请教各位大侠:
请问调用tffDevFormat时,函数参数是怎样确定的,***Erase(),***Write(),函数的参数又是怎样确定的,参数的传递过程又是怎样的?[em06]
tffsDevFormatParams params =
#undef HALF_FORMAT /* lower 512KB for bootimage, upper for TFFS */
#ifdef HALF_FORMAT
{0x00080000l, 99, 1, 0x40000l, NULL, {0,0,0,0}, NULL, 2, 0, NULL},
#else
{0x00000000l, 99, 1, 0x40000l, NULL, {0,0,0,0}, NULL, 2, 0, NULL},
#endif /* HALF_FORMAT */
FTL_FORMAT_IF_NEEDED
status = tffsDevFormat (1, (int)¶ms); /* 设备1 */
0x00080000l是前面保留的大小;0x00000000l就是不保留!
0x40000l是一个扇区(SECTOR)的大小!(具体看你的芯片而定)
Procedure: lv160MTDWrite ID:1
Purpose: MTD写Flash函数
Input:
Output:
Errors:
static FLStatus lv160MTDWrite(FLFlash vol, CardAddress address, const void FAR1 *buffer, int length, FLBoolean overwrite)
int cLength;
FlashWPTR flashPtr, flashTmp;
volatile UINT16 *gBuffer;
flashTmp = flashPtr = (FlashWPTR) vol.map(&vol, address, length);
if(length&1)
printf("warning! the data length can not divided by 2.");
cLength = length/2;
gBuffer = (UINT16 *)buffer;
while (cLength >= 1)
*thisVars->unlockAddr1 = UNLOCK_1;
*thisVars->unlockAddr2 = UNLOCK_2;
*thisVars->unlockAddr1 = SETUP_WRITE;
*flashPtr = *gBuffer;
if(lv160OpOverDetect((void *)flashPtr, 0x1000000));
if(*flashPtr != *gBuffer)
*flashPtr = READ_ARRAY;
#ifdef DEBUG_PRINT
DEBUG_PRINT("Debug: lv160MTDWrite timeout.\n");
#endif
return flWriteFault;
cLength--;
flashPtr++;
gBuffer++;
if (tffscmp((void FAR0 *) flashTmp, buffer,length))
/* verify the data */
#ifdef DEBUG_PRINT
DEBUG_PRINT("Debug: lv160MTDWrite fail.\n");
#endif
return flOK;
Purpose: MTD擦除Flash函数
Input:
Output:
Errors:
static FLStatus lv160MTDErase(FLFlash vol, int firstErasableBlock, int numOfErasableBlocks)
int iBlock; FlashWPTR flashPtr;
unsigned int offset;
if(numOfErasableBlocks <= 0) return ERROR;
for (iBlock = 0; iBlock < numOfErasableBlocks; iBlock++)
int i;
offset = (firstErasableBlock + iBlock) * vol.erasableBlockSize;
flashPtr = (FlashWPTR) vol.map(&vol, offset, vol.interleaving);
*thisVars->unlockAddr1 = SETUP_ERASE;
*flashPtr = SECTOR_ERASE;
lv160OpOverDetect((void *)flashPtr, 0x2000000);
for(i=0; i<vol.erasableBlockSize/2; i++,flashPtr++)
if(*flashPtr != 0xffff) break;
if(i < vol.erasableBlockSize/2)
#ifdef DEBUG_PRINT
DEBUG_PRINT("Debug: lv160MTDErase fail.\n");
#endif
printf("\Erase ok\n");
return flOK;
看看他们是怎样调用的:
Procedure: lv160MTDIdentify ID:1
Purpose: MTD读Flash标识[extern]
Input:
Output:
Errors:
FLStatus lv160MTDIdentify(FLFlash vol)
FlashWPTR baseFlashPtr;
vol.interleaving = 1;
flSetWindowBusWidth(vol.socket,16);/* use 16-bits */
flSetWindowSpeed(vol.socket,120); /* 120 nsec. */
if (vol.socket->serialNo == 0){
flSetWindowSize(vol.socket, FLASH_SIZE>>12);
vol.chipSize =0x001c0000; /* FLASH_SIZE;*/
vol.map = lv160MTDMap0;
else if(vol.socket->serialNo == 1){
flSetWindowSize(vol.socket, FLASH_BOOT_SIZE>>12);
vol.chipSize = FLASH_BOOT_SIZE;
vol.map = lv160MTDMap1;
vol.mtdVars = &mtdVars[flSocketNoOf(vol.socket)];
baseFlashPtr = (FlashWPTR)vol.map (&vol, (CardAddress)0, vol.interleaving);
printf("\nthe baseFlashPtr is %x\n",baseFlashPtr);
/*UNLOCK_ADDR为字地址, 赋值转换x2*/
thisVars->unlockAddr1 = (FlashWPTR)((long)baseFlashPtr) + UNLOCK_ADDR1;
thisVars->unlockAddr2 = (FlashWPTR)((long)baseFlashPtr) + UNLOCK_ADDR2;
fllv160Identify(&vol, 2); /*get flash device ID.*/
printf("\nthe thisVars->unlockAddr1 is %x, thisVars->unlockAddr2 is %x\n",thisVars->unlockAddr1,thisVars->unlockAddr2);
printf("\nthe type is %x\n",vol.type);
if (vol.type != AM29LV160D_DEID)
#ifdef DEBUG_PRINT
DEBUG_PRINT("Debug: can not identify SST39VF160 media.\n");
#endif
return flUnknownMedia;
vol.noOfChips =0x1; /*one chip.*/
vol.erasableBlockSize = 0x40000; /* 256k bytes.*/
vol.flags |= SUSPEND_FOR_WRITE;
/* Register our flash handlers */
vol.write = lv160MTDWrite;
vol.erase = lv160MTDErase;
printf("\nidentify ok\n");
return flOK;
"tffs/flflash.h"
/* FAT-FTL Lite Software Development Kit */
/* Copyright (C) M-Systems Ltd. 1995-1996 */
#ifndef FLFLASH_H
#define FLFLASH_H
#ifdef __cplusplus
extern "C" {
#endif
#include "flsocket.h"
/* Some useful types for mapped Flash locations */
typedef volatile unsigned char FAR0 * FlashPTR;
typedef volatile unsigned short int FAR0 * FlashWPTR;
typedef volatile unsigned long FAR0 * FlashDPTR;
typedef unsigned short FlashType; /* JEDEC id */
#define NOT_FLASH 0
/* page characteristics flags */
#define BIG_PAGE 0x0100 /* page size > 100H*/
#define FULL_PAGE 0x0200 /* no partial page programming*/
/* MTD write routine mode flags */
#define OVERWRITE 1 /* Overwriting non-erased area */
#define EDC 2 /* Activate ECC/EDC */
#define EXTRA 4 /* Read/write spare area */
/* Flash array identification structure */
/* This structure contains a description of the Flash array and */
/* routine pointers for the map, read, write & erase functions. */
/* The structure is initialized by the MTD that identifies the Flash */
/* array. */
/* On entry to an MTD, the Flash structure contains default routines */
/* for all operations. This routines are sufficient forread-only access */
/* to NOR Flash on a memory-mapped socket. The MTD should override the */
/* default routines with MTD specific ones when appropriate. */
typedef struct tFlash FLFlash; /* Forward definition */
struct tFlash {
FlashType type; /* Flash device type (JEDEC id) */
long int erasableBlockSize; /* Smallest physically erasable size
(with interleaving taken in account) */
long int chipSize; /* chip size */
int noOfChips; /* no of chips in array */
int interleaving; /* chip interleaving
(The interleaving is defined as
the address difference between
two consecutive bytes on a chip) */
unsigned flags; /* Special capabilities & options
Bits 0-7 may be used by FLite.
Bits 8-15 are not used bt FLite
and may be used by MTD's for MTD-
specific purposes. */
void * mtdVars; /* Points to MTD private area for
this socket.
This field, if used by the MTD, is
initialized by the MTD identification
routine */
FLSocket * socket; /* Socket of this drive */
/* Flag bit values */
#define SUSPEND_FOR_WRITE 1 /* MTD provides suspend for write */
#define NFTL_ENABLED 2 /* Flash can run NFTL */
/* f l a s h . m a p */
/* MTD specific map routine */
/* The default routine maps by socket mapping, and is suitable for all */
/* NOR Flash. */
/* NAND or other type Flash should use map-through-copy emulation: Read */
/* a block of Flash to an internal buffer and return a pointer to that */
/* buffer. */
/* Parameters: */
/* vol : Pointer identifying drive */
/* address : Card address to map */
/* length : Length to map */
/* Returns: */
/* Pointer to required card address */
void FAR0 * (*map)(FLFlash *, CardAddress, int);
/* f l a s h . r e a d */
/* MTD specific Flash read routine */
/* The default routine reads by copying from a mapped window, and is */
/* suitable for all NOR Flash. */
/* Parameters: */
/* address : Card address to read */
/* buffer : Area to read into */
/* length : Length to read */
FLStatus (*read)(FLFlash *, CardAddress, void FAR1 *, int, int);
/* f l a s h . w r i t e */
/* MTD specific Flash write routine */
/* The default routine returns a write-protect error. */
/* Parameters: */
/* address : Card address to write to */
/* buffer : Address of data to write */
/* length : Number of bytes to write */
/* modes : See write mode flags definition above */
/* Returns: */
/* FLStatus : 0 on success, failed otherwise */
FLStatus (*write)(FLFlash *, CardAddress, const void FAR1 *, int, int);
/* f l a s h . e r a s e */
/* Erase one or more contiguous Flash erasable blocks */
/* Parameters: */
/* firstErasableBlock : Number of first block to erase */
/* numOfErasableBlocks: Number of blocks to erase */
/* Returns: */
FLStatus (*erase)(FLFlash *, int, int);
/* f l a s h . s e t P o w e r O n C a l l b a c k */
/* Register power on callback routine. Default: no routine is */
/* registered. */
/* Parameters: */
void (*setPowerOnCallback)(FLFlash *);
/* MTD registration information */
extern int noOfMTDs; /* No. of MTDs actually registered */
typedef FLStatus (*MTDidentifyRoutine) (FLFlash vol);
extern MTDidentifyRoutine mtdTable[];
/* See interface documentation of functions in flash.c */
extern void flIntelIdentify(FLFlash *,
void (*)(FLFlash *, CardAddress, unsigned char, FlashPTR),
CardAddress);
extern FLStatus flIntelSize(FLFlash *,
CardAddress);
extern FLStatus flIdentifyFlash(FLSocket *socket, FLFlash *flash);
#ifdef __cplusplus
#endif
#endif
谢谢 maomaotr的回答。
我根据maoamotr的回复对照了自己的代码,然后调试中出现了这样的问题:
-> tffsDevFormat
Debug:i28f128MTDIdentify: entering 16-bit Intel media identification routine.
Debug: i28f128Erase - firstErasableBlock=0, iBlock=0, vol.erasableBlockSize=0x20000, offset=0x0.
Debug: i28f128Erase - flashPtr=0x10140000, first=0, number=1.
i28f128Write: dest=0x10140000, src=0x21fff070 , size=0x50, start_sect=0x0, i28f128Write:start_sect=0x0,end_sect=0x0
************erase sector 0x0***********
----------program sector 0x0---------
Data abort
我发现src=0x21fff070 , size=0x50,都不是我想要的值,但是也不知道这些值系统是根据什么配置来确定的。
[em06][em06]有奖活动 | |
硬核工程师专属补给计划——填盲盒 | |
“我踩过的那些坑”主题活动——第002期 | |
【EEPW电子工程师创研计划】技术变现通道已开启~ | |
【EEPW在线】E起听工程师的声音! | |
高校联络员开始招募啦!有惊喜!! | |
送您一块开发板,2025年“我要开发板活动”又开始了! |
