我配置了BootLoader VIVI 的Makefile 文件,把编译路径cross-compile设为宿主机的/usr/local/arm/2.95.3/bin/arm-linux- 把linux-include -dir设为/usr/local/arm/2.95.3/include
然后make menuconfig9(通过)
接着make vivi
出现如下编译错误:
[root@localhost vivi]# make vivi
/usr/local/arm/2.95.3/bin/arm-linux-gcc -I/usr/src/net xiazai yuan ma/vivi/inclu
de -I/usr/local/arm/2.95.3/include -Wall -Wstrict-prototypes -O2 -fPIC -fomit-fr
ame-pointer -mapcs-32 -mshort-load-bytes -msoft-float -c -o init/main.o init
/main.c
arm-linux-gcc: cannot specify -o with -c or -S and multiple compilations
make: *** [init/main.o] Error 1
这是怎么回事啊?是arm-linux-gcc缺少相关的东西吗?
请高手指点!!!
