共4条
I2C 如何用普通I/O口模拟I2C功能?
我的问题是,对于不带I2C口的AVR单片机,如何用普通I/O口模拟I2C功能?我现在知道AVR的每位I/O口在使用都是要定义输入输出方向的。那对于I2C总线的SDA线,它既要输入又要输出数据,那么是不是在输出数据前,要先在DDRX里面定义成输出,输入时再改回来?或者,在输入时,不改变DDRX中的输出定义,而是直接读PINX的状态了?还望DX们指教。
答 1:
pls see atmel i2c demo;**** A P P L I C A T I O N N O T E A V R 3 0 0 ************************
;* Title : I2C (Single) Master Implementation
;* Version : 1.0 (BETA)
;* Last updated : 97.08.27
;* Target : AT90Sxxxx (any AVR device)
;* Support email : AVR@atmel.com
;* DESCRIPTION
;* Basic routines for communicating with I2C slave devices. This
;* "single" master implementation is limited to one bus master on the
;* I2C bus. Most applications do not need the multimaster ability
;* the I2C bus provides. A single master implementation uses, by far,
;* less resources and is less XTAL frequency dependent.
;* Some features :
;* * All interrupts are free, and CAN be used for other activities.
;* * Supports normal and fast mode.
;* * Supports both 7-bit and 10-bit addressing.
;* * Supports the entire AVR microcontroller family.
;* Main I2C functions :
;* 'i2c_start' - Issues a start condition and sends address
;* and transfer direction.
;* 'i2c_rep_start' - Issues a repeated start condition and sends
;* address and transfer direction.
;* 'i2c_do_transfer' - Sends or receives data depending on
;* direction given in address/dir byte.
;* 'i2c_stop' - Terminates the data transfer by issue a
;* stop condition.
;* USAGE
;* Transfer formats is described in the AVR300 documentation.
;* (An example is shown in the 'main' code).
;* NOTES
;* The I2C routines CAN be called either from non-interrupt or
;* interrupt routines, not both.
;* STATISTICS
;* Code Size : 81 words (maximum)
;* Register Usage : 4 High, 0 Low
;* Interrupt Usage : None
;* Other Usage : Uses two I/O pins on port D
;* XTAL Range : N/A
;**** Includes ****
.include "1200def.inc" ; change if an other device is used
;**** Global I2C Constants ****
.equ SCLP = 1 ; SCL Pin number (port D)
.equ SDAP = 0 ; SDA Pin number (port D)
.equ b_dir = 0 ; transfer direction bit in i2cadr
.equ i2crd = 1
.equ i2cwr = 0
;**** Global Register Variables ****
.def i2cdelay= r16 ; Delay loop variable
.def i2cdata = r17 ; I2C data transfer register
.def i2cadr = r18 ; I2C address and direction register
.def i2cstat = r19 ; I2C bus status register
;**** Interrupt Vectors ****
rjmp RESET ; Reset handle
; ( rjmp EXT_INT0 ) ; ( IRQ0 handle )
; ( rjmp TIM0_OVF ) ; ( Timer 0 overflow handle )
; ( rjmp ANA_COMP ) ; ( Analog comparator handle )
;* FUNCTION
;* i2c_hp_delay
;* i2c_qp_delay
;* DESCRIPTION
;* hp - half i2c clock period delay (normal: 5.0us / fast: 1.3us)
;* qp - quarter i2c clock period delay (normal: 2.5us / fast: 0.6us)
;* SEE DOCUMENTATION !!!
;* USAGE
;* no parameters
;* RETURN
;* none
i2c_hp_delay:
ldi i2cdelay,2
i2c_hp_delay_loop:
dec i2cdelay
brne i2c_hp_delay_loop
ret
i2c_qp_delay:
ldi i2cdelay,1
i2c_qp_delay_loop:
dec i2cdelay
brne i2c_qp_delay_loop
ret
;* FUNCTION
;* i2c_rep_start
;* DESCRIPTION
;* Assert repeated start condition and sends slave address.
;* USAGE
;* i2cadr - Contains the slave address and transfer direction.
;* RETURN
;* Carry flag - Cleared if a slave responds to the address.
;* NOTE
;* IMPORTANT! : This funtion must be directly followed by i2c_start.
i2c_rep_start:
sbi DDRD,SCLP ; force SCL low
cbi DDRD,SDAP ; release SDA
rcall i2c_hp_delay ; half period delay
cbi DDRD,SCLP ; release SCL
rcall i2c_qp_delay ; quarter period delay
;* FUNCTION
;* i2c_start
;* DESCRIPTION
;* Generates start condition and sends slave address.
;* USAGE
;* RETURN
;* NOTE
;* IMPORTANT! : This funtion must be directly followed by i2c_write.
i2c_start:
mov i2cdata,i2cadr ; copy address to transmitt register
sbi DDRD,SDAP ; force SDA low
;* FUNCTION
;* i2c_write
;* DESCRIPTION
;* Writes data (one byte) to the I2C bus. Also used for sending
;* the address.
;* USAGE
;* i2cdata - Contains data to be transmitted.
;* RETURN
;* Carry flag - Set if the slave respond transfer.
;* NOTE
;* IMPORTANT! : This funtion must be directly followed by i2c_get_ack.
i2c_write:
sec ; set carry flag
rol i2cdata ; shift in carry and out bit one
rjmp i2c_write_first
i2c_write_bit:
lsl i2cdata ; if transmit register empty
i2c_write_first:
breq i2c_get_ack ; goto get acknowledge
brcc i2c_write_low ; if bit high
nop ; (equalize number of cycles)
rjmp i2c_write_high
i2c_write_low: ; else
rjmp i2c_write_high ; (equalize number of cycles)
i2c_write_high:
rjmp i2c_write_bit
;* FUNCTION
;* i2c_get_ack
;* DESCRIPTION
;* Get slave acknowledge response.
;* USAGE
;* (used only by i2c_write in this version)
;* RETURN
;* Carry flag - Cleared if a slave responds to a request.
i2c_get_ack:
i2c_get_ack_wait:
sbis PIND,SCLP ; wait SCL high
;(In case wait states are inserted)
rjmp i2c_get_ack_wait
clc ; clear carry flag
sbic PIND,SDAP ; if SDA is high
ret
;* FUNCTION
;* i2c_do_transfer
;* DESCRIPTION
;* Executes a transfer on bus. This is only a combination of i2c_read
;* and i2c_write for convenience.
;* USAGE
;* i2cadr - Must have the same direction as when i2c_start was called.
;* see i2c_read and i2c_write for more information.
;* RETURN
;* (depends on type of transfer, read or write)
;* NOTE
;* IMPORTANT! : This funtion must be directly followed by i2c_read.
i2c_do_transfer:
sbrs i2cadr,b_dir ; if dir = write
rjmp i2c_write ; goto write data
;* FUNCTION
;* i2c_read
;* DESCRIPTION
;* Reads data (one byte) from the I2C bus.
;* USAGE
;* Carry flag - If set no acknowledge is given to the slave
;* indicating last read operation before a STOP.
;* If cleared acknowledge is given to the slave
;* indicating more data.
;* RETURN
;* i2cdata - Contains received data.
;* NOTE
;* IMPORTANT! : This funtion must be directly followed by i2c_put_ack.
i2c_read:
rol i2cstat ; store acknowledge
; (used by i2c_put_ack)
ldi i2cdata,0x01 ; data = 0x01
i2c_read_bit: ; do
rol i2cdata ; store data bit
brcc i2c_read_bit ; while receive register not full
;* FUNCTION
;* i2c_put_ack
;* DESCRIPTION
;* Put acknowledge.
;* USAGE
;* (used only by i2c_read in this version)
;* RETURN
;* none
i2c_put_ack:
ror i2cstat ; get status bit
brcc i2c_put_ack_low ; if bit low goto assert low
rjmp i2c_put_ack_high
i2c_put_ack_low: ; else
i2c_put_ack_high:
i2c_put_ack_wait:
rjmp i2c_put_ack_wait
ret
;* FUNCTION
;* i2c_stop
;* DESCRIPTION
;* Assert stop condition.
;* USAGE
;* No parameters.
;* RETURN
;* None.
i2c_stop:
ret
;* FUNCTION
;* i2c_init
;* DESCRIPTION
;* Initialization of the I2C bus interface.
;* USAGE
;* Call this function once to initialize the I2C bus. No parameters
;* are required.
;* RETURN
;* None
;* NOTE
;* PORTD and DDRD pins not used by the I2C bus interface will be
;* set to Hi-Z (!).
;* COMMENT
;* This function CAN be combined with other PORTD initializations.
i2c_init:
clr i2cstat ; clear I2C status register (used
; as a temporary register)
out PORTD,i2cstat ; set I2C pins to open colector
out DDRD,i2cstat
ret
;* PROGRAM
;* main - Test of I2C master implementation
;* DESCRIPTION
;* Initializes I2C interface and shows an example of using it.
RESET:
main: rcall i2c_init ; initialize I2C interface
;**** Write data => Adr(00) = 0x55 ****
ldi i2cadr,$A0+i2cwr ; Set device address and write
rcall i2c_start ; Send start condition and address
ldi i2cdata,$00 ; Write word address (0x00)
rcall i2c_do_transfer ; Execute transfer
ldi i2cdata,$55 ; Set write data to 01010101b
rcall i2c_stop ; Send stop condition
;**** Read data => i2cdata = Adr(00) ****
ldi i2cadr,$A0+i2crd ; Set device address and read
rcall i2c_rep_start ; Send repeated start condition and address
sec ; Set no acknowledge (read is followed by a stop condition)
rcall i2c_do_transfer ; Execute transfer (read)
rcall i2c_stop ; Send stop condition - releases bus
rjmp main ; Loop forewer
;**** End of File ****
答 2: 谢谢david1234!收到,谢谢拉。
;* DESCRIPTION
;* Some features :
;* stop condition.
;* USAGE
;* NOTES
;* STATISTICS
;* XTAL Range : N/A
;**** Includes ****
.equ i2crd = 1
.equ i2cwr = 0
;* FUNCTION
;* i2c_hp_delay
;* i2c_qp_delay
;* DESCRIPTION
;* USAGE
;* no parameters
;* RETURN
;* none
i2c_hp_delay:
ldi i2cdelay,2
i2c_hp_delay_loop:
dec i2cdelay
ret
i2c_qp_delay:
ldi i2cdelay,1
i2c_qp_delay_loop:
dec i2cdelay
ret
;* FUNCTION
;* i2c_rep_start
;* DESCRIPTION
;* USAGE
;* RETURN
;* NOTE
i2c_rep_start:
;* FUNCTION
;* i2c_start
;* DESCRIPTION
;* USAGE
;* RETURN
;* NOTE
i2c_start:
;* FUNCTION
;* i2c_write
;* DESCRIPTION
;* the address.
;* USAGE
;* RETURN
;* NOTE
i2c_write:
i2c_write_bit:
i2c_write_first:
rjmp i2c_write_high
i2c_write_high:
rjmp i2c_write_bit
;* FUNCTION
;* i2c_get_ack
;* DESCRIPTION
;* USAGE
;* RETURN
i2c_get_ack:
i2c_get_ack_wait:
ret
;* FUNCTION
;* i2c_do_transfer
;* DESCRIPTION
;* USAGE
;* RETURN
;* NOTE
i2c_do_transfer:
;* FUNCTION
;* i2c_read
;* DESCRIPTION
;* USAGE
;* RETURN
;* NOTE
i2c_read:
i2c_read_bit: ; do
;* FUNCTION
;* i2c_put_ack
;* DESCRIPTION
;* Put acknowledge.
;* USAGE
;* RETURN
;* none
i2c_put_ack:
i2c_put_ack_high:
i2c_put_ack_wait:
ret
;* FUNCTION
;* i2c_stop
;* DESCRIPTION
;* USAGE
;* No parameters.
;* RETURN
;* None.
i2c_stop:
ret
;* FUNCTION
;* i2c_init
;* DESCRIPTION
;* USAGE
;* are required.
;* RETURN
;* None
;* NOTE
;* set to Hi-Z (!).
;* COMMENT
i2c_init:
out DDRD,i2cstat
ret
;* PROGRAM
;* DESCRIPTION
RESET:
共4条
