2.1i Service Pack 4 Readme for PC
This 2.1i Service Pack 4 Update is intended as an update to all 2.1i Alliance
and Foundation installations on W95/W98/WNT machines.
All fixes packaged in the previous 2.1i Service Packs are included in Service
Pack 4. Installation of the earlier Service Packs is NOT necessary.
The Device Data Files Update contains all new fixes for Service Pack 4. The
Service Pack 4 Implementation Update is identical to the Service Pack 3
Implementation Update. Xilinx customers who previously downloaded Service
Pack 3 need not install the Implementation Update again.
Service Pack 4 requires AT LEAST 200MB free disk space to complete
installation.
Fewer than 200MB free TEMP disk space may result in the following error:
PackageForTheWeb Error
System error during decompression
Creating extra disk space will allow the installation to successfully
complete.
Implementation Update Installation Instructions:
Download the 21i_sp4_implementation_pc.exe update file.
Run "21i_sp4_implementation_pc.exe".
Device Data Files Update Installation Instructions:
Download the 21i_sp4_data_pc.exe update file.
Run "21i_sp4_data_pc.exe"
FPGA Express Files Update Installation Instructions (Intended only for users
of Foundation Express):
Download the 21i_FPGAExpress.exe update file.
Run "21i_FPGAExpress.exe"
NOTE 1: The destination directory specified during the setup operation must
contain an existing 2.1i installation. Only existing files will be updated.
Any new device support not previously installed, should first be installed
from the 2.1i CD before installing the service pack update.
NOTE 2: Foundation users must perform the setup operation on a machine with
an existing Foundation 2.1i environment.
For information on the contents of the Implementation Tools Update see:
Xilinx Answer #8299
The following products are addressed in 2.1i Service Pack 4
NGDBuild
Map
Par
Timing
Back Annotation
Hardware Debugger Bitgen
Design Manager
JTAG Programmer
CPLD
Floorplanner
FPGA Editor
Core Generator
Speed Files
Package Files
Library
Constraints Editor
Denotes a fix new to Service Pack 4.
NGDBUILD
Xilinx Answer #6847 : 2.1i NGDBuild - msvcrt.dll conflict; ucf file size
limitations on Windows NT/95.
Xilinx Answer #7016 : 2.1i NGDBuild - Causes Dr Watson on Windows NT 4.0 SP3
at Address: 0x780125b3.
Xilinx Answer #7071 : 2.1i NGDBuild - NGDBuild ignoring drive strength
constraints attached to nets which drive IOB components (created from
constraints editor)
Xilinx Answer #7351 : 2.1i NGDBuild - TNM_NET propagation thru DLL to no
synchronous loads (two problems).
MAP
Xilinx Answer #8092 : 2.1i Virtex Map - FATAL_ERROR:xvkpu:xvkpulocal.c:246:1.3
Xilinx Answer #7709 : 2.1i Virtex Map - Map uses the incorrect JF setting for
a CLKDLLHF.
Xilinx Answer #7325 : 2.1i Virtex Map - Map creates bad .pcf constraints from
floorplanner constraints.
Xilinx Answer #7264 : 2.1i Virtex Map - exception: Access Violation
(oxc0000005), address:ox00255920.
Xilinx Answer #7364 : 2.1i Virtex Map - Mapped design results in sourceless
net leading to DRC errors.
Xilinx Answer #7728 : 2.1i Virtex Map - The default input path delay element
usage is being changed.
Xilinx Answer #7453 : 2.1i Virtex Map - Map hangs at "Reading NGD file ..."
on XCV1000 design.
Xilinx Answer #7466 : 2.1i Virtex Map - Mapper creates unroutable connection
when F6mux is driven by two F5muxes.
Xilinx Answer #7487 : 2.1i Virtex Map - FATAL_ERROR:xvkpk:xvkpkslice.c:146:1.3
0
Xilinx Answer #6319 : 2.1i 4000X* Map - Map writes bad constraint leading to
error: ERROR:OldMap:563 - Bel type "PAD" is not supported.
Xilinx Answer #7279 : 2.1i Virtex Map - Map trims inverter when FF pushed
into IOB.
Xilinx Answer #7349 : 2.1i Virtex Map - Virtex mapper treats OBUF driving PU,
PD, or
KEEPER inconsistently.
Xilinx Answer #7008 : 2.1i Virtex Map - Map may configure a BUFT driven by
PWR/GND in a way that will not work in the hardware.
Xilinx Answer #7086 : 2.1i Virtex Map/PAR - Designs combining non-RLOC'd
carry chains and macros may fail.
Xilinx Answer #6708 : 2.1i Virtex Map - ERROR:xvkpu - Unable to obey design
constraints...
Xilinx Answer #7321 : 2.1i Virtex Map - The Virtex packer is failing to
process the local output directive properly.
PAR
Xilinx Answer #8297 : 2.1i XV1000E PAR - A data file fix for XV1000E may
improve
placement results for some designs.
Xilinx Answer #7813 : 2.1i Virtex PAR - Router has difficulty connecting
Block RAM pins.
Xilinx Answer #7827 : 2.1i PAR - PAR and TRCE report different numbers for
the same routing.
Xilinx Answer #8093 : 2.1i Virtex PAR - FATAL_ERROR:Utilities:basagconjgradien
t.c:202:1.1.4.2 - CG SOLVER: residual.
Xilinx Answer #8094 : 2.1i Virtex-E PAR - Placer continues even if LVDS IO
comps have no locate constraints.
Xilinx Answer #7245 : 2.1i PAR - Application error has occured.
Exception:Access Violation (0xc0000005), Address: 0x039313b9
Xilinx Answer #7296 : 2.1i 4000XL/XV PAR - Prohibit constraint ignored.
Xilinx Answer #7372 : 2.1i Virtex PAR - PC only crash occurs after "Starting
the placer".
Xilinx Answer #7249 : 2.1i 4000XL/XV PAR - Dr Watson during routing. Access
Violation (0xc0000005), Address: 0x0024b0b1.
Xilinx Answer #7734 : 2.1i Virtex PAR - The .par results file reports
incorrect number of logic levels
Xilinx Answer #7316 : 2.1i Virtex PAR - Placer has been enhanced to use
MAXSKEW preference to assign secondary global clock buffers for external
clock nets.
Xilinx Answer #6690 : 2.1i Virtex PAR - FATAL_ERROR:Place:xvkapanal.c:1860:1.1
.2.21.2.1
Xilinx Answer #6739 : 2.1i Virtex PAR - Virtex design is taking too long to
route PWR/GND signals.
Xilinx Answer #7335 : 2.1i SpartanXL PAR - PAR fails to produce consistent
results when running a cost table twice.
Xilinx Answer #6953 : 2.1i Virtex PAR - Virtex designs with area constraints
may run out of memory during placement.
Xilinx Answer #7064 : 2.1i Virtex PAR - Router terminates with Segmentation
fault during PWR/GND routing.
Xilinx Answer #7350 : 2.1i PAR - PAR does not cleanup low-end results when
running turns engine (ignores -s)
Xilinx Answer #7345 : 2.1i Virtex PAR - Placer leaves source pin of high
fanout net unplaced, leading to router crash.
Xilinx Answer #7078 : 2.1i Virtex PAR - Placer ignores list constraint
involving IOB.
Xilinx Answer #7342 : 2.1i SpartanXL PAR - FATAL_ERROR:Route:basrtsanity.c:241
:1.1.2.2 -Process will terminate.
TIMING
Xilinx Answer #7192 : 2.1i Timing Analyzer - Bus error when launched on the
HP 10.20 platform.
Xilinx Answer #7312 : 2.1i 9500XL Timing Analyzer - Custom Report for CPLD
gives stack fault error (timingan.exe, mfc42.dll) or Process Exit Code 2.
Xilinx Answer #7448 : 2.1i Virtex Floorplanner - Crashes due to stack
overflow.
Xilinx Answer #6964 : 2.1i Virtex Timing - There are two known where back
annotated Virtex timing under reports delay.
Xilinx Answer #6965 : 2.1i 4KE/Spartan Timing - There is a known case where
back annotated xc4000e and Spartan delays are under reported.
Xilinx Answer #6825 : 2.1i Timing Analyzer - Timing Analyzer only produces a
summary report of constraints with no paths for advanced analysis.
Xilinx Answer #6959 : 2.1i TRCE/NGDBUILD/Timing Analyzer/FPGA Editor - MIN
delays & changing speed grades after implementation does not work
Xilinx Answer #7340 : 2.1i TRCE - Paths are reported against the wrong timing
constraint.
Xilinx Answer #7341 : 2.1i Virtex Speed Files - Missing Virtex pin-to-pin
timing values cause overly optimistic delays
BACK ANNOTATION
Xilinx Answer #7322 : 2.1i Virtex Ngdanno - Virtex single and dual port RAM
give setup violations for Physical Sim only.
Xilinx Answer #7331 : 2.1i - Verilog UNISIM and Cadence Concept models are
not using glbl.GSR for Block RAM
Xilinx Answer #7336 : 2.1i Virtex Ngdanno - Back annotated delay has 3.7ns
added to tristate signal on an IOB.
Xilinx Answer #6913 : 2.1i Ngdanno - INTERNAL_ERROR:AnnAx.c:2094:1.1.2.40.2.
4 - Ax::fixConfusedPins() cannot handle this configuration.
HARDWARE DEBUGGER
Xilinx Answer #7763 : 2.1i Hardware Debugger - Parallel cable doesn't
complete with Virtex chains.
BITGEN
Xilinx Answer #8244 : 2.1i Virtex Bitgen - Virtex bit file from bitgen with
default
options causes improper behavior on CLKDLL.
Xilinx Answer #7186 : 2.1i Virtex Bitgen - "WARNING:Bitgen:73 - Can't find
arc ...."
DESIGN MANAGER
Xilinx Answer #726 : 2.1i Design Manager: New behavior for UCF declaration
introduced.
Xilinx Answer #6554 : 2.1i Design Manager - Running pld_dsgnmgr through
Mentor DM or using the Design Manager option from Exemplar's P&R tab, can not
choose options for implementation.
Xilinx Answer #7328 : 2.1i Design Manager - DM Overwrite Last Version does
not work on win95/98 & WS
Xilinx Answer #6660 : 2.1i Design Manager - The server threw an exception
Xilinx Answer #7343 : 2.1i General - Help -> About Project Manager does not
display Service Pack revision information.
JTAG PROGRAMMER
Xilinx Answer #8312 : 2.1i JTAG Programmer - Virtex-E BSDL files are
available.
Xilinx Answer #8108 : 2.1i JTAG Programmer - Error: JTAG - Unable to locate
BSDL file 'c.bsd'.
Xilinx Answer #6850 : 2.1i 1800 JTAG Programmer - Is there JTAG support for
the 1800 series PROMs?
Xilinx Answer #7319 : 2.1i Virtex JTAG Programmer - Virtex configuration
requires shutdown sequence at beginning
Xilinx Answer #6764 : 2.1i JTAG Programmer - Error:JTag- The boundary-scan
'program' operation is not supported ... using SVF for the 4002xl-pq100
Xilinx Answer #7049 : 2.1i JTAG Programmer - Done does not go high when
configuring 4010XL
CPLD
Xilinx Answer #8095 : 2.1i 9500XL Hitop - Designs that fit in 1.5i do not fit
in 2.1i.
Xilinx Answer #7314 : 2.1i 9500XL Hitop - Incorrect implementation of a
<function> = VCC.
Xilinx Answer #8109 : 2.1i 9500/XL TAEngine - Program abnormally terminated.
Xilinx Answer #7760 : 2.1i Hitop - Hitop uses SLOW slew when routing internal
BUFG net through GTS pin.
Xilinx Answer #6683 : 2.1i Hitop - Fitting Report shows VCCIO pins as TIE on
XC95288XL-BG256
Xilinx Answer #7337 : 2.1i Hitop - Hitop not fitting DFF--> INV --> OBUF
correctly.
FLOORPLANNER
Xilinx Answer #6438 : 2.1i Floorplanner - Map file naming is causing problems
for the Design Manager.
FPGA EDITOR
Xilinx Answer #7329 : 2.1i FPGA Editor - ERROR:Portability:90 - Command line
error: Switch '-usedpin' is unexpected.
Xilinx Answer #7334 : 2.1i FPGA Editor - Busy cursors are not used on many
long processes.
COREGEN
Xilinx Answer #7151 : 2.1i Foundation COREGEN - "Line: 3 Wrong number of
fields BUS" on modules during symbol generation.
Xilinx Answer #6853 : 2.1i Foundation COREGEN - Unexpanded block error ...
because one or more pins on the block ... were not found.
Xilinx Answer #7397 : 2.1i Foundation COREGEN - Virtex Variable Parallel
Multiplier optional pins appear in a Foundation symbol even when not
requested.
Xilinx Answer #6890 : 2.1i Foundation COREGEN - Coregen may not be able to
locate the Foundation install directory on Windows.
SPEED FILES
Xilinx Answer #8117 : 2.1i Speed Files - There are several speed file changes
available in Service Pack 3.
Xilinx Answer #7327 : 2.1i Virtex Speed Files - New Virtex Speed files are
available in 2.1i Service Pack 1.
Xilinx Answer #7330 : 2.1i XC4000XV Speed Files - The 2.1i Service Pack 1
Update contains Preliminary XC4000XV speed data.
Xilinx Answer #7352 : 2.1i SpartanXL Speed Files - Updated speed files are
available for -5 Preliminary speed grades.
PACKAGE FILES
Xilinx Answer #8296 : 2.1i Spartan2 Package Files - The TQ144 Package has
been
added for Spartan2.
Xilinx Answer #8298 :2.1i Virtex-E Packages - The XV600E FG900 and XV1000E
FG1156 packages have bad banking information.
Xilinx Answer #8118 : 2.1i Spartan2 Package Files - New package files are
available with Service Pack 4.
Xilinx Answer #7736 : 2.1i Package Files - Incorrect location for Spartan40XL
BG256 DONE pin specified in the pad report.
Xilinx Answer #7326 : 2.1i SpartanXL - The CS280 packages are missing in
M2.1i
Xilinx Answer #7185 : 2.1i Package Files - The 40150xv BG432 package is
incorrect.
LIBRARY
Xilinx Answer #1825 : 2.1i UNISIMS/SIMPRIMS - CLKDLL doesn't lock after RST
is de-asserted.
Xilinx Answer #7470 : 2.1i XSI Library - Bidirectional I/O has extra
inversion inferred (IOBUF_N).
Xilinx Answer #6588 : Synopsys FPGA Compiler 1998.08/1999.05 - Slew rate
specifications on Virtex IOBs are ignored during synthesis.
CONSTRAINTS EDITOR
Xilinx Answer #7235 : 2.1i Constraints Editor - Spartan 20 PQ208 Prohibit IO
locations for configuration pins are incorrect.
Xilinx Answer #7050 : 2.1i Constraints Editor - Constraint_editor.exe: An
application error has occured.
