共1条
ISA Bus Technical Summary(1)
Table of Contents
1.0 ISA Overview
2.0 ISA Documents
2.1 ISA Specifications
2.2 ISA Books
3.0 ISA Signal Descriptions
4.0 ISA Timing Diagrams
5.0 ISA Signal Usage
6.0 ISA Connector Pinout
1.0 ISA Overview
The Industry Standard Architecture, or ISA, bus originated in the early 1980s at an IBM development lab in Boca Raton, Florida. The original IBM Personal Computer introduced in 1981 included the 8-bit subset of the ISA bus. In 1984, IBM introduced the
PC-AT which was the first full 16-bit implementation of the ISA bus.
The "AT bus", as IBM originally called it, was first documented in an IBM publication called the PC-AT Technical Reference. The Technical Reference included schematics and BIOS listings that made it easy for other companies like Compaq to produce IBM
compatible clones. The companies producing IBM compatibles could not use the "AT bus" name however since IBM had protected it with a trademark. In response, the industry coined "ISA" as a new name for the bus that was eventually adopted by everyone
including IBM.
Although the PC-AT Technical Reference included detailed schematics and BIOS listings, it did not include the rigorous timings, rules, and other requirements that would make it a good bus specification. As a result, the various implementations of ISA
were not always compatible with each other. Over time various ISA bus specifications were produced in an attempt to alleviate the compatibility problems. But unfortunately these specifications did not always agree with each other, so no single
specification for the ISA bus was ever developed.
2.0 ISA Documents
Several documents that include specifications for the ISA bus are as follows:
EISA Specification, Version 3.12 - This document includes specifications for ISA as well as the "Extended Industry Standard Architecture" that defined a 32-bit extension to the ISA bus. At last check, this document could be ordered for a fee from
Global Engineering Services.
IEEE Draft Standard P996 - This document describes the mechanical and electrical specifications for standard PC-style systems. At last check it could be ordered for a fee from IEEE at http://standards.ieee.org/.
PS/2 Technical Reference - AT Bus Systems - This document from IBM includes signal definitions and timing diagrams for the ISA bus used in some of IBM's PS/2 line of computers. At last check it could be ordered for a fee from IBM at
http://www.ibmlink.ibm.com. Search IBM's PubCatalog for document number S85F-1646.
2.2 ISA Books
Two books that provide good descriptions of the ISA bus are:
ISA & EISA Theory and Operation, by Edward Solari. (Annabooks) (ISBN 0-929392-15-9)
ISA System Architecture, by Don Anderson and Tom Shanley (MindShare) (ISBN 0-201-40996-8)
SA19 to SA0
System Address bits 19:0 are used to address memory and I/O devices within the system. These signals may be used along with LA23 to LA17 to address up to 16 megabytes of memory. Only the lower 16 bits are used during I/O operations to address up to 64K
I/O locations. SA19 is the most significant bit. SA0 is the least significant bit. These signals are gated on the system bus when BALE is high and are latched on the falling edge of BALE. They remain valid throughout a read or write command. These
signals are normally driven by the system microprocessor or DMA controller, but may also be driven by a bus master on an ISA board that takes ownership of the bus.
LA23 to LA17
Unlatched Address bits 23:17 are used to address memory within the system. They are used along with SA19 to SA0 to address up to 16 megabytes of memory. These signals are valid when BALE is high. They are "unlatched" and do not stay valid for the
entire bus cycle. Decodes of these signals should be latched on the falling edge of BALE.
AEN
Address Enable is used to degate the system microprocessor and other devices from the bus during DMA transfers. When this signal is active the system DMA controller has control of the address, data, and read/write signals. This signal should be
included as part of ISA board select decodes to prevent incorrect board selects during DMA cycles.
BALE
Buffered Address Latch Enable is used to latch the LA23 to LA17 signals or decodes of these signals. Addresses are latched on the falling edge of BALE. It is forced high during DMA cycles. When used with AEN, it indicates a valid microprocessor or DMA
address.
CLK
System Clock is a freerunning clock typically in the 8MHz to 10MHz range, although its exact frequency is not guaranteed. It is used in some ISA board applications to allow synchronization with the system microprocessor.
SD15 to SD0
System Data serves as the data bus bits for devices on the ISA bus. SD15 is the most significant bit. SD0 is the least significant bits. SD7 to SD0 are used for transfer of data with 8-bit devices. SD15 to SD0 are used for transfer of data with 16-bit
devices. 16-bit devices transferring data with 8-bit devices shall convert the transfer into two 8-bit cycles using SD7 to SD0.
-DACK0 to -DACK3 and -DACK5 to -DACK7
DMA Acknowledge 0 to 3 and 5 to 7 are used to acknowledge DMA requests on DRQ0 to DRQ3 and DRQ5 to DRQ7.
DMA Requests are used by ISA boards to request service from the system DMA controller or to request ownership of the bus as a bus master device. These signals may be asserted asynchronously. The requesting device must hold the request signal active
until the system board asserts the corresponding DACK signal.
-I/O CH CK
I/O Channel Check signal may be activated by ISA boards to request than an non-maskable interrupt (NMI) be generated to the system microprocessor. It is driven active to indicate a uncorrectable error has been detected.
I/O CH RDY
I/O Channel Ready allow slower ISA boards to lengthen I/O or memory cycles by inserting wait states. This signals normal state is active high (ready). ISA boards drive the signal inactive low (not ready) to insert wait states. Devices using this signal
to insert wait states should drive it low immediately after detecting a valid address decode and an active read or write command. The signal is release high when the device is ready to complete the cycle.
-IOR
I/O Read is driven by the owner of the bus and instructs the selected I/O device to drive read data onto the data bus.
-IOW
I/O Write is driven by the owner of the bus and instructs the selected I/O device to capture the write data on the data bus.
IRQ3 to IRQ7 and IRQ9 to IRQ12 and IRQ14 to IRQ15
Interrupt Requests are used to signal the system microprocessor that an ISA board requires attention. An interrupt request is generated when an IRQ line is raised from low to high. The line must be held high until the microprocessor acknowledges the
request through its interrupt service routine. These signals are prioritized with IRQ9 to IRQ12 and IRQ14 to IRQ15 having the highest priority (IRQ9 is the highest) and IRQ3 to IRQ 7 have the lowest priority (IRQ7 is the lowest).
-SMEMR
System Memory Read instructs a selected memory device to drive data onto the data bus. It is active only when the memory decode is within the low 1 megabyte of memory space. SMEMR is derived from MEMR and a decode of the low 1 megabyte of memory.
-SMEMW
System Memory Write instructs a selected memory device to store the data currently on the data bus. It is active only when the memory decode is within the low 1 megabyte of memory space. SMEMW is derived from MEMW and a decode of the low 1 megabyte of
memory.
-MEMR
Memory Read instructs a selected memory device to drive data onto the data bus. It is active on all memory read cycles.
-MEMW
Memory Write instructs a selected memory device to store the data currently on the data bus. It is active on all memory write cycles.
-REFRESH
Memory Refresh is driven low to indicate a memory refresh operation is in progress.
OSC
Oscillator is a clock with a 70ns period (14.31818 MHz). This signal is not synchronous with the system clock (CLK).
RESET DRV
Reset Drive is driven high to reset or initialize system logic upon power up or subsequent system reset.
TC
Terminal Count provides a pulse to signal a terminal count has been reached on a DMA channel operation.
-MASTER
Master is used by an ISA board along with a DRQ line to gain ownership of the ISA bus. Upon receiving a -DACK a device can pull -MASTER low which will allow it to control the system address, data, and control lines. After -MASTER is low, the device
should wait one CLK period before driving the address and data lines, and two clock periods before issuing a read or write command.
-MEM CS16
Memory Chip Select 16 is driven low by a memory slave device to indicate it is capable of performing a 16-bit memory data transfer. This signal is driven from a decode of the LA23 to LA17 address lines.
-I/O CS16
I/O Chip Select 16 is driven low by a I/O slave device to indicate it is capable of performing a 16-bit I/O data transfer. This signal is driven from a decode of the SA15 to SA0 address lines.
-0WS
Zero Wait State is driven low by a bus slave device to indicate it is capable of performing a bus cycle without inserting any additional wait states. To perform a 16-bit memory cycle without wait states, -0WS is derived from an address decode.
-SBHE
System Byte High Enable is driven low to indicate a transfer of data on the high half of the data bus (D15 to D8).
关键词: Technical Summary signal
共1条
硬核工程师专属补给计划——填盲盒 | |
“我踩过的那些坑”主题活动——第002期 | |
【EEPW电子工程师创研计划】技术变现通道已开启~ | |
【EEPW在线】E起听工程师的声音! | |
高校联络员开始招募啦!有惊喜!! | |
送您一块开发板,2025年“我要开发板活动”又开始了! |
