How to integrate the snmp agent to VxWorks?(老站转)
cocoyang
来自:
发表总数:10
查看 短消息 电子邮件
I move INCLUDE_SNMPD to INCLUDED FACILITIES section of configAll.h,
when I rebuild the VxWorks,the error displays as follows:
partialImage.o(.text+0x220fc):fake: undefined reference to `snmpIoMain'
partialImage.o(.text+0x221bc):fake: undefined reference to `Process_Rcvd_SNMP_Packet_Async
partialImage.o(.text+0x22234):fake: undefined reference to `SNMP_Process_Finish'
partialImage.o(.text+0x22254):fake: undefined reference to `snmpIoWrite'
partialImage.o(.text+0x2225c):fake: undefined reference to `EBufferClean'
partialImage.o(.text+0x22280):fake: undefined reference to `snmpIoClose'
partialImage.o(.text+0x22318):fake: undefined reference to `SNMP_CoarseLock'
partialImage.o(.text+0x2235c):fake: undefined reference to `envoy_init'
partialImage.o(.text+0x22394):fake: undefined reference to `SNMP_CoarseLock'
partialImage.o(.text+0x2240c):fake: undefined reference to `SNMP_View_Create'
partialImage.o(.text+0x22440):fake: undefined reference to `SNMP_View_Install'
partialImage.o(.text+0x2248c):fake: undefined reference to `SNMP_View_Set_Mask'
partialImage.o(.text+0x224d4):fake: undefined reference to `SNMP_CoarseLock'
partialImage.o(.text+0x224f4):fake: undefined reference to `SNMP_View_Next'
partialImage.o(.text+0x22510):fake: undefined reference to `SNMP_View_Deinstall'
partialImage.o(.text+0x22540):fake: undefined reference to `SNMP_View_Delete'
partialImage.o(.text+0x2258c):fake: undefined reference to `SNMP_View_Lookup'
partialImage.o(.text+0x225c0):fake: undefined reference to `SNMP_View_Deinstall'
partialImage.o(.text+0x225f0):fake: undefined reference to `SNMP_View_Delete'
partialImage.o(.text+0x22604):fake: undefined reference to `SNMP_CoarseLock'
partialImage.o(.text+0x22664):fake: undefined reference to `Add_Node_From_Root'
partialImage.o(.text+0x226b8):fake: undefined reference to `SNMP_CoarseLock'
partialImage.o(.text+0x22708):fake: undefined reference to `Remove_Node_From_Root'
partialImage.o(.text+0x22730):fake: undefined reference to `SNMP_CoarseLock'
partialImage.o(.text+0x227d8):fake: undefined reference to `SNMP_Create_Trap'
partialImage.o(.text+0x22840):fake: undefined reference to `SNMP_Create_Request2'
partialImage.o(.text+0x228b0):fake: undefined reference to `SNMP_Encode_Packet'
partialImage.o(.text+0x228dc):fake: undefined reference to `SNMP_Free'
partialImage.o(.text+0x228e8):fake: undefined reference to `SNMP_Free'
partialImage.o(.text+0x22920):fake: undefined reference to `snmpIoWrite'
partialImage.o(.text+0x22938):fake: undefined reference to `EBufferClean'
partialImage.o(.text+0x229e8):fake: undefined reference to `snmpIoTrapSend'
partialImage.o(.text+0x22b18):fake: undefined reference to `nextproc_no_next'
partialImage.o(.text+0x22b2c):fake: undefined reference to `nextproc_error'
partialImage.o(.text+0x22b50):fake: undefined reference to `snmpdMemoryFree'
partialImage.o(.text+0x22b70):fake: undefined reference to `oid_to_ip'
partialImage.o(.text+0x22c84):fake: undefined reference to `snmpIoTrapSend'
partialImage.o(.text+0x22cb4):fake: undefined reference to `snmpIoClose'
partialImage.o(.text+0x60608):fake: undefined reference to `snmpdGroupByGetprocAndInstance
partialImage.o(.text+0x60630):fake: undefined reference to `getproc_nosuchins'
partialImage.o(.text+0x607bc):fake: undefined reference to `getproc_got_uint32'
partialImage.o(.text+0x607d0):fake: undefined reference to `getproc_got_int32'
partialImage.o(.text+0x607e4):fake: undefined reference to `getproc_error'
partialImage.o(.text+0x60820):fake: undefined reference to `setproc_good'
partialImage.o(.text+0x6085c):fake: undefined reference to `testproc_error'
partialImage.o(.text+0x6087c):fake: undefined reference to `testproc_good'
partialImage.o(.data+0xb2c):fake: undefined reference to `SNMP_Bind_Null'
partialImage.o(.data+0xb30):fake: undefined reference to `SNMP_Bind_64_Unsigned_Integer'
partialImage.o(.data+0xb34):fake: undefined reference to `SNMP_Bind_String'
partialImage.o(.data+0xb38):fake: undefined reference to `SNMP_Bind_Object_ID'
partialImage.o(.data+0xb3c):fake: undefined reference to `SNMP_Bind_IP_Address'
partialImage.o(.data+0xb40):fake: undefined reference to `SNMP_Bind_Integer'
partialImage.o(.data+0xb44):fake: undefined reference to `SNMP_Bind_Unsigned_Integer'
make: *** [vxWorks] Error 0x1
I don't know how to remove these errors,can you help me?
Thank you!
编辑 发表於:2002-01-14 - 09:36:22 IP: 202.119.*.*
cliff
助理工程师
来自:
发表总数:6
查看 短消息 电子邮件
这些错误的原因是 vxworks 原来的 snmp 模块没有链接到库中,
可以手工将模块加入库 libPPC860gnuvx.a 中,(名字与你选择的
目标平台 (PPC860) 和编译器 (gnu)有关):
1.设置 tornado 环境: \Tornado\host\x86-win32\bin\torVars.bat
2.进入 \Tornado\target\src\snmpv1\agent
你可以打开 makefile 来看看
make clean CPU=PPC860
make CPU=PPC860
这样就都加到 libPPC860gnuvx.a 中了,另外可以手工加入:
arppc crus \Tornado\target\lib\libPPC860gnuvx.a snmpdLib.o snmpIoLib.o \
snmpIcmp.o snmpIp.o snmpMib2.o snmpSnmp.o snmpSystem.o snmpTcp.o snmpUdp.o \
subagentLib.o
(上面的命令是一行来的)
然后你再编译自己的文件就可以找到那些函数了
编辑 发表於:2002-01-14 - 17:57:22 IP: 202.104.*.*
embedfree
高级工程师
来自:
发表总数:142
查看 短消息 电子邮件
在PROJECT的管理工具中, INCLUDE SNMP的组件难道系统不会自动来加入所有相关的
文件吗?
在TORNADO的使用过程中,自动配置工具不能完全完成所有我们需要的功能吗?
谢谢!
宠辱不惊,
看庭前花开花落;
去留无意,
任天上云卷云舒
编辑 发表於:2002-01-15 - 08:59:27 IP: 211.99.*.*
cliff
助理工程师
来自:
发表总数:6
查看 短消息 电子邮件
libPPC860gnuvx.a 是在安装 Tornado 的时候编译的吧,
之后使用过程中加入的项目只是将 libPPC860gnuvx.a 链接
到你的项目中。
在 Project 的管理工具选择了 SNMP 组件,最直接的作用是
在你的Project 中打开了 SNMP 这个宏的开关,好像是
INCLUDE_SNMP之类的,同时 snmpd 任务也激活,于是你
就可以使用该组件了,至于组件本来的库文件,Tornado认为
你本来就已经配置好了。
像你这种情况,会不会是安装过程中出错了?
编辑 发表於:2002-01-15 - 10:28:10 IP: 202.104.*.*
cocoyang
来自:
发表总数:10
查看 短消息 电子邮件
cliff,
您讲的1,2 步我都已经做过
但是当重新build vxWorks时就出现了我所讲的错误,我不知道为什么,难道是我的tornado 有问题?
编辑 发表於:2002-01-15 - 14:06:32 IP: 202.119.*.*
yuefc
来自:
发表总数:25
查看 短消息 电子邮件
你有可能没有安装SNMP组件,好像应该单买!
关键词: integrate agent VxWorks 老
vxWorks 中snmp agent 的开发
cocoyang
来自:
发表总数:10
查看 短消息 电子邮件
现在的MIB已经经过mib compiler,接下去我该如何修改Method routine
如何激活snmp agent .
请各位不吝赐教
谢谢!
编辑 发表於:2002-01-09 - 09:18:22 IP: 202.119.*.*
小华
高级工程师
来自:
发表总数:102
查看 短消息 电子邮件
Use "mibcomp" generate the .c files. Fill your function to the .c files.
Make it!
________________________________________________
You can find this in detail in SNMP online manual
__________________________________________________
编辑 发表於:2002-01-09 - 17:43:25 IP: 61.177.*.*
cocoyang
来自:
发表总数:10
查看 短消息 电子邮件
When I type the following line in command line
cd tornado\target\src\snmpv1\agent> make
The screen display "make is not a internal or external command ,nor a program"
How can I to use make?
Thanks a lot!
编辑 发表於:2002-01-10 - 10:25:28 IP: 61.177.*.*
amine
版主
来自:
发表总数:519
查看 短消息 电子邮件
可能你的执行环境变量path未设置.
| OrangePiZero2W系统被打赏¥33元 | |
