BROADBAND PACKET SWITCHING TECHNOLOGIES
BROADBAND PACKET
BROADBAND PACKET
A Practical Guide to ATM Switches
and IP Routers
H. JONATHAN CHAO
CHEUK H. LAM
EIJI OKI
A Wiley-Interscience Publication
JOHN WILEY & SONS, INC.
New York r Chichester r Weinheim r Brisbane r Singapore r Toronto
Designations used by companies to distinguish their products are often claimed as trademarks.
In all instances where John Wiley & Sons, Inc., is aware of a claim, the product names
appear in initial capital or ALL CAPITAL LETTERS. Readers, however, should contact the
appropriate companies for more complete information regarding trademarks and registration.
Copyright _ 2001 by John Wiley & Sons, Inc. All rights reserved.
No part of this publication may be reproduced, stored in a retrieval system or transmitted
in any form or by any means, electronic or mechanical, including uploading, downloading,
printing, decompiling, recording or otherwise, except as permitted under Sections 107 or
108 of the 1976 United States Copyright Act, without the prior written permission of the
Publisher. Requests to the Publisher for permission should be addressed to the
Permissions Department, John Wiley & Sons, Inc., 605 Third Avenue, New York, NY
. . 10158-0012, 212 850-6011, fax 212 850-6008, E-Mail: PERMREQ & WILEY.COM.
This publication is designed to provide accurate and authoritative information in regard to the
subject matter covered. It is sold with the understanding that the publisher is not engaged in
rendering professional services. If professional advice or other expert assistance is required, the
services of a competent professional person should be sought.
ISBN 0-471-22440-5
This title is also available in print as ISBN 0-471-00454-5
For more information about Wiley products, visit our web site at www.Wiley.com.
CONTENTS
PREFACE xiii
1 INTRODUCTION 1
1.1 ATM Switch Systems r 3
1.1.1 Basics of ATM networks r 3
1.1.2 ATM switch structure r 5
1.2 IP Router Systems r 8
1.2.1 Functions of IP routers r 8
1.2.2 Architectures of IP routers r 9
1.3 Design Criteria and Performance Requirements r 13
References r 14
2 BASICS OF PACKET SWITCHING 15
2.1 Switching Concepts r 17
2.1.1 Internal link blocking r 17
2.1.2 Output port contention r 18
2.1.3 Head-of-line blocking r 19
2.1.4 Multicasting r 19
2.1.5 Call splitting r 20
2.2 Switch Architecture Classification r 21
2.2.1 Time division switching r 22
v
CONTENTS vi
2.2.2 Space division switching r 24
2.2.3 Buffering strategies r 34
2.3 Performance of Basic Switches r 37
2.3.1 Input-buffered switches r 37
2.3.2 Output-buffered switches r 40
2.3.3 Completely shared-buffer switches r 44
References r 46
3 INPUT-BUFFERED SWITCHES 49
3.1 A Simple Switch Model r 50
3.1.1 Head-of-line blocking phenomenon r 51
3.1.2 Traffic models and related throughput results r 52
3.2 Methods for Improving Performance r 53
3.2.1 Increasing internal capacity r 53
3.2.2 Increasing scheduling efficiency r 54
3.3 Scheduling Algorithms r 57
. 3.3.1 Parallel iterative matching PIM r 58
. 3.3.2 Iterative round-robin matching iRRM r 60
. 3.3.3 Iterative round-robin with SLIP iSLIP r 60
. 3.3.4 Dual round-robin matching DRRM r 62
3.3.5 Round-robin greedy scheduling r 65
3.3.6 Design of round-robin arbitersrselectors r 67
3.4 Output-Queuing Emulation r 72
. 3.4.1 Most-Urgent-Cell-First-Algorithm MUCFA r 72
3.4.2 Chuang et al.’s results r 73
. 3.5 Lowest-Output-Occupancy-Cell-First Algorithm LOOFA
r 78
References r 80
4 SHARED-MEMORY SWITCHES 83
4.1 Linked-List Approach r 84
4.2 Content-Addressable Memory Approach r 91
4.3 Space_Time_Space Approach r 93
4.4 Multistage Shared-Memory Switches r 94
4.4.1 Washington University gigabit switch r 95
4.4.2 Concentrator-based growable switch
architecture r 96
4.5 Multicast Shared-Memory Switches r 97
CONTENTS vii
4.5.1 Shared-memory switch with a multicast logical
queue r 97
4.5.2 Shared-memory switch with cell copy r 98
4.5.3 Shared-memory switch with address copy r 99
References r 101
5 BANYAN-BASED SWITCHES 103
5.1 Banyan Networks r 103
5.2 Batcher-Sorting Network r 106
5.3 Output Contention Resolution Algorithms r 110
5.3.1 Three-phase implementation r 110
5.3.2 Ring reservation r 110
5.4 The Sunshine Switch r 112
5.5 Deflection Routing r 114
5.5.1 Tandem banyan switch r 114
5.5.2 Shuffle-exchange network with deflection
routing r 117
5.5.3 Dual shuffle-exchange network with error-correcting
routing r 118
5.6 Multicast Copy Networks r 125
5.6.1 Broadcast banyan network r 127
5.6.2 Encoding process r 129
5.6.3 Concentration r 132
5.6.4 Decoding process r 133
5.6.5 Overflow and call splitting r 133
5.6.6 Overflow and input fairness r 134
References r 138
6 KNOCKOUT-BASED SWITCHES 141
6.1 Single-Stage Knockout Switch r 142
6.1.1 Basic architecture r 142
6.1.2 Knockout concentration principle r 144
6.1.3 Construction of the concentrator r 146
6.2 Channel Grouping Principle r 150
6.2.1 Maximum throughput r 150
6.2.2 Generalized knockout principle r 152
6.3 A Two-Stage Multicast Output-Buffered ATM
Switch r 154
6.3.1 Two-stage configuration r 154
CONTENTS viii
6.3.2 Multicast grouping network r 157
6.3.3 Translation tables r 160
6.3.4 Multicast knockout principle r 163
6.4 A Fault-Tolerant Multicast Output-Buffered ATM
Switch r 169
6.4.1 Fault model of switch element r 169
6.4.2 Fault detection r 172
6.4.3 Fault location and reconfiguration r 174
6.4.4 Performance analysis of reconfigured switch
module r 181
6.5 Appendix r 185
References r 187
7 THE ABACUS SWITCH 189
7.1 Basic Architecture r 190
7.2 Multicast Contention Resolution Algorithm r 193
7.3 Implementation of Input Port Controller r 197
7.4 Performance r 198
7.4.1 Maximum throughput r 199
7.4.2 Average delay r 203
7.4.3 Cell loss probability r 206
7.5 ATM Routing and Concentration Chip r 208
7.6 Enhanced Abacus Switch r 211
7.6.1 Memoryless multistage concentration network r 212
7.6.2 Buffered multistage concentration network r 214
7.6.3 Resequencing cells r 217
7.6.4 Complexity comparison r 219
7.7 Abacus Switch for Packet Switching r 220
7.7.1 Packet interleaving r 220
7.7.2 Cell interleaving r 222
References r 224
8 CROSSPOINT-BUFFERED SWITCHES 227
8.1 Overview of Crosspoint-Buffered Switches r 228
8.2 Scalable Distributed Arbitration Switch r 229
8.2.1 SDA structure r 229
8.2.2 Performance of SDA switch r 231
8.3 Multiple-QoS SDA Switch r 234
8.3.1 MSDA structure r 234
CONTENTS ix
8.3.2 Performance of MSDA switch r 236
References r 238
9 THE TANDEM-CROSSPOINT SWITCH 239
9.1 Overview of Input_Output_Buffered Switches r 239
9.2 TDXP Structure r 241
9.2.1 Basic architecture r 241
9.2.2 Unicasting operation r 242
9.2.3 Multicasting operation r 246
9.3 Performance of TDXP Switch r 246
References r 252
10 CLOS-NETWORK SWITCHES 253
10.1 Routing Properties and Scheduling Methods r 255
10.2 A Suboptimal Straight Matching Method for Dynamic
Routing r 258
10.3 The ATLANTA Switch r 259
10.3.1 Basic architecture r 261
10.3.2 Distributed and random arbitration r 261
10.3.3 Multicasting r 262
10.4 The Continuous Round-Robin Dispatching Switch r 263
10.4.1 Basic architecture r 264
. 10.4.2 Concurrent round-robin dispatching CRRD
scheme r 265
10.4.3 Desynchronization effect of CRRD r 267
10.5 The Path Switch r 268
10.5.1 Homogeneous capacity and route
assignment r 272
10.5.2 Heterogeneous capacity assignment r 274
References r 277
11 OPTICAL PACKET SWITCHES 279
11.1 All-Optical Packet Switches r 281
11.1.1 The staggering switch r 281
11.1.2 ATMOS r 282
11.1.3 Duan’s switch r 283
11.2 Optoelectronic Packet Switches r 284
11.2.1 HYPASS r 284
11.2.2 STAR-TRACK r 286
CONTENTS x
11.2.3 Cisneros and Brackett’s Architecture r 287
11.2.4 BNR switch r 289
11.2.5 Wave-mux switch r 290
11.3 The 3M Switch r 291
11.3.1 Basic architecture r 291
11.3.2 Cell delineation unit r 294
11.3.3 VCI-overwrite unit r 296
11.3.4 Cell synchronization unit r 297
11.4 Optical Interconnection Network for Terabit IP
Routers r 301
11.4.1 Introduction r 301
11.4.2 A terabit IP router architecture r 303
11.4.3 Router module and route controller r 306
11.4.4 Optical interconnection network r 309
11.4.5 Ping-pong arbitration unit r 315
11.4.6 OIN complexity r 324
11.4.7 Power budget analysis r 326
11.4.8 Crosstalk analysis r 328
References r 331
12 WIRELESS ATM SWITCHES 337
12.1 Wireless ATM Structure Overviews r 338
12.1.1 System considerations r 338
12.1.2 Wireless ATM protocol r 349
12.2 Wireless ATM Systems r 341
12.2.1 NEC’s WATMnet prototype system r 341
12.2.2 Olivetti’s radio ATM LAN r 342
12.2.3 Virtual connection tree r 342
12.2.4 BAHAMA wireless ATM LAN r 343
12.2.5 NTT’s wireless ATM Access r 343
12.2.6 Other European projects r 243
12.3 Radio Access Layers r 344
12.3.1 Radio physical layer r 344
12.3.2 Medium access control layer r 346
12.3.3 Data link control layer r 346
12.4 Handoff in Wireless ATM r 347
12.4.1 Connection rerouting r 348
12.4.2 Buffering r 340
CONTENTS xi
12.4.3 Cell routing in a COS r 351
12.5 Mobility-Support ATM Switch r 352
12.5.1 Design of a mobility-support switch r 353
12.5.2 Performance r 358
References r 362
13 IP ROUTE LOOKUPS 365
13.1 IP Router Design r 366
13.1.1 Architectures of generic routers r 366
13.1.2 IP route lookup design r 368
13.2 IP Route Lookup Based on Caching Technique
r 369
13.3 IP Route Lookup Based on Standard Trie
Structure r 369
13.4 Patricia Tree r 372
13.5 Small Forwarding Tables for Fast Route Lookups r 373
13.5.1 Level 1 of data structure r 374
13.5.2 Levels 2 and 3 of data structure r 376
13.5.3 Performance r 377
13.6 Route Lookups in Hardware at Memory Access
Speeds r 377
13.6.1 The DIR-24-8-BASIC scheme r 378
13.6.2 Performance r 381
13.7 IP Lookups Using Multiway Search r 381
13.7.1 Adapting binary search for best matching
prefix r 381
13.7.2 Precomputed 16-bit prefix table r 384
13.7.3 Multiway binary search: exploiting the cache
line r 385
13.7.4 Performance r 388
13.8 IP Route Lookups for Gigabit Switch Routers r 388
13.8.1 Lookup algorithms and data structure
construction r 388
13.8.2 Performance r 395
13.9 IP Route Lookups Using Two-Trie Structure r 396
13.9.1 IP route lookup algorithm r 397
13.9.2 Prefix update algorithms r 398
13.9.3 Performance r 403
References r 404
CONTENTS xii
APPENDIX SONET AND ATM PROTOCOLS 407
A.1 ATM Protocol Reference Model r 409
. A.2 Synchronous Optical Network SONET r 410
A.2.1 SONET sublayers r 410
A.2.2 STS-N signals r 412
A.2.3 SONET overhead bytes r 414
A.2.4 Scrambling and descrambling r 417
A.2.5 Frequency justification r 418
. A.2.6 Automatic protection switching APS r 419
A.2.7 STS-3 versus STS-3c r 421
A.2.8 OC-N multiplexer r 422
A.3 Sub-Layer Functions in Reference Model r 423
. A.4 Asynchronous Transfer Mode ATM r 425
A.4.1 Virtual pathrvirtual channel identifier
. VPIrVCI r 426
. A.4.2 Payload type identifier PTI r 427
. A.4.3 Cell loss priority CLP r 428
A.4.4 Pre-defined header field values r 428
. A.5 ATM Adaptation Layer AAL r 429
. A.5.1 AAL type 1 AAL1 r 431
. A.5.2 AAL type 2 AAL2 r 433
. A.5.3 AAL types 3r4 AAL3r4 r 434
. A.5.4 AAL type 5 AAL5 r 436
References r 438
INDEX 439
关键词: BROADBAND PACKET SWITCHIN
PREFACE
This packet switching book mainly targets high-speed packet networking. As
Internet traffic grows exponentially, there is a great need to build multiŽ
. . terabit Internet protocol IP routers, asynchronous transfer mode ATM
. switches, multiprotocol label switch MPLS switches, and optical switches.
Packet switching technologies have been investigated and researched
intensively for almost two decades, but there are very few appropriate
textbooks describing it. Many engineers and students have to search for
technical papers and read them in an ad hoc manner. This book is the first
that explains packet switching concepts and implementation technologies in
broad scope and great depth.
This book addresses the basics, theory, architectures, and technologies to
implement ATM switches, IP routers, and optical switches. The book is
based on the material that Jonathan has been teaching to the industry and
universities for the past decade. He taught a graduate course ‘‘Broadband
Packet Switching Systems’’ at Polytechnic University, New York, and used
the draft of the book as the text. The book has incorporated feedback from
both industry people and college students.
The fundamental concepts and technologies of packet switching described
in the book are useful and practical when designing IP routers, packet
switches, and optical switches. The basic concepts can also stand by themselves
and are independent of the emerging network platform, for instance,
. IP, ATM, MPLS, and IP over wavelength-division multiplexing WDM .
ATM switching technologies have been widely used to achieve high speed
and high capacity. This is because ATM uses fixed-length cells and the
switching can be implemented at high speed with synchronous hardware
xiii
PREFACE xiv
logics. Although most of low-end to medium-size IP routers do not use the
same hardware-based technologies as those of ATM switches, next-generaŽ
tion backbone IP routers will use the ATM switching technologies although
the cell size in the switch core of IP routers may be different from that of
. ATM cells . The switching technologies described in this book are common
to both ATM switches and IP routers. We believe that the book will be a
practical guide to understand ATM switches and IP routers.
硬核工程师专属补给计划——填盲盒 | |
“我踩过的那些坑”主题活动——第002期 | |
【EEPW电子工程师创研计划】技术变现通道已开启~ | |
【EEPW在线】E起听工程师的声音! | |
高校联络员开始招募啦!有惊喜!! | |
送您一块开发板,2025年“我要开发板活动”又开始了! |
