EXMC初始化之后,对外部SRAM的操作没有效果,以下是代码部分(nor_region传的是EXMC_BANK0_NORSRAM_REGION0)。
是什么问题。
void exmc_norflash_init(uint32_t nor_region)
exmc_norsram_parameter_struct nor_init_struct;
exmc_norsram_timing_parameter_struct nor_timing_init_struct;
gpio_deinit(GPIOB);
gpio_deinit(GPIOD);
gpio_deinit(GPIOE);
gpio_deinit(GPIOF);
gpio_deinit(GPIOG);
exmc_norsram_deinit(nor_region);
/* EXMC clock enable */
rcu_periph_clock_enable(RCU_EXMC);
/* GPIO clock enable */
rcu_periph_clock_enable(RCU_GPIOB);
rcu_periph_clock_enable(RCU_GPIOD);
rcu_periph_clock_enable(RCU_GPIOE);
rcu_periph_clock_enable(RCU_GPIOF);
rcu_periph_clock_enable(RCU_GPIOG);
/* configure GPIO D[0-15] */
gpio_af_set(GPIOD, GPIO_AF_12, GPIO_PIN_0 | GPIO_PIN_1 | GPIO_PIN_8 | GPIO_PIN_9 |
GPIO_PIN_10 | GPIO_PIN_14 | GPIO_PIN_15);
gpio_mode_set(GPIOD, GPIO_MODE_AF, GPIO_PUPD_PULLUP, GPIO_PIN_0 | GPIO_PIN_1 | GPIO_PIN_8 | GPIO_PIN_9 |
gpio_output_options_set(GPIOD, GPIO_OTYPE_PP, GPIO_OSPEED_100_220MHZ, GPIO_PIN_0 | GPIO_PIN_1 | GPIO_PIN_8 | GPIO_PIN_9 |
gpio_af_set(GPIOE, GPIO_AF_12, GPIO_PIN_7 | GPIO_PIN_8 | GPIO_PIN_9 | GPIO_PIN_10 |
GPIO_PIN_11 | GPIO_PIN_12 | GPIO_PIN_13 | GPIO_PIN_14 | GPIO_PIN_15);
gpio_mode_set(GPIOE, GPIO_MODE_AF, GPIO_PUPD_PULLUP, GPIO_PIN_7 | GPIO_PIN_8 | GPIO_PIN_9 | GPIO_PIN_10 |
gpio_output_options_set(GPIOE, GPIO_OTYPE_PP, GPIO_OSPEED_100_220MHZ, GPIO_PIN_7 | GPIO_PIN_8 | GPIO_PIN_9 | GPIO_PIN_10 |
/* configure GPIO A[0-23] */
gpio_af_set(GPIOF, GPIO_AF_12, GPIO_PIN_0 | GPIO_PIN_1 | GPIO_PIN_2 | GPIO_PIN_3 |
GPIO_PIN_4 | GPIO_PIN_5 | GPIO_PIN_12 | GPIO_PIN_13 | GPIO_PIN_14 | GPIO_PIN_15);
gpio_mode_set(GPIOF, GPIO_MODE_AF, GPIO_PUPD_PULLUP, GPIO_PIN_0 | GPIO_PIN_1 | GPIO_PIN_2 | GPIO_PIN_3 |
gpio_output_options_set(GPIOF, GPIO_OTYPE_PP, GPIO_OSPEED_100_220MHZ, GPIO_PIN_0 | GPIO_PIN_1 | GPIO_PIN_2 | GPIO_PIN_3 |
gpio_af_set(GPIOG, GPIO_AF_12, GPIO_PIN_0 | GPIO_PIN_1 | GPIO_PIN_2 | GPIO_PIN_3 |
GPIO_PIN_4 | GPIO_PIN_5);
gpio_mode_set(GPIOG, GPIO_MODE_AF, GPIO_PUPD_PULLUP, GPIO_PIN_0 | GPIO_PIN_1 | GPIO_PIN_2 | GPIO_PIN_3 |
gpio_output_options_set(GPIOG, GPIO_OTYPE_PP, GPIO_OSPEED_100_220MHZ, GPIO_PIN_0 | GPIO_PIN_1 | GPIO_PIN_2 | GPIO_PIN_3 |
gpio_af_set(GPIOD, GPIO_AF_12, GPIO_PIN_11 | GPIO_PIN_12 | GPIO_PIN_13);
gpio_mode_set(GPIOD, GPIO_MODE_AF, GPIO_PUPD_PULLUP, GPIO_PIN_11 | GPIO_PIN_12 | GPIO_PIN_13);
gpio_output_options_set(GPIOD, GPIO_OTYPE_PP, GPIO_OSPEED_100_220MHZ, GPIO_PIN_11 | GPIO_PIN_12 | GPIO_PIN_13);
gpio_af_set(GPIOE, GPIO_AF_12, GPIO_PIN_2 | GPIO_PIN_3 | GPIO_PIN_4 | GPIO_PIN_5 | GPIO_PIN_6);
gpio_mode_set(GPIOE, GPIO_MODE_AF, GPIO_PUPD_PULLUP, GPIO_PIN_2 | GPIO_PIN_3 | GPIO_PIN_4 | GPIO_PIN_5 | GPIO_PIN_6);
gpio_output_options_set(GPIOE, GPIO_OTYPE_PP, GPIO_OSPEED_100_220MHZ, GPIO_PIN_2 | GPIO_PIN_3 | GPIO_PIN_4 | GPIO_PIN_5 | GPIO_PIN_6);
/* configure NOE NWE */
gpio_af_set(GPIOD, GPIO_AF_12, GPIO_PIN_4 | GPIO_PIN_5);
gpio_mode_set(GPIOD, GPIO_MODE_AF, GPIO_PUPD_PULLUP, GPIO_PIN_4 | GPIO_PIN_5);
gpio_output_options_set(GPIOD, GPIO_OTYPE_PP, GPIO_OSPEED_100_220MHZ, GPIO_PIN_4 | GPIO_PIN_5);
/* configure NBL0-1 */
gpio_af_set(GPIOE, GPIO_AF_12, GPIO_PIN_0 | GPIO_PIN_1);
gpio_mode_set(GPIOE, GPIO_MODE_AF, GPIO_PUPD_PULLUP, GPIO_PIN_0 | GPIO_PIN_1);
gpio_output_options_set(GPIOE, GPIO_OTYPE_PP, GPIO_OSPEED_100_220MHZ, GPIO_PIN_0 | GPIO_PIN_1);
/* configure EXMC NE0*/
gpio_af_set(GPIOD, GPIO_AF_12, GPIO_PIN_7);
gpio_mode_set(GPIOD, GPIO_MODE_AF, GPIO_PUPD_PULLUP, GPIO_PIN_7);
gpio_output_options_set(GPIOD, GPIO_OTYPE_PP, GPIO_OSPEED_100_220MHZ, GPIO_PIN_7);
/* configure CLK and NWAIT */
gpio_af_set(GPIOD, GPIO_AF_12, GPIO_PIN_3 | GPIO_PIN_6);
gpio_mode_set(GPIOD, GPIO_MODE_AF, GPIO_PUPD_PULLUP, GPIO_PIN_3 | GPIO_PIN_6);
gpio_output_options_set(GPIOD, GPIO_OTYPE_PP, GPIO_OSPEED_100_220MHZ, GPIO_PIN_3 | GPIO_PIN_6);
exmc_norsram_struct_para_init(&nor_init_struct);
nor_timing_init_struct.asyn_access_mode = EXMC_ACCESS_MODE_A;
nor_timing_init_struct.syn_data_latency = EXMC_DATALAT_6_CLK;
nor_timing_init_struct.syn_clk_division = EXMC_SYN_CLOCK_RATIO_6_CLK;
nor_timing_init_struct.bus_latency = 5;
nor_timing_init_struct.asyn_data_setuptime = 80;
nor_timing_init_struct.asyn_address_holdtime = 10;
nor_timing_init_struct.asyn_address_setuptime = 10;
/* configure EXMC bus parameters */
nor_init_struct.norsram_region = nor_region;
nor_init_struct.address_data_mux = DISABLE;
nor_init_struct.memory_type = EXMC_MEMORY_TYPE_SRAM;
nor_init_struct.databus_width = EXMC_NOR_DATABUS_WIDTH_16B;
nor_init_struct.burst_mode = DISABLE;
nor_init_struct.nwait_polarity = EXMC_NWAIT_POLARITY_LOW;
nor_init_struct.nwait_config = EXMC_NWAIT_CONFIG_BEFORE;
nor_init_struct.memory_write = ENABLE;
nor_init_struct.nwait_signal = DISABLE;
nor_init_struct.extended_mode = DISABLE;
nor_init_struct.asyn_wait = DISABLE;
nor_init_struct.write_mode = EXMC_ASYN_WRITE;
nor_init_struct.cram_page_size = EXMC_CRAM_AUTO_SPLIT;
nor_init_struct.read_write_timing = &nor_timing_init_struct;
nor_init_struct.write_timing = &nor_timing_init_struct;
exmc_norsram_init(&nor_init_struct);
exmc_norsram_enable(nor_region);
请教下GD32H7系列的外部SRAM读写EXMC初始化问题
硬核工程师专属补给计划——填盲盒 | |
“我踩过的那些坑”主题活动——第002期 | |
【EEPW电子工程师创研计划】技术变现通道已开启~ | |
【EEPW在线】E起听工程师的声音! | |
高校联络员开始招募啦!有惊喜!! | |
送您一块开发板,2025年“我要开发板活动”又开始了! |
