共3条
电子通讯计算机专业--最佳工作机会(shanghai)-更新后
只看楼主 1楼
大型美资企业,坐落于张江高科技园区,待遇丰厚,敬请关注。
职位列表:
VP of Engineering
Manufacturing Manager
Engineers-System
Engineers-Real Time Embedded SW
Engineering Manager-HW
Engineers-Element Management SW
Engineers-ASIC/FPGA
Engineers-Hardware
Engineers-DFT
Engineers-System Automation
Engineers-System Test
招聘职位
Engineering-System Test
发布日期:2005-05-27 工作地点:上海市
招聘人数:若干 学 历:本科
薪水范围:面议 接受简历语言:中文或英文
职位描述:
Description:
Create, design, and execute test cases . Job entails analyzing functional and systems
requirements documents, writing test cases, reviewing test cases, executing test cases,
participating in test reviews, operating a variety of test equipment, posting results, tracking
test progress, opening problem reports, verifying fixed problem reports, working with
engineering development to debug defects, assisting customer service, and interacting with
SYSTEM TEST team members constructively. Strong knowledge of Ethernet and SDH/SONET
hardware/software integration is a plus.
Preferred Experience:
Previous telecommunications equipment testing experience
Strong knowledge of 10/100/1000 Ethernet and accompanying test equipment
Understanding of PPP, TCP/IP protocols (OSPF, MPLS)
Conformance testing for OSPF, RSTP, STP, VLANs and GVRP a plus
Understanding of PC and UNIX operating systems
Telecom protocol knowledge in SONET, DS3, T1
Working experience with Smartbits, Adtech, Agilent, and Acterna test sets
Able to work in a team environment
Able to work flexible hours depending on test set resources
Must have better than average English verbal and written skills
Engineering-Hardware Design and Development
招聘人数:若干 学 历:本科
工作年限:二年以上 薪水范围:面议
接受简历语言:中文或英文
职位描述:
Description:
Candidates will have a minimum of two years of experience in the design and development of
high-speed digital electrical design of complex circuit packs. He/she should be familiar with
CAD design systems, preferably Cadence, for schematic capture, signal analysis, and PCB layout
Candidates will be responsible for independently taking portions of a subsystem all the way
from design to implementation and test. This will require technical strength and the ability to
interact with the team to insure other subsystem parts are integrated with the overall system.
Candidates will require excellent communications skills in Mandarin and basic communication
skills in English to be able to translate system requirements to actual hardware design and to
effectively understand, debug and correct problems faced by the teams in China and the USA.
Candidates will require knowledge of standard hardware development processes and methodologies,
and have a high commitment to hardware quality. Hands-on experience with embedded processors
and exposure to developing and debugging hardware/software is required as well as exposure to
use of emulators, BDM's, logic-analyzers, etc.
A bachelor's or master's degree in electrical or computer engineering is required, with
experience in PowerPC, SONET, EoS, DS3, and DS1 standards highly desired.
招聘职位
Systems Engineering
招聘人数:若干 学 历:本科
工作年限:二年以上 薪水范围:面议
接受简历语言:中文和英文
职位描述:
Description:
Candidates must have a minimum of two years of experience working with telecommunications
systems, architectures, and services. Each candidate must possess a thorough understanding of
one or more of the following; Ethernet, Ethernet-Over-SONET, PPP, IP, TCP, routing, TL-1, or
SNMP.
Candidates must have excellent communications skills in Mandarin and average communication
skills in English to be able to define and specify system-level requirements in a manner that
the development organization can interpret, understand, and implement.
A bachelor's degree in electrical engineering or computer science is required, with a master's
or Ph.D. degree preferred.
Engineering-Embedded Applications Layer Software
Software Engineers - all levels of experience
招聘人数:若干 学 历:本科
薪水范围:面议 接受简历语言:中文和英文
职位描述:
Description:
Candidates will be responsible for independently taking a subsystem all the way from design to
implementation and test. This will require technical strength and the ability to interact with
the team to insure subsystems are integrated with the overall system.
Candidates will require excellent communications skills in Mandarin and average communication
skills in English to be able to translate system requirements to actual software design and to
Candidates will require knowledge of standard software development processes and methodologies,
and have a high commitment to software quality. Hands-on experience with embedded processors
and RTOS, C and assembler languages, with exposure to developing and debugging low-level
(interrupts/hardware-access) multitasking/multiprocessing, shared-memory and message-passing
programming is required as well as exposure to use of emulators, BDMs, logic-analyzers, etc.
A bachelor's or master's degree in electrical engineering or computer science is required, with
experience in SONET, IP/OSI/datacomm stacks and protocols, OSE and/or VxWorks, and PowerPC
highly desired.
Software Manager
Description:
For technical background, candidates will have a minimum of five years of experience in all
aspects of real-time, embedded, software engineering, including requirements analysis, design,
implementation, unit and integration testing. A full understanding of, and experience with,
structured analysis and design technologies is required. Additionally a strong understanding of
finite state machines and object-oriented techniques such as use-case analysis and object-
interaction diagrams is required. Hands-on experience with embedded processors and RTOS, C and
assembler languages, with exposure to developing and debugging low-level (interrupts/hardware-
access) multitasking/multiprocessing, shared-memory and message-passing programming is also
required. Exposure to the use of emulators, BDMs, logic-analyzers, etc is also required. Having
this prior experience in IP/SDH telecommunications systems development will give a highly
preferred status to a candidate.
Candidates should have prior management but outstanding candidates with successful team
leadership roles will be considered. This job requires great leadership potential, strong
technical knowledge, strong ethics, the ability and desire to mentor younger engineers, and the
desire to work with your peers in the United States.
The position will report to the Director of Software who is located in the USA so it is
critical that the candidate be self-motivated, highly organized, and have average to good
English skills.
The Software Engineering Manager will be required to help recruit, interview, and establish the
embedded SW team of 10 to 15 engineers.
A bachelor's or master's degree in electrical engineering or computer science is required.
Experience in IP/SDH, IP/OSI/datacomm stacks and protocols, OSE and/or VxWorks, and PowerPC is
highly desired.
Vice President Of Engineering
发布日期:2005-11-02 工作地点:上海市
招聘人数:1 学 历:本科
工作年限:十年以上 薪水范围:面议
外语要求:英语 熟练 接受简历语言:中文或英文
职位描述:
Description:
This is the top technical position in China operations and could expand to be the top
technical position in all of White Rock Networks.As the China leader, you will be responsible
for all facets of White Rock Networks product development teams. This includes recruiting,
scheduling, technical guidance, budgets, and mentoring of less experienced team members.
The team is currently at 40 headcount and consists of SW, HW, Test, ASIC, Mech, PCB layout, and
support personnel. The FY2006 plan is to grow this head count to 75. Further growth is
desirable depending upon the success of the team.
The VP of Engineering will be replacing the current VP of Engineering (Founder and CTO) who
will continue to perform as the China country manager. Since the current CTO is based in the
United States, he can no longer provide the daily guidance the Shanghai Development Center
(SDC) team requires for its success.
However, the CTO and a small team of US based engineers and leaders will be available to assist
the new VP of Engineering and his/her SDC team. If the candidate quickly succeeds at his/her
role, the US based team may be placed under direct management of the new VP of Engineering.
The requirements for this job are specific and demanding. If you do not meet these minimum
requirements then please do not send a resume for consideration.
1.Potential candidates must have >12 years of work experience since graduating in
telecommunications system design
2.Candidates must have >5 years experience from one of these companies:
a.Huawei, UTStarcomm, ZTE, Lucent, Nortel, Alcatel, or Fujitsu.
3.Candidates must have 5 or more years experience doing SDH/SONET equipment design as a
Software, ASIC, or Digital design engineer
4.Candidates must have >5 years of management experience
5.In your 12+ years of experience, you must have worked for less than 5 different
companies….White Rock is looking for demonstrable stability in a candidate
6.You must have outstanding English communication skills. Your interview will be in English
7.You must lead by example. You work the hours needed to accomplish the goals, your ethics are
unimpeachable, you are company oriented first, then team oriented, and finally self oriented.
Preference will be given to candidates that have one or more of the following items:
1.An MBA from a top school…preferably US based
2.US work experience with a major US telecom equipment company
3.Have previously led cross functional systems developments
4.Candidates that are currently at the Senior Manager or higher level within one of the above
listed companies
The selected individual will get something that few others are ever offered….a chance to step
into THE technical leadership role for a growing company.
Design For Testability Engineer
招聘人数:1 学 历:本科
工作年限:二年以上 薪水范围:面议
外语要求:英语 熟练 接受简历语言:中文和英文
职位描述:
Description
A Design For Test (DFT) Engineer is responsible for analyzing the testability of manufactured
electronic boards and providing proposals to R&D department for improving coverage in the
Manufacturing process. The goal of a DFT Engineer is to achieve 100% testability and coverage
for a board across ICT, Boundary scan, functional test, and system test. The DFT Engineer
position at White Rock requires a background in hardware analysis and experience in SONET,
Ethernet, DS3, DS1, IP, or LAN telecommunications protocol products. White Rock is looking for
people that have a strong desire to learn, can work in a multi-national team environment, and
that would like to advance their career.
1 Familiar with major ICT systems (3070, GenRad, Teradyne)
2 Familiar with ICT program development
3 Familiar with ICT fixture design
4 Familiar with Boundary scan technology and BSDL
5 Ability to read schematics
6 Experiences in 5DX and AOI is a advantage
7 Experience in mechnical design for manufacturing (DFM) analysis is also a advantage
8 Able to work in a fast paced and team environment
9 Must have better than average English verbal and written skills
VP of Engineering
Engineers-System
Engineers-ASIC/FPGA
Engineers-Hardware
Engineers-DFT
联系人:张先生
Email: francky1979@hotmail.com
(可加入MSN)
公司网址: www.whiterock.com
祝你好运!!!
关键词: 电子 通讯 计算机 专业 最佳 工作机会 shan
共3条
“我踩过的那些坑”主题活动——第002期 | |
【EEPW电子工程师创研计划】技术变现通道已开启~ | |
【EEPW在线】E起听工程师的声音! | |
高校联络员开始招募啦!有惊喜!! | |
打赏了!打赏了!打赏了! |
