电子产品世界 » 论坛首页 » 嵌入式开发 » MCU » ****在线***: Program Interrupt in PowerPC
2006-08-16 23:32:17     打赏
When my device runs as usual, it encounter a Program Interrupt at fault pc.
1) It's a PowerPC processor
2) The Program Interrupt was caused by unrecognized instruction.
I suspect some threads have modified the instruction so that the CPU can't recognize it.
Do you have any ideas to track who modified the instruction?
关键词: 在线     Program     Interrupt     Powe
2006-08-21 17:37:00     打赏
Several days before, I tried to dump the instructions around fault pc and it worked.
I found NO kernel text corruption happened because all the instructions around fault pc (and at fault pc) looks good. All the instructions can be disassembled correctly.
I'm suspecting the instruction cache has been corrupted. It seems no direct way supplied to dump instruction cache.
