共1条
IC库存,低价清仓!! NOW IN STOCK !!
Over 100000 units in stock !!!sales56@gmail.com *~*86-755-89800951***
OFFER LIST
SDRAM
SDRAM 32Mx8-H HY57V56820CT-H Hynix 11,520
SDRAM 16Mx16-H HY57V561620CTP-H Hynix 10,560
SDRAM 16Mx16-H HY57V561620CT-H Hynix 11,520
SDRAM 8Mx16-H HY57V281620PT-H leadfree Hynix 10,000
SDRAM 8Mx16-6/H HY57V281620ET-6/H Hynix 11,520
IC库存,低价清仓!! NOW IN STOCK !!sales56@gmail.com***
SDRAM 2Mx32-7 HY57V643220C/DTP-7 Hynix 11,520
SDRAM 2Mx32-7 HY57V643220C/DT-7 Hynix 11,520
SDRAM 4Mx16-75 K4S641632H-TC75 Samsung 10,000
SDRAM 4Mx16-7 HY57V641620ET-7 Hynix 23,040
SDRAM 4Mx16-H HY57V641620ET-H Hynix 23,040
SDRAM 1Mx16-6 K4S161622HUC-60 Samsung 10,000
SDRAM 1Mx16-7 HY57V161610ET-7 Hynix 23,040
SDRAM 1Mx16-8 HY57V161610ET/ETP-8 Hynix 23,040
NOW IN STOCK !! Over 100000 units in stock !!!sales56@gmail.com *~*86-755-
89800951***
IC库存,低价清仓!! NOW IN STOCK !!sales56@gmail.com删除
SDRAM- PC133
SD 32Mx16-75 133MHz K4S511632B-TC75 Samsung 960@
SD 32Mx8-75 133MHz CL3 K4S560832E-TC75 Samsung 7680@
SD 16Mx16-H 133MHz CL3 HY57V561620CT-H Hynix 11040@
SD 16Mx16-75 133MHz CL3 MT48LC16M16A2TG-75 Micron 6000@ USD4.20 Stock
SD 16Mx16-75 133 MHz K4S561632E-TC75 Samsung 1934@
SD 16Mx16-75 133 MHz PB Free K4S561632E-UC75 Samsung --@ USD3.92 Stock
SD 16Mx8 PC133 CL3 K4S280832F-TC75 Samsung 11520@
SD 16Mx8-75 133Mhz CL3 K4S280832F-TC75 Samsung 22080@
SD 8Mx16-H 133MHz CL3 HY57V281620HCT-H Hynix 5760@ USD2.40 Stock HK
SD 8Mx16-H 133MHz CL3 HY57V281620ET-H Hynix 11520@
IC库存,低价清仓!! sales56@gmail.com *~*86-755-89800951***
SD 8Mx16-75 133MHz CL3 MT48LC8M16A2TG-75 Micron 12000@ USD 2.22 4 days
SD 8Mx16-75 133MHz CL3 K4S281632F-TC75 Samsung 28800@
SD 8Mx16-75 133MHz CL3 K4S281632F-TC75T00 Samsung 28000@ USD1.98 1 day
SD 4Mx16 PC143 HY57V641620HGT-7 Hynix 14000@
SD 4Mx16 PC133 CL3 HY57V641620HGT-H Hynix 28800@ USD1.03 1 day
SD 4Mx16 -75 133Mhz K4S641632H-TC75 Samsung 6720@
SD 4Mx16-75 133Mhz Pb Free K4S641632H-UC75 Samsung 100000@ USD0.95 1 day
SD 2Mx32 PC143 HY57V643220CT-7TR Hynix 1000@
SD 1Mx16 PC143 HY57V161610ET-7 Hynix 40000@
SD 1Mx16-6 PC166 CL3 Pb Free K4S161622H-UC60 Samsung 10000@
EDO Extended Data Out
EDO 1Mx16-50 3.3 1K SOJ GM71V18163CJ-5 Hynix [Hyundai] 471@
EDO 1Mx16-60 5V 1K SOJ GM71CS18163CLJ-6 Goldstar 1360@
EDO 1Mx16-6 3.3V S OJ GM71V18163CJ-60 Hynix 930@
EDO 1Mx16 3.3v SOJ HY51V18164C-JC60 Hynix 3000@
EDO 256Kx16-28 SOJ V53C16258HK-28 Mosel Vitelic 590@
FPM Fast Page Mode
FPM 1Mx16-60 5V 4K SOJ GM71C16160CJ-60 Goldstar 4900@
FPM 1Mx16-60 5V 4k SOJ GM71C16160BJ-60 Goldstar 7000@
89800951***
Description Part No Brand Quantity @ Price Remarks
Altera
PQFP, 208 Pin EP1K30QC2083 Altera 216@
Altera EPF6016QC208-3 Altera 288@
Complex EEPLD, 100 Pins, 128 Cells EPM7128ATC100-10 Altera 270@ See remark
Analog Devices
A/D Converter AD1674KN Analog Devices 100@
Amplifier AD822AR Analog Devices 1000@
Amplifier & nbsp;AD8307AR Analog Devices 5000@
Atmel
8 Bit Microcontroller AT89S52-24JI Atmel 21600@
8 bit Microcontroller ATMEGA16L-8MC Atmel 5000@
EEPROM AT29C512-12PC Atmel 1500@
Atmel ATMEGA48V-10AI Atmel 5000@
Maxim
LED Display Driver MAX7219CNG Maxim 151
Step-Up DC-DC Converters MAX1724EZK50-T Maxim 500@
89800951***
Flash Memory
256M Flash Memory RC28F256K3C-120 Intel 1000@
256M Flash Memory TE28F256J3C-125 Intel 4000@
256M Flash Memory RC25F256K3C-120 Intel 5000@
256M Flash Memory RC28F256J3C-125 Intel 9000@
128M Flash Memory RC28F128J3C-150 Intel 2000@
64M Flash Memory RC28F640J3A-120 Intel 10000@
32M Flash Memory E28F320J5A-120 Intel 350@
32M Flash Memory TE28F320J3C-110 Intel 300@
32M Flash Memory TE28F320J3C-90 Intel 300@
32M Flash Memory MT28F320J3FS-11 Micron 7000@
16M Flash Memory AM29LV160DB-70EI AMD 19200@
16M Flash Memory AT45DB161B-CNI Atmel 50000@
16M Flash Memory TE28F160B3TD70 Intel 3000@
16M Flash Memory GE28F160C3TD-70 Intel 5000@
8M Flash Memory 3.3V TSOP TE28F800B3BA-90 Intel 675@
8M Flash Memory TE28F800B3B-90 Intel/00+ -1@
89800951*** ***
8M Flash Memory TE28F800C3B-90 Intel 675@
8M NOR Flash Memory TE28F800C3BA-90 Intel 675@
8Mb Nor Flash TSOP 5V MT28F800B5WP-8B Micron 2000@
8Mb Nor Flash TSOP 3.3V MT28F800B3WG-9B Micron 20000@
8Mb Nor Flash TSOP 3.3V MT28F800B3WG-10B Micron 20000@
8M Flash memory SST39VF800A-70-4I-EK SST 10560@
8M Flash Memory M29W800DT-70N6 ST Microelectronics 15000@
8M Flash 3.3 TSOP M29W800DT-90N6 ST Microelectronics 15000@
89800951***
4M NOR Flash Memory TSOP AM29LV400BB-70EC AMD 10000@
4M Flash Memory AM29F040B-90JC AMD 1050@
4M Flash Memory AM29F400BT-90ECT AMD 4000@
4M Flash Memory AM29F040B-90PI AMD 1100@
4M Flash Memory AM29LV040B-70JI AMD 1020@
32M NOR Flash S29GL032M10TAIR40 Spansion 600@
4M Flash Memory SST39VF400A-70-4C-EK SST 2000@
4M Flash Memory SST49LF004B-33-4C-NH SST 17000@
4M Flash Memory SST49LF004A-33-4C-NH SST 17000@
2M Flash Memory AM29LV200BB-70WAI AMD 5000@
2M Flash Memory AM29LV200BT-70EI AMD 1000@
1M Flash Memory AM29F010B-70PC AMD/01+ 300@
1M Flash Memory TSOP AM29LV001BB-55EC AMD/99+ 20000@
1M Flash Memory TSOP AM29LV001BB-70EC AMD/99+ 20000@
1M Flash Memory AM29LV001BB-90EC AMD 20000@
1M Flash Memory AM29F010-90JI AMD 4000@
8G Nand Flash K9W8G08U0M-PCB0 Samsung 18000@
Static RAM
SRAM 512Kx16 K6X8016T3B-TF70 Samsung 1600@
Fast SRAM 1Mx4-1 SOJ K6R4004C1D-JC10 Samsung 15000@
SRAM 512Kx8-7 K6T4008C1C-GF70 Samsung 2400@
SRAM 512Kx8-10 STSOP K6T4008U1C-YF10 Samsung 1000@
SRAM 512Kx8-10 STSOP K6T4008U1C-YF10T00 Samsung 1000@
SRAM 512Kx8-10 SOP K6R4008V1C-JC10000 Samsung 4000@
SRAM 512Kx8-12 SOP K6R4008V1C-JC12000 Samsung 4000@
SRAM 512Kx8-10 3.3V K6R4008V1D-UC10 Samsung 15000@
SRAM 512Kx8-10 3.3V K6R4008V1C-JC15000 Samsung 4000@
SRAM 128kx8-70 LL Pwr 5V SOP HY628100BLLG-70 Hynix 5000@
SRAM 128Kx8-7 SOP K6T1008V2E-GB70T00 Samsung 1500@
SRAM 128kx8 SOP LLP HY628100BLLG-55 Hynix 10000@
89800951***
SRAM 256Kx16 R1LV0416CSB-5SI Renesas 1000@
SRAM 128Kx8-10 K6R1008C1D-JI10 Samsung/02+ 1000@
IC库存,低价清仓!! sales56@gmail.com ***
SRAM 32Kx8-70 SOP HY62WT08081E-DG70C Hynix 20000@
SRAM 512Kx36 K7D803671B-HC30000 Samsung 400@
SRAM 512KX8-70 K6T4008U1C-YB70 Samsung 1000@
SRAM 512kx8 [4M] K6X4008C1F-GF55 Samsung 800@
SRAM 512Kx8 K6X4008T1F-YF70 Samsung 5000@
SRAM 128KX8-55 K6X1008C2D-GF55T00 Samsung 2000@
SRAM 512Kx8 K6X4008T1F-GF70T Samsung 2000@
SRAM 128KX8-55 Industrial Grade K6X1008C2D-DF55 Samsung 300@
SRAM 1Mx8 2.7 to 3.6 volts TSOP2 K6X8008T2B-TF70 Samsung 3000@
EPROM
EEPROM AT89C52-24PI ATMEL 20000@
8M EPROM DIP M27C801-100F1 ST Microelectronics 1008@
1M CMOS EEPROM AM27C010-150DC AMD 1000@
89800951***
EEPROM M95256-VMW6T ST Microelectronics 20000@
SGRAM
SGRAM 2Mx32-8 TSOP TC59S6432CFT-80 Toshiba 2000@
Multi Chips Carrier (Flash / Static RAM)
64M NOR Flash / 8M SRAM S71JL064H80BAW010 DDR
DDR 64Mx8-J PC333 HY5DU12822BT-J Hynix 11,520
DDR 32Mx16-CTP-J HY5DU121622CTP-J Hynix 11,520
DDR 32Mx8-D43 PC400 HY5DU56822B/C/DT-D43 Hynix 11,520
DDR 32Mx8-J PC333 HY5DU56822B/C/DT-J Hynix 11,520
DDR 16Mx16-5 HY5DU561622C/DT-5 Hynix 11,520
DDR 8Mx16-5 HY5DU281622C/ET-5 Hynix 11,520
DDR 8Mx32-33 Hynix 10,080
DDR 4Mx32-33 HY5DU283222-BF33 Hynix 10,080
DDR 4Mx32-36/4/5 Hynix 11,520
HY5DU283222-F36/AF36/AQ4/AQP5
Graphic DDR
GDDR 16Mx16 250MHz TSOP HY5DU561622CT-4 Hynix
GDDR 16Mx16 200MHz TSOP HY5DU561622DT-5 Hynix 11520
GDDR 4Mx32 300MHz FPGA< /td> HY5DU283222AF-33 Hynix 11520
DDR 8Mx16-4 HY5DU281622AT-4 Hynix --@ HK
DDR2
DDR2 64Mx8 PC533 FBGA K4T51083QC-ZCD500 Samsung 11520@
DDR2 32Mx8 PC400 HYB18T256800AF-5 Infineon 6000@
DDR 128Mx4 PC400 BGA K4H510438C-ZCCC Samsung 20000@
DDR 128Mx4 PC400 CL2.5 BGA HYB25D512400BC-5 Infineon 10000@
DDR 64Mx8 PC400 K4H510838B-TCCC Samsung 10000@
DDR 64Mx8 PC400 HY5DU12822BT-D43 Hynix 11520@
DDR 64Mx8 PC400 K4H510838C-UCCC Samsung 5760@
DDR 64Mx8 PC400 MT46V64M8TG-5B Micron 10000@
DDR 64Mx8 PC400 Pb Free HY5DU12822CTP-D43 Hynix &nb sp;--@
DDR 32Mx16 PC400 TSOP HY5DU121622CTP-D43 Hynix 33223@
DDR 32Mx8 PC400 K4H560838F-TCCC Samsung 11520@
DDR 32Mx8 PC400 CL3 HYB25D256800BT-5 Infineon 19500@
DDR 32Mx8-5 PC400 MT46V32M8TG-5B Micron 10000@
DDR 32Mx8 PC400 PB Free HYB25D256800CE-5 Infineon 21000@
DDR 32Mx8 PC400 EDD2508ARTA-5B Elpida 10800@
89800951***
DDR 32Mx8 PC400 HY5DU56822BT-D43 Hynix 11520@
DDR-333
DDR 128Mx4 PC333 Pb Free K4H510438C-ZCB3 Samsung 10000@ USD8.30 1 day
DDR 32Mx16 PC333 PB Free TSOP HYB25D512160BE-6 Infineon 15000@
DDR 32Mx8 PC333 CL2.5 HYB25D256800BT-6 Infineon 9000@ USD2.75 Stock HK
DDR 16Mx8 PC333 Lead Free HYB25D128800CE-6 Infineon 18000@
DDR-266 SRAM
HY62KT08081E-DT70DR 32Kx8SRAM 1.5K/01+ 1000
GM76FV116SLT-70T 64Kx16SRAM 6K/04+ 960
HY628400ALLG-55 512Kx8SRAM 3K/02+ 550
HY62WT08081E-DG70C 32Kx8SRAM 20K/04+ 1000
HY628100BLLG-70 128Kx8SRAM 20K/03+ 550
HY62V8100BLLT1-70 128Kx8SRAM 50k/02+ 1400
HY62U8100BLLST-70I 128Kx8SRAM 25k/02+ 1400
HY628100BLLT1-70 128Kx8SRAM 12k/04+ 1400
HY628100BLLG-55I 128Kx8SRAM 4K/02+ 550
HY628400ALLT2-55 512Kx8SRAM 5760/00+ 960
HY62V8400ALLG-70 512Kx8SRAM 30k/03+ 550
HY62V8400ALLT2-70DR 512Kx8SRAM 4k/00+ 1000
R1LP0408CSP-7LC 512Kx8SRAM 10K/
SDRAM
HY57V561620CT-H 16Mx16SDRAM 10K/04+ 960
HY57V56420CT-H-A 64M*4SDRAM 5760/04+ 960
HY57V561620CTP-H 16M*16SDRAM 5760/04+ 960
HY57V56820CT-H 32M*8SDRAM 10k/04+ 960
HY57V561620CLT-H 16M*16SDRAM 20K/05+ 960
HY57V281620HCT-H 8Mx16SDRAM 20K/04+ 960
HY57V281620ET-6 8Mx16SDRAM 10K/04+ 960
HY57V281620ET-H 8Mx16SDRAM 10K/04+ 960
HY57V641620HGT-H 4Mx16SDRAM 30K/04+ 960
HY57V641620HGTP-H 4M*16SDRAM 15K/04+ 960
HY57V641620HGT-7 4Mx16SDRAM 20k/04+ 960
HY57V641620HGT-6 4Mx16SDRAM 7K/03+ 960
HY57V641620ET-7 4Mx16SDRAM 50K/04+ 960
HY57V641620ET-H 4Mx16SDRAM 10K/04+ 960
HY57V641620ET-6 4Mx16SDRAM 11520/05+ 960
HY57V643220DT-6 2M*32SDRAM 10k/04+ 960
HY57V64820HGLT-PDR 8M*8SDRAM 10K/04+ 1000/reel
HY57V161610ETP-7 1Mx16SDRAM 50K/04+ 960
HY57V161610ET-7 1Mx16SDRAM 50K/04+ 960
DDR
HY5DU283222AF-33 4M*32 20K/04+ 1680
HY5DU283222AQ-5 4M*32 2880/04+ 720
HY5DU56422DT-HDR-A 64M*4 5000/04+ 1000
HY5DU561622DT-5 16Mx16 11520/04+ 960
HY5DU281622ET-4 8M*16 11520/04+ 960
HY5DU281622ET-5 8M*16 11520/04+ 960
NAND FLASH
HY27US08561M-TCB 32Mx8 10K/04+ 960
HY27US08121M-TCB 64Mx8 20K/04+ 960
HY27UA081G1M-TCB 128M*8 10K/04+ 960
HY27UF081G2M-TCB 128M*8 20K/04+ 960
HY27UG082G2M-TCB 256M*8 5760/04+ 960
HY27UH084G2M-TCB 512M*8 2880/05+ 960
OTHERS
GM71C16160CT-6 1Mx16FP 1520/00+ 960
GM71V18163CJ-5DR 1Mx16EDO 1K/01+ 1000
GM71V17403CT-6 4Mx4EDO 1K/01+ 1000
HY531000ALJ-60 1Mx1FP 26K/97+ 1000
HY531000AJ-70 1Mx1FP 48K/97+ 1000
HY512264JC-70 128Kx8EDO 16K/97+ 500
HY29F040AT-70 512Kx8FLASH 10k/00+ 1400
HY29F040AT-55 512Kx8FLASH 10k/00+ 1400
HY5DU561622CT-33 Hynix
HY5DU561622CT-5 Hynix
K4D551638F-TC50T00 Samsung
K4D551638F-TC60 Samsung
HY5DU281622ET-33 Hynix
HY5DU281622ET-5 Hynix
**IC库存,低价清仓!! NOW IN STOCK !!sales56@gmail.com***
89800951*** K4D263238E-GC33 Samsung
HY5DU56822BT-D5 Hynix
HY5DU121622AT-D43 Hynix
K4H560838E-TCCC* Samsung
HY5DU56822DT-D43 Hynix
EDD2508AMTA-5B Elpida
89800951*** **IC库存,低价清仓!! NOW IN STOCK !!sales56@gmail.com***
89800951*** EDD2508AKTA-5B Elpida
V58C2256804SAT-5B Mosel Vitelic
K4H560838E-TCCC Samsung
HYB25D256160BT-5 Infineon
HYB25D256160CE-5 Infineon
HY5DU561622DT-D43 Hynix
HY5DU561622CT-D43 Hynix
HYB25D512800BC-6 Infineon
HY5DU121622BT-J Hynix
MT46V32M16TG-6T Micron
HYB25D256400CC-6 Infineon
HYB25D256400BC-6 Infineon
K4H560438E-GCB3 Samsung
K4H560838E-GCB3 Samsung
EDD2508AMTA-6B Elpida
HYB25D256800CC-6 Infineon
EDD2508AKTA-6B Elpida
HY5DU56822BT-J Hynix
HY5DU56822DT-J Hynix
HYB25D256800CE-6 Infineon
MT46V32M8TG-6T Micron
P2S56D20BTP-6 UTT UTT - Mira
V58C2256804SAT-6 Mosel Vitelic
K4H560838F-TCB3 Samsung
M2S56D30ATP-60 Mitsubishi
HY5DU561622DT-J Hynix
89800951*** HYB25D256160BT-6 Infineon
EDD2516AMTA-6B Elpida
MT46V16M16TGP-6T Micron
K4H561638F-TCB3 Samsung
K4H510438B-TCB0 Samsung
EDD5116ADTA-7A Elpida
K4H560438E-TCB0* Samsung
HYB25D256400BT-7 Infineon
MT46V32M8TG-75 Micron
HY5DU56822BT-H Hynix
EDD2508AKTA-7A Elpida
MT46V16M16TG-75 Micron
HYB25D128800AT-7 Infineon
K4H280838F-TCB0 Samsung
HY5DU281622ET-J Hynix
K4S510832B-TC75 Samsung
HYB39S256400DT-7 Infineon
H**IC库存,低价清仓!! NOW IN STOCK !!sales56@gmail.com***
89800951*** Y57V56820HCT-H Hynix
HYB39S256800DT-7 Infineon
MT48LC32M8A2TG-75 Micron
K4S560832E-TC75T00 Samsung
K4S560832E-UC75 Samsung
关键词: 库存 低价 清仓 STOCK 100000 uni
共1条
硬核工程师专属补给计划——填盲盒 | |
“我踩过的那些坑”主题活动——第002期 | |
【EEPW电子工程师创研计划】技术变现通道已开启~ | |
【EEPW在线】E起听工程师的声音! | |
高校联络员开始招募啦!有惊喜!! | |
送您一块开发板,2025年“我要开发板活动”又开始了! |
