GCC GCC高手们,请给我一个合理的解释好吗?
同样的代码
ICC编译后736字节 (版本icc AVR 6.30 45天试用版)
GCC编译后1652字节 (版本winAVR 20030310 )
在硬件上运行结果相同。
gcc优化级为 s
结果让我十分苦恼
我实在不愿看到这个结果(心爱的GCC你不会是和我开玩笑呢吧!)。
就算插入初始化代码也不至于将近1K(单片机一共没多少K呀)吧!
代码点下面链接下载后把扩展名改成RAR后解压缩。
http://www.21icsearch.com/buzi/upimage/upfile/2004422923170.jpg
答 1: 这里下http://bitfu.go.nease.net/temp/code.rar 答 2: 你的程序好像没用到printf函数所以可以修改一下链接编译选项
你的Makefile中
# Optional linker flags.
LDFLAGS = -Wl,-Map=$(TARGET).map,--cref,-u,vfprintf -lprintf_min
改为
# Additional libraries
# Minimalistic printf version
#LDFLAGS += -Wl,-u,vfprintf -lprintf_min
# Floating point printf version (requires -lm below)
#LDFLAGS += -Wl,-u,vfprintf -lprintf_flt
# -lm = math library
#LDFLAGS += -lm
可视情况添加或删减链接库文件
试试看,程序代码量应该会大大减少,比ICC少很多
(我没试,暂时不用AVR,所以机子没装WinAVR) 答 3: 我换了makefile 编译后为510字节#makefile如下:
# WinAVR Sample makefile written by Eric B. Weddington, Jörg Wunsch, et al.
# Released to the Public Domain
# Please read the make user manual!
# On command line:
# make all = Make software.
# make clean = Clean out built project files.
# make coff = Convert ELF to AVR COFF (for use with AVR Studio 3.x or VMLAB).
# make extcoff = Convert ELF to AVR Extended COFF (for use with AVR Studio
# 4.07 or greater).
# make program = Download the hex file to the device, using AVRdude. Please
# customize the AVRdude settings below first!
# make filename.s = Just compile filename.c into the assembler code only
# To rebuild project do "make clean" then "make all".
#============= MCUÑ¡Ôñ ===========================
# MCU name
MCU = at90s8535
#============= Êä³ö¸ñʽѡÔñ ======================
# Output format. (CAN be srec, ihex, binary)
FORMAT = ihex
#============= Ä¿±êÎļþÃû(²»´øÀ©Õ¹Ãû) ============
# Target file name (without extension).
TARGET = demo
#============= ÓÅ»¯¼¶±ðÑ¡Ôñ ======================
# Optimization level, CAN be [0, 1, 2, 3, s]. 0 turns off optimization.
# (Note: 3 is not always the best optimization level. See AVR-libc FAQ.)
OPT = s
#============= C Ô´ÎļþÁбí("\"Ϊ»»ÐзûºÅ) =======
# List C source files here. (C dependencies are automatically generated.)
SRC = $(TARGET).c
# If there is more than one source file, append them above, or adjust and
# uncomment the following:
#SRC += foo.c bar.c
# You CAN also wrap lines by appending a backslash to the end of the line:
#SRC += baz.c \
#xyzzy.c
#============= ASM Ô´ÎļþÁбí ====================
# List Assembler source files here.
# Make them always end in a capital .S. Files ending in a lowercase .s
# will not be considered source files but generated files (assembler
# output from the compiler), and will be deleted upon "make clean"!
# Even though the DOS/Win* filesystem matches both .s and .S the same,
# it will preserve the spelling of the filenames, and gcc itself does
# care about how the name is spelled on its command-line.
ASRC =
#============= C±àÒëÑ¡Ïî =========================
# Optional compiler flags.
# -g: generate debugging information (for GDB, or for COFF conversion)
# -O*: optimization level
# -f...: tuning, see gcc manual and AVR-libc documentation
# -Wall...: warning level
# -Wa,...: tell GCC to pass this to the assembler.
# -ahlms: create assembler listing
CFLAGS = -g -O$(OPT) \
-funsigned-char -funsigned-bitfields -fpack-struct -fshort-enums \
-Wall -Wstrict-prototypes \
-Wa,-ahlms=$(<:.c=.lst)
#============= »ã±àÆ÷Ñ¡Ïî ========================
# Optional assembler flags.
# -ahlms: create listing
# -gstabs: have the assembler create line number information; note that
# for use in COFF files, additional information about filenames
# and function names needs to be present in the assembler source
# files -- see AVR-libc docs [FIXME: not yet described there]
ASFLAGS = -Wa,-ahlms=$(<:.S=.lst),-gstabs
#============= Á¬½ÓÆ÷Ñ¡Ïî ========================
# -Wl,...: tell GCC to pass this to linker.
# -Map: create map file
# --cref: add cross reference to map file
#============= ¸½¼Ó¿âÑ¡Ïî ========================
LDFLAGS += -lm
# Programming support using AVRdude. Settings and variables.
# Programming hardware: AVRisp stk500 AVR910 pAVR stk200 pony-stk200
# dt006 bascom alf
# Type: AVRdude -c ?
# to get a full listing.
AVRDUDE_PROGRAMMER = stk500
AVRDUDE_PORT = com1 # programmer connected to serial device
#AVRDUDE_PORT = lpt1 # programmer connected to parallel port
AVRDUDE_ERASE = -e
AVRDUDE_FLAGS = -p $(MCU) -P $(AVRDUDE_PORT) -c $(AVRDUDE_PROGRAMMER)
# Uncomment the following if you want AVRdude's erase cycle counter.
# Note that this counter needs to be initialized first using -Yn,
# see AVRdude manual.
#AVRDUDE_ERASE += -y
# Uncomment the following if you do /not/ wish a verification to be
# performed after programming the device.
#AVRDUDE_FLAGS += -V
# Increase verbosity level. Please use this when submitting bug
# reports about AVRdude. See <http://savannah.nongnu.org/projects/AVRdude>
# to submit bug reports.
#AVRDUDE_FLAGS += -v -v
#============= Ö¸¶¨Ä¿Â¼£¬Èç¹ûÐèÒª ================
# Define directories, if needed.
DIRAVR = c:/winAVR
DIRAVRBIN = $(DIRAVR)/bin
DIRAVRUTILS = $(DIRAVR)/utils/bin
DIRINC = .
DIRLIB = $(DIRAVR)/AVR/lib
#============= ¶¨ÒåÃüÁî(¹¤¾ßÈí¼þÃû³Æ) ============
# Define programs and commands.
SHELL = sh
CC = AVR-gcc
OBJCOPY = AVR-objcopy
OBJDUMP = AVR-objdump
SIZE = AVR-size
AVRDUDE = AVRdude
REMOVE = rm -f
COPY = cp
HEXSIZE = $(SIZE) --target=$(FORMAT) $(TARGET).hex
#ELFSIZE = $(SIZE) -A $(TARGET).elf
ELFSIZE = $(SIZE) $(TARGET).elf
FINISH = echo Errors: none
BEGIN = echo -------- begin --------
END = echo -------- end --------
# Define all object files.
OBJ = $(SRC:.c=.o) $(ASRC:.S=.o)
# Define all listing files.
LST = $(ASRC:.S=.lst) $(SRC:.c=.lst)
# Combine all necessary flags and optional flags.
# Add target processor to flags.
ALL_CFLAGS = -mmcu=$(MCU) -I. $(CFLAGS)
ALL_ASFLAGS = -mmcu=$(MCU) -I. -x assembler-with-cpp $(ASFLAGS)
# Default target.
all: begin gccversion sizebefore $(TARGET).elf $(TARGET).hex $(TARGET).eep \
$(TARGET).lss sizeafter finished end
# Eye CANdy.
# AVR Studio 3.x does not check make's exit code but relies on
# the following magic strings to be generated by the compile job.
begin:
@$(BEGIN)
finished:
@$(FINISH)
end:
@$(END)
# Display size of file.
sizebefore:
@if [ -f $(TARGET).elf ]; then echo Size before:; $(ELFSIZE);fi
sizeafter:
@if [ -f $(TARGET).elf ]; then echo Size after:; $(ELFSIZE);fi
# Display compiler version information.
gccversion :
$(CC) --version
# Convert ELF to COFF for use in debugging / simulating in
# AVR Studio or VMLAB.
COFFCONVERT=$(OBJCOPY) --debugging \
--change-section-address .data-0x800000 \
--change-section-address .bss-0x800000 \
--change-section-address .noinit-0x800000 \
--change-section-address .eeprom-0x810000
coff: $(TARGET).elf
$(COFFCONVERT) -O coff-AVR $< $(TARGET).cof
extcoff: $(TARGET).elf
$(COFFCONVERT) -O coff-ext-AVR $< $(TARGET).cof
# Program the device. The magic trickery below examines the .eep hex
# file whether the size is > 0, and if so, reprograms the EEPROM as
# well. Just delete these lines if you don't want this feature (like
# on the ATmegas with the EESAVE fuse bit set).
program: $(TARGET).hex $(TARGET).eep
$(AVRDUDE) $(AVRDUDE_FLAGS) $(AVRDUDE_ERASE)
$(AVRDUDE) $(AVRDUDE_FLAGS) -i $(TARGET).hex
@$(SIZE) --target=$(FORMAT) $(TARGET).eep | while read line; \
do \
set -- $$line; \
if [ "x$$1" != "x0" ] ; then continue; fi; \
if [ "$$2" -ne 0 ] ; then \
echo $(AVRDUDE) $(AVRDUDE_FLAGS) -m eeprom -i $(TARGET).eep; \
break; \
fi; \
done
# Create final output files (.hex, .eep) from ELF output file.
%.hex: %.elf
$(OBJCOPY) -O $(FORMAT) -R .eeprom $< $@
%.eep: %.elf
-$(OBJCOPY) -j .eeprom --set-section-flags=.eeprom="alloc,load" \
--change-section-lma .eeprom=0 -O $(FORMAT) $< $@
# Create extended listing file from ELF output file.
%.lss: %.elf
$(OBJDUMP) -h -S $< > $@
# Link: create ELF output file from object files.
.SECONDARY : $(TARGET).elf
.PRECIOUS : $(OBJ)
%.elf: $(OBJ)
$(CC) $(ALL_CFLAGS) $(OBJ) --output $@ $(LDFLAGS)
# Compile: create object files from C source files.
%.o : %.c
$(CC) -c $(ALL_CFLAGS) $< -o $@
# Compile: create assembler files from C source files.
%.s : %.c
$(CC) -S $(ALL_CFLAGS) $< -o $@
# Assemble: create object files from assembler source files.
%.o : %.S
$(CC) -c $(ALL_ASFLAGS) $< -o $@
# Target: clean project.
clean: begin clean_list finished end
clean_list :
$(REMOVE) $(TARGET).hex
$(REMOVE) $(TARGET).eep
$(REMOVE) $(TARGET).obj
$(REMOVE) $(TARGET).cof
$(REMOVE) $(TARGET).elf
$(REMOVE) $(TARGET).map
$(REMOVE) $(TARGET).a90
$(REMOVE) $(TARGET).sym
$(REMOVE) $(TARGET).lnk
$(REMOVE) $(TARGET).lss
$(REMOVE) $(OBJ)
$(REMOVE) $(LST)
$(REMOVE) $(SRC:.c=.s)
$(REMOVE) $(SRC:.c=.d)
# Automatically generate C source code dependencies.
# (Code originally taken from the GNU make user manual and modified
# (See README.txt Credits).)
# Note that this will work with sh (bash) and sed that is shipped with WinAVR
# (see the SHELL variable defined above).
# This may not work with other shells or other seds.
%.d: %.c
set -e; $(CC) -MM $(ALL_CFLAGS) $< \
| sed 's,\(.*\)\.o[ :]*,\1.o \1.d : ,g' > $@; \
[ -s $@ ] || rm -f $@
# Remove the '-' if you want to see the dependency files generated.
-include $(SRC:.c=.d)
# Listing of phony targets.
.PHONY : all begin finish end sizebefore sizeafter gccversion coff extcoff \
clean clean_list program
答 4: 确实是这样感谢 笑苍天、yfzhang。
我也试过了,那个MAKEFILE是WINAVR里的示例,改时没有注意。
我很抱歉,GCC及它的爱好者们!
在硬件上运行结果相同。
gcc优化级为 s
结果让我十分苦恼
你的Makefile中
改为
#LDFLAGS += -lm
可视情况添加或删减链接库文件
# On command line:
# 4.07 or greater).
# MCU name
MCU = at90s8535
FORMAT = ihex
TARGET = demo
OPT = s
SRC = $(TARGET).c
#SRC += foo.c bar.c
#SRC += baz.c \
#xyzzy.c
ASRC =
LDFLAGS += -lm
# dt006 bascom alf
AVRDUDE_ERASE = -e
DIRAVR = c:/winAVR
DIRINC = .
SHELL = sh
CC = AVR-gcc
SIZE = AVR-size
AVRDUDE = AVRdude
REMOVE = rm -f
COPY = cp
# Default target.
# Eye CANdy.
begin:
@$(BEGIN)
finished:
@$(FINISH)
end:
@$(END)
sizebefore:
sizeafter:
gccversion :
$(CC) --version
coff: $(TARGET).elf
do \
set -- $$line; \
break; \
fi; \
done
%.hex: %.elf
%.eep: %.elf
%.lss: %.elf
.PRECIOUS : $(OBJ)
%.elf: $(OBJ)
%.o : %.c
%.s : %.c
%.o : %.S
clean_list :
$(REMOVE) $(OBJ)
$(REMOVE) $(LST)
%.d: %.c
我很抱歉,GCC及它的爱好者们!
硬核工程师专属补给计划——填盲盒 | |
“我踩过的那些坑”主题活动——第002期 | |
【EEPW电子工程师创研计划】技术变现通道已开启~ | |
【EEPW在线】E起听工程师的声音! | |
高校联络员开始招募啦!有惊喜!! | |
送您一块开发板,2025年“我要开发板活动”又开始了! |
