有大虾做过ucosII上移植lwip吗?我的环境是S3C44B0,编译器器为ADS
看过skyeye项目杨晔大侠在gcc环境下的移植代码,我定义的cc.h文件为
typedef unsigned char u8_t;
typedef signed char s8_t;
typedef unsigned short u16_t;
typedef signed short s16_t;
typedef unsigned int u32_t;
typedef signed int s32_t;
#define PACK_STRUCT_FIELD(x) x
#define PACK_STRUCT_STRUCT
#define PACK_STRUCT_BEGIN __packed
#define PACK_STRUCT_END
一旦编译以后,就提示:type disagreement for "OS_EVENT" ucos_ii.h,不光是OS_EVENT结构,几乎所有ucos_ii.h中的定义的结构都是报同样的错误,请大家给与一点指点,我现在是束手无策了。
