MSG = ""
#创建软件I2C对象
i2c = SoftI2C(sda=Pin(23), scl=Pin(18))
#创建OLED对象,OLED分辨率、I2C接口
oled = SSD1306_I2C(128, 64, i2c)
#Geiger in
Geiger_In=Pin(14,Pin.IN,Pin.PULL_UP)
class ESP32_BLE():
def __init__(self, name):
self.led = Pin(15, Pin.OUT)
self.timer1 = Timer(0)
self.name = name
self.ble = bluetooth.BLE()
self.ble.active(True)
self.ble.config(gap_name=name)
self.disconnected()
self.ble.irq(self.ble_irq)
self.register()
self.ble.gatts_write(self.rx, bytes(100)) #修改一次最大接收字节数100
self.advertiser()
def connected(self):
self.led.value(1)
self.timer1.deinit()
def disconnected(self):
self.timer1.init(period=100, mode=Timer.PERIODIC, callback=lambda t: self.led.value(not self.led.value()))
def ble_irq(self, event, data):
global BLE_MSG
if event == 1: #_IRQ_CENTRAL_CONNECT 手机链接了此设备
self.connected()
elif event == 2: #_IRQ_CENTRAL_DISCONNECT 手机断开此设备
self.advertiser()
self.disconnected()
elif event == 3: #_IRQ_GATTS_WRITE 手机发送了数据
buffer = self.ble.gatts_read(self.rx)
BLE_MSG = buffer.decode('UTF-8').strip()
def register(self):
service_uuid = '6E400001-B5A3-F393-E0A9-E50E24DCCA9E'
reader_uuid = '6E400002-B5A3-F393-E0A9-E50E24DCCA9E'
sender_uuid = '6E400003-B5A3-F393-E0A9-E50E24DCCA9E'
services = (
bluetooth.UUID(service_uuid),
(bluetooth.UUID(sender_uuid), bluetooth.FLAG_NOTIFY),
(bluetooth.UUID(reader_uuid), bluetooth.FLAG_WRITE),
((self.tx, self.rx,), ) = self.ble.gatts_register_services(services)
def send(self, data):
self.ble.gatts_notify(0, self.tx, data + '\n')
def advertiser(self):
name = bytes(self.name, 'UTF-8')
adv_data = bytearray('\x02\x01\x02', 'UTF-8') + bytearray((len(name) + 1, 0x09)) + name
self.ble.gap_advertise(100, adv_data)
print(adv_data)
print("\r\n")
#Geiger计数器外部中断函数
def Geiger_In_irq(Geiger_In):
global numPulse
numPulse = numPulse + 1
ble.send(str3)
#程序入口
if __name__=="__main__":
global numPulse
BUFFER_SIZE = 20
rows, cols = 2, BUFFER_SIZE
mem_data = [[0 for _ in range(cols)] for _ in range(rows)]
numPulse = 0
pos = 0
oled.fill(0) #清空屏幕
oled.text("Geiger Counter",0,0,1) #显示字符串
oled.show() #执行显示
ble = ESP32_BLE("Geiger_Counter")
Geiger_In.irq(Geiger_In_irq,Pin.IRQ_FALLING) #配置外部中断,下降沿触发
while True:
time.sleep_ms(3000)
mem_data[0][pos] = time.ticks_ms()
mem_data[1][pos] = numPulse
numPulse = 0
cpm=0
pos_old = pos
pos = (pos+1)%BUFFER_SIZE
numAll = 0
uSvh = 0
time_now = mem_data[0][pos_old]
for i in range(0, BUFFER_SIZE - 1):
if mem_data[0][pos_old] != 0:
numAll = numAll + mem_data[1][pos_old]
time_old = mem_data[0][pos_old]
if pos_old == 0:
pos_old = BUFFER_SIZE - 1
else:
pos_old = pos_old - 1
if time_now-time_old > 0:
cpm = numAll*1000*60/(time_now-time_old)
uSvh = cpm/151
str1 = "{:.0f}".format(cpm) #CPM转字符串
str2 = "{:.3f}".format(uSvh) #uSv/h转字符串
oled.fill(0) #清空屏幕
oled.text("CPM",80,10,2) #显示CPM单位
oled.text("uSv/h",80,20,2) #显示uSv/h单位
oled.text(str1,0,10,2) #显示CPM数据
oled.text(str2,0,20,2) #显示uSv/h数据
oled.show() #执行显示
str3 = str1+' CPM ' + str2+' uSv/h'
print(str3)手机上下载BLE调试助手APP,
程序下载运行后,打开BLE调试助手APP后,连接到Geiger_Counter蓝牙,
选择Unknown Service,点击接受数据,手机蓝牙收到盖革计数器的测量值。
