When my device runs as usual, it encounter a Program Interrupt at fault pc.
1) It's a PowerPC processor
2) The Program Interrupt was caused by unrecognized instruction.
I suspect some threads have modified the instruction so that the CPU can't recognize it.
Do you have any ideas to track who modified the instruction?
共3条
****在线***: Program Interrupt in PowerPC
PowerPC processor has a big family -- Some of them can support hardware data break point register -- and this can capture it.
Several days before, I tried to dump the instructions around fault pc and it worked.
I found NO kernel text corruption happened because all the instructions around fault pc (and at fault pc) looks good. All the instructions can be disassembled correctly.
I'm suspecting the instruction cache has been corrupted. It seems no direct way supplied to dump instruction cache.
共3条
| 为遥控小车巧添功能被打赏¥26元 | |
