共1条
ISA Bus Technical Summary(3)
5.0 ISA Signal Usage
Legend:
I/O = Input and Output
I = Input
O = Output
- = Signal not needed
An I/O shown in parentheses () indicates that the signal is
optional for this devices.
The following table indicates typical signal usage by an ISA system board:
Signal Name System Board Usage Signal Name System Board Usage
AEN O -MEM CS16 I/O
BALE O -MEMR I/O
CLK O -MEMW I/O
-DACK O OSC O
DRQ I -REFRESH I/O
-IO CS16 I RESET DRV O
-I/O CH CK I SA I/O
I/O CH RDY I/O SD I/O
-IOR I/O -SBHE I/O
-IOW I/O -SMEMR I/O
IRQ I -SMEMW I/O
LA I/O TC I/O
-MASTER I -0WS I
The following table indicates typical signal usage by the various types of ISA expansion boards:
Signal Name ISA Bus Master ISA 16-bit Mem Slave ISA 16-bit I/O Slave ISA 8-bit Mem Slave ISA 8-bit I/O Slave ISA DMA Device
AEN - - I - I -
BALE - I - (I) - -
CLK (I) (I) (I) (I) (I) (I)
-DACK I - - - - I
DRQ O - - - - O
-IO CS16 I - O - - -
-I/O CH CK (O) (O) (O) (O) (O) (O)
I/O CH RDY I (O) (O) (O) (O) -
-IOR O - I - I I
-IOW O - I - I I
IRQ (O) (O) (O) (O) (O) (O)
LA(23:17) O I - (I) - -
-MASTER O - - - - -
-MEM CS16 I 0 - - - -
-MEMR O I - (I) - -
-MEMW O I - (I) - -
OSC (I) (I) (I) (I) (I) (I)
-REFRESH (O) I - I - -
RESET DRV I I I I I I
SA(16:0) O I I I I -
SA(19:17) - (I) - (I) - -
SD(7:0) I/O I/O I/O I/O I/O I/O
SD(15:8) I/O I/O I/O - - (I/O)
-SBHE O I I - - -
-SMEMR - - - I - -
-SMEMW - - - I - -
TC - - - - - (I)
-0WS - (O) - (O) (O) -
6.0 ISA Connector Pinout
Signal Name Pin Pin Signal Name
Ground B1 A1 -I/O CH CK
RESET DRV B2 A2 SD7
+5 V dc B3 A3 SD6
IRQ 9 B4 A4 SD5
-5 V dc B5 A5 SD4
DRQ2 B6 A6 SD3
-12 V dc B7 A7 SD2
-0WS B8 A8 SD1
+12 V dc B9 A9 SD0
Ground B10 A10 I/O CH RDY
-SMEMW B11 A11 AEN
-SMEMR B12 A12 SA19
-IOW B13 A13 SA18
-IOR B14 A14 SA17
-DACK3 B15 A15 SA16
DRQ3 B16 A16 SA15
-DACK1 B17 A17 SA14
DRQ1 B18 A18 SA13
-REFRESH B19 A19 SA12
CLK B20 A20 SA11
IRQ7 B21 A21 SA10
IRQ6 B22 A22 SA9
IRQ5 B23 A23 SA8
IRQ4 B24 A24 SA7
IRQ3 B25 A25 SA6
-DACK2 B26 A26 SA5
TC B27 A27 SA4
BALE B28 A28 SA3
+5 V dc B29 A29 SA2
OSC B30 A30 SA1
Ground B31 A31 SA0
Key
-MEM CS16 D1 C1 -SBHE
-IO CS16 D2 C2 LA23
IRQ10 D3 C3 LA22
IRQ11 D4 C4 LA21
IRQ12 D5 C5 LA20
IRQ15 D6 C6 LA19
IRQ14 D7 C7 LA18
-DACK0 D8 C8 LA17
DRQ0 D9 C9 -MEMR
-DACK5 D10 C10 -MEMW
DRQ5 D11 C11 SD08
-DACK6 D12 C12 SD09
DRQ6 D13 C13 SD10
-DACK7 D14 C14 SD11
DRQ7 D15 C15 SD12
+5 V dc D16 C16 SD13
-MASTER D17 C17 SD14
Ground D18 C18 SD15
Copyright ? 1999-2002 TechFest.com. All Rights Reserved.
关键词: Technical Summary
共1条
硬核工程师专属补给计划——填盲盒 | |
“我踩过的那些坑”主题活动——第002期 | |
【EEPW电子工程师创研计划】技术变现通道已开启~ | |
【EEPW在线】E起听工程师的声音! | |
高校联络员开始招募啦!有惊喜!! | |
送您一块开发板,2025年“我要开发板活动”又开始了! |
