共4条
我用的是atmel128,用了3个定时器,定时器1和0都好用,同样的设置定时器3就进不了定时中断,中断我也开了,就是进不了,郁闷,还请大侠指点。
程序如下:
#pragma interrupt_handler timer3_ovf_isr:30
void timer3_ovf_isr(void)
//TIMER3 has overflowed
WDR();
TCNT3H = 0xAB; //reload counter high value
TCNT3L = 0xA0; //reload counter low value
time3_count++;
WDR();
void timer3_init(void)
WDR();
time3_count=0;
TCCR3B = 0x00; //stop
TCNT3H = 0xAB; //setup
TCNT3L = 0xA0;
OCR3AH = 0x54;
OCR3AL = 0x60;
OCR3BH = 0x54;
OCR3BL = 0x60;
OCR3CH = 0x54;
OCR3CL = 0x60;
ICR3H = 0x54;
ICR3L = 0x60;
TCCR3A = 0x00;
TCCR3B = 0x05; //start Timer
WDR();
void main()
setbit(TIMSK,TOIE3); //定时器3溢出中断使能
} 答 1: 没设全局中断吧!没设全局中断吧。sei(); 答 2: 你直接拿ICC的向导写算了。 答 3: 仔细看看TOIE3在哪个寄存器再说!错: setbit(TIMSK,TOIE3); //定时器3溢出中断使能
程序如下:
WDR();
time3_count++;
WDR();
WDR();
time3_count=0;
TCNT3L = 0xA0;
OCR3AH = 0x54;
OCR3AL = 0x60;
OCR3BH = 0x54;
OCR3BL = 0x60;
OCR3CH = 0x54;
OCR3CL = 0x60;
ICR3H = 0x54;
ICR3L = 0x60;
TCCR3A = 0x00;
WDR();
void main()
共4条
| 为遥控小车巧添功能被打赏¥26元 | |
