VxWorks_etherLib Problem(老站转)
小华
高级工程师
来自:
发表总数:102
查看 短消息 电子邮件
Hi,
I didnot use the functions of the etherLib.
I want use it to transfer and receive ethernet packets.
Anyone used it before?
Can you give me some example program?
Thanks!
编辑 发表於:2002-01-25 - 10:19:36 IP: 202.119.*.*
superme
来自:
发表总数:40
查看 短消息 电子邮件
Give you a sample code for low level Ethernet routines. It includes three files:
etherDemo.h, etherInputDemo.c and etherOutputDemo.c
The following are the code:
/* etherDemo.h - header for etherInputDemo and etherOutputDemo */
/* Copyright 1984-1997 Wind River Systems, Inc. */
modification history
01b,06nov97,mm added copyright.
01a,17feb94,ms written
#define ET_TYPE (u_short)1111 /* user defined protocol type */
#define INTERFACE_NAME "sm0" /* name of your network interface name*/
LOCAL STATUS etBcast(); /* broadcast on ethernet network interface */
/* LOCAL BOOL etHandle (); ether input hook routine for handling input */
LOCAL char etMessage [] = "Hello World!!!"; /* data to be passed*/
/* Broadcast ethernet address is used for simple demonstration. You can
* replace the value of the etbcastaddr variable with the destination
* ethernet address.
unsigned char etbcastaddr [6] = { 0xff, 0xff, 0xff, 0xff, 0xff, 0xff };
编辑 发表於:2002-01-29 - 08:39:04 IP: 24.100.*.*
superme
来自:
发表总数:40
查看 短消息 电子邮件
/* etherInputDemo.c - Demo for using low-level ethernet input routines */
01e,06nov97,mm added copyright.
01d,22Sep97,mm removed include changed include "etherDemo.h" to
"in_etherDemo.h"
01c,22Sep97,mm added include , , and
01b,22Sep97,mm changed "if.h" to "net/if.h"
01a,16Feb94,ms modified and cleaned up for VxDemo.
#include
#include
#include
#include
#include "net/if.h"
#include "netinet/if_ether.h"
#include "in_etherDemo.h"
* etherInputDemo - Demo for using low-level ethernet input routines
* DESCRIPTION
* Handles (receives) raw input frames (input data) from the network
* interface using ether input hook routine etHandle.
* This is a simple demonstration of using low-level input ethernet
* routines. The other half of the demonstration of using low-level
* output ethernet routines is in etherOutputDemo.c. etherInputDemo runs on
* one VxWorks system, and etherOutputDemo runs on an other VxWorks system
* in the same physical network.
* RETURNS: OK or ERROR
* EXAMPLE:
* To run this etherInputDemo task from the VxWorks shell do as follows:
* -> sp (etherInputDemo)
STATUS etherInputDemo ()
if (etherInputHookAdd (etHandle) == OK)
printf ("etherInputHookAdd successful\n");
else
perror ("etherInputHook failed");
return (ERROR);
return (OK);
* etHandle - ether input hook routine for handling raw input frames from the
* network interface. This routine is executed at task level
* interrupt service for input packets.
* RETURNS: TRUE or FALSE
BOOL etHandle (ifp, buffer, length)
struct ifnet *ifp;
char *buffer;
int length;
struct ether_header *ethHdr;
char *buffPtr;
int ix;
char tmp[25];
ethHdr = (struct ether_header *) buffer;
if (ntohs(ethHdr->ether_type) != (u_short) ET_TYPE)
return (FALSE); /* Not a user defined protocol type, hence 0 is passed
* to indicate further processing of data to be handled by
* higher level protocols (IP, TCP etc., ).
/* Handle raw input frames.
* Data integrity check and printing the input message is done for
* demonstration purpose.
/* Check for data integrity error */
buffPtr = (char *) (buffer + sizeof (*ethHdr));
strncpy (tmp, buffPtr, strlen (etMessage));
for (ix = 0; ix < sizeof (etMessage); ++ix)
if (*buffPtr++ != etMessage [ix])
break;
if (ix != strlen (etMessage))
logMsg ("etHandle: data integrity error at %d.\n", ix);
return (ERROR);
logMsg ("etHandle: data okay - message is : %s \n", tmp);
return (TRUE); /* non-zero value to imply hook routine has processed
* the input and there is no need for further handling by
* any higher level protocols (IP, TCP etc.)
编辑 发表於:2002-01-29 - 08:40:09 IP: 24.100.*.*
superme
来自:
发表总数:40
查看 短消息 电子邮件
/* etherOutputDemo.c - Demo for using low-level output ethernet routines */
01d,06nov97,mm added copyright.
01c,22Sep97,mm added include string.h and "etherLib.h"
01b,22Sep97,mm changed "if.h" to "netinet/if_ether.h"
#include "net/if.h"
#include "etherDemo.h"
#include
#include
#include "etherLib.h"
* etherOutputDemo - Demo for using low-level ethernet output routines
* DESCRIPTION
* Sends (broadcast) data on an ethernet network interface
* and handles (receives) raw input frames (input data) from the network
* This is a simple demonstration of using low-level output ethernet
* input ethernet routines is in etherInputDemo.c. etherInputDemo task
* runs on one VxWorks system, and etherOutputDemo task runs on other
* VxWorks system in the same physical network.
* EXAMPLE:
* To run this etherOutputDemo task from the VxWorks shell do as follows:
* -> sp (etherOutputDemo)
STATUS etherOutputDemo ()
if (etBcast (INTERFACE_NAME) == ERROR)
printf ("etherOutput broadcast failed\n");
return (ERROR);
else
printf ("etherOutputDemo completed\n");
return (OK);
* etBcast - Sends (broadcast) data on an ethernet network interface
STATUS etBcast
char *ifname /* name of the network interface eg. "ei0" */
struct ether_header ethHdr; /* ethernet header */
struct ifnet *pIfnet; /*Pointer to your network interface's ifnet struct*/
pIfnet = ifunit (ifname); /* get the ifnet pointer of your network
* interface
if (pIfnet == (struct ifnet *) NULL)
printf ("ifunit failed\n");
return (ERROR);
/* Set the value of destination host's ethernet address -
here broadcast ethernet address is set */
bcopy (etbcastaddr, ethHdr.ether_dhost, sizeof (ethHdr.ether_dhost));
ethHdr.ether_type = htons (ET_TYPE); /* user defined protocol */
printf ("Protocol type 0x%x \n\n", (u_short)ethHdr.ether_type);
/* send (broadcast) message on an ethernet interface */
if (etherOutput (pIfnet, ðHdr, etMessage, strlen (etMessage)) == ERROR)
perror ("etherOutput failed");
return (ERROR);
else
printf ("etherOutput done - message: %s \n", etMessage);
return (OK);
编辑 发表於:2002-01-29 - 08:41:24 IP: 24.100.*.*
小华
高级工程师
来自:
发表总数:102
查看 短消息 电子邮件
谢谢您,这些代码对我很有帮助,祝您春节愉快!
关键词: VxWorks etherLib Problem
| OrangePiZero2W系统被打赏¥33元 | |
