如下
[root@tian myapp]# arm-elf-ld -L/uClinux-dist/uClibc -L/usr/local/arm-elf/lib -L/usr/local/lib/gcc-lib/arm-elf/2.95.3 -L/usr/lib -elf2flt -o hello /uClinux-dist/lib/libc/crt0.o /usr/lib/gcc-lib/i386-redhat-linux/3.2.2/crtbegin.o hello.o /usr/lib/gcc-lib/i386-redhat-linux/3.2.2/crtend.o -lc -lgcc -lc /usr/local/bin/arm-elf-ld: line 139: 4084 段错误 $LINKER -r -d -o $OFILE.elf2flt $ARG1
[root@tian myapp]#
[align=right][color=#000066][此贴子已经被作者于2005-1-15 21:58:25编辑过][/color][/align]
