共1条
当今用于无线(UHF)传输等IC的特点
A good example of what you can get today is the Micrel MICRF
receiver family, which comprises 418- to 433-MHz- and 900-MHz-band
devices. The lower band, 16-pin MICRF002 and eight-pin MICRF022 and
higher band, but otherwise similar, 16-pin MICRF003 and eight-pin
MICRF033 use an architecture that eliminates the need for manual
tuning of each unit (Figure 1). These superhet receivers, which
target on/off keying, or amplitude shift keying (ASK), require few
external components: a 47-nF capacitor, a 4.7-μF capacitor, and an
inexpensive, 6- to 7-MHz ceramic resonator. These ICs need no
filters or inductors.
The higher frequency, $4.50 (1000) MICRF003/033 supports data rates
as fast as 20 kbps, and you provide the data from a CMOS-logic
interface. The IC consumes 4 mA from a 5V supply in normal operation
and one-hundredth of that value in shutdown mode. You can set the
receiver to periodically wake up and check for incoming signals;
this duty-cycle-oriented operation results in an overall dissipation
that is near the shutdown value.
Texas Instruments recently introduced its TRF6900 transceiver for
850- to 950-MHz operation and the associated MSP430 ultra-low-power,
16-bit μC for burst-mode operation and low power consumption. The
fairly complex 48-pin transceiver supports FM, FSK, on/off keying,
and ASK operation and produces as much as 6-dBm output power from a
2.2 to 3.6V supply. Within this IC is a channel-hopping, 24-bit,
direct-digital synthesizer with an 11-bit DAC and 230-Hz resolution;
a reference oscillator and a VCO; a
received-signal-strength-indicator (RSSI) block; and a serial
interface to the μC.
The IC lets you send data as fast as 200 kbps, and you can
selectively turn its internal blocks on and off to minimize power
consumption. To facilitate this technique, the blocks within the IC
turn on and off within 500 msec, and you can get standby power
consumption as low as microamps. Along with the detailed data sheet,
TI offers application notes, μC- and PC-based software, a reference
design, a bill of materials, and RF-layout files. To complete your
RF portion of the design, you need a UHF filter, an IF filter, and a
crystal, plus a few resistors, capacitors, and inductors, which cost
$1 to $5, depending on the application.
Mitel is extending its transmitter and receiver line with ICs such
as the KESRX05, a PLL-controlled receiver upgrade of its older
KESRX04 unit, which locks to a reference crystal via an internal
divide-by-64 prescaler. This 260- to 470-MHz receiver uses ASK
modulation and allows data rates as fast as 100 kbps, although the
typical data rate is less than 5 kbps. Sensitivity of the receiver
is -106 to -109 dBm at 433 MHz at a 2-kbps data rate and 50% duty
cycle.
Mitel has also redesigned the receiver with an antijamming circuit
that rejects adjacent-channel interference at 433.92 MHz, such as
that from nearby amateur-radio repeater signals. This feature lets
you use a low-cost LC front-end filter instead of a slightly more
costly SAW filter. The redesigned receiver also extends the
operating temperature from 85°C for its predecessor to 105°C; this
extension is an important factor in many practical installations in
which ambient temperature plus impinging sunlight can push the IC
temperature quite high.
Infineon Technologies (formerly, Siemens Components) is also
extending its 400-MHz products to the higher bands. The company
offers the TDA5100 ASK/FSK transmitter for both the 868- to 870-MHz
and the 433- to 435-MHz bands and the complementary TDA5200 ASK
superhet receiver for European markets. Infineon also offers the
similar TDA5101 and TDA5251, which target the US market, for the
315- to 345-MHz band.
The transmitter is a 16-pin TSSOP IC that costs $1.50 (50,000) and
operates from a 2.1 to 4V supply. It integrates a VCO, PLL, crystal
oscillator, supply-rail regulator, and power amplifier. You use the
transmitter with a μC operating from the same clock crystal as the
transmitter. The receiver uses a 5V supply and includes a VCO, a
PLL, a limiter, filters, and a data comparator; the receiver's
sensitivity is 1 μV. The 85-cent (50,000) IC comes in a 28-pin
TSSOP.
Motorola offers some wideband ICs that you can use, along with a
baseband signal processor, for your RF channel. The company's
MC13146 dc to 1.8-GHz transmitter pumps 10-dBm output at a 1-dB
compression point. It includes a linear mixer, VCO, dual-modulus
prescaler, and power amplifier. Operating voltage is 2.7 to 6.5V,
with current drain of less than 25 mA at 1.8 GHz; in power-down
mode, consumption drops to 60 μA. The matching MC13145 receiver has
a low-noise amplifier, two mixers, a VCO, a dual-modulus prescaler,
an IF amplifier and limiter, an RSSI circuit, and an inductorless
FM/FSK demodulator. The transmitter is available as a 24-pin LQFP
device; the receiver is a 48-pin LQFP IC.
A transceiver IC from Chipcon Components AS is noteworthy because of
its relatively high output power and consequent range. The CC400 FSK
for 300- to 500-MHz ISM applications provides 9.6-kbps, half-duplex
operation to 2000m (Figure 2). The output-power range spans -5 to
+14 dBm, which you can program in 1-dB steps; receiver sensitivity
is -112 dBm at 1.2 kbps and a 10-3 BER. The 28-pin SSOP IC operates
from a 2.7 to 3.3V supply with current requirements of 18 mA with
the receiver on full-time and 180-μA average operating current using
receiver polling. The vendor also supplies a development kit that
includes PC-configurable radio modules, cables and connectors, and
PC-based software.
RF Micro Devices recently introduced a spread-spectrum transmitter-
and receiver-IC pair for the 902- to 928-MHz ISM band. The RF2908
includes a double-conversion receiver, a quadrature modulator, dual
IF amplifiers, filters, data comparators, and a PLL synthesizer.
This 68-pin LQFP IC costs $5.25 (10,000). The matching RF2909
supports direct modulation control, and you can set the output-power
level of this 24-pin SSOP from 1 to 80 mW; it costs $2.35 (10,000).
Also for 900-MHz use, Level One has the LXT 810, a 32-ksps
spread-spectrum transceiver with 100m range (1 to 100 mW output),
and which needs no tuning, adjustments, or filters. A complete
design with this IC uses under 30 discrete components.
If you can consider hybrids instead of just ICs, you'll find that
vendors such as RF Monolithics offer some devices that are only
slightly larger than a packaged IC yet reduce your design challenge
to absolute simplicity. The product line includes transmitters,
receivers, and transceivers for 433- and 916-MHz operation and is
certified for use in different regions of the world, depending on
the model. For example, the company's $15.20 (1000) 3V RX6000
amplifier-sequenced-hybrid (ASH) receiver supports data rates to
115.2 kbps using an architecture with a wide-dynamic-range
logarithmic detector, a data slicer, digital AGC, two stages of SAW
filtering for out-of-band rejection, and stability with almost any
antenna impedance (Figure 3).
This stability factor is especially important in many RF-link
applications, because the actual impedance of an antenna changes as
its orientation and proximity to nearby conducting surfaces vary.
The ASH-receiver design maximizes the channel-capture effect,
whereby the strongest signal in the RF field dominates and fully
captures the receiver. Meanwhile, the receiver ignores undesirable,
weaker signals, which thereby do not degrade demodulation BER
performance. (Although these characteristics may seem
Darwinian-reflecting the laws of the RF jungle-they make for a good
link!) The material in Reference 1 provides an informative
discussion of the unique ASH architecture and its features as well
as the many critical design and application issues beyond the
vendor's parts.
You can soon expect a full-duplex transceiver IC, which operates
from 220 to 928 MHz, from Philsar Electronics. This multipurpose RF
device in a 32-pin SSOP supports data rates to 10 kbps and includes
a PLL, VCO, and crystal oscillator, among other key functions. It
requires approximately 10 noncritical external passive components
and uses an active-filter tuning design for maximum performance. The
3V IC requires 2.5 mA in receiving mode (1 μA in standby) and 6 mA
in transmitting mode and produces an RF-output level of -12 dBm with
-115-dBm sensitivity at 1k sample/sec.
Moving to the 2.4-GHz ISM band, National Semiconductor has the
LMX3162 transceiver, which gives you an entry point for home and
small-office LANs (Figure 4). The receiver within has -93-dBm RF
sensitivity and RSSI sensitivity to -100 dBm. An 85-db-gain IF strip
follows this front end; the front end's system-noise figure is 6.5
dB. You can operate this 48-pin IC from an unregulated 3 to 5.5V
supply.
Within the $5.60 (1000) single-conversion transceiver are a 1.3-GHz
PLL that both the transmitting and the receiving functions share, a
2.4-GHz frequency doubler, a low-noise amplifier, buffers, a mixer,
the associated receiving-channel functions, and the basic
transmitting-signal path. Working with a system-integrator partner,
RTX Telecom A/S, National Semiconductor also provides you with
reference designs that include schematics, layouts, software, and
documentation.
Also for 2.4 GHz, Digital Wireless has a complete modem with 100-mW
output power that comes on a 9-mm-thick housing that measures less
than 46X80 cm (Figure 5). The WIT2410 3.3V modem supports data rates
to 115 kbps as a frequency-hopping, spread-spectrum unit.
Whichever vendors you look at, be sure to assess how complete their
ICs are, because completeness, like beauty, is in the eye of the
beholder. Now, vendors with devices that are "even more complete"
are replacing some RF ICs that manufacturers last year touted as
"complete"-something of a contradiction! Completeness really
indicates how many and what type of passive and active components
you need to add to the IC to finish the design.
关键词: 当今 用于 无线 传输 特点 receiver
共1条
