am29lv160dt,flash am29lv160dt flash 擦除
am29lv160dt flash 擦除某一sector时怎么全片都擦除了
这是下面的代码,请高手看看有没有写错。
void flash_erase(P_U16 base_addr){
P_U16 Temp;
U32 i=35000000;
/* Issue the Sector Erase command to am29lv160dt */
Temp = (P_U16)((0x0000555<<1)+FLASH_ADDRESS); *Temp = 0xAA;
Temp = (P_U16)((0x00002AA<<1)+FLASH_ADDRESS); *Temp = 0x55;
*Temp = 0x80;
*Temp = 0xAA;
*Temp = 0x55;
Temp = base_addr;
*Temp = 0x30;
while(i--);//Delay
} 答 1: 有没有人用过个flash呢有没有人用过个flash呢 答 2: re:woaini看看我的擦除操作:
#define WRITE_FLASH(uiAddr,usData) *((volatile INT16U *)(uiAddr << 1))= usData
void bSST39VF160SectorErase(INT32U uiAddr)
WRITE_FLASH(0x5555, 0xAA);
WRITE_FLASH(0x2AAA, 0x55);
WRITE_FLASH(0x5555, 0x80);
WRITE_FLASH(uiAddr, 0x30);
bWaitForEndOfPrg();//判断是否写入完成函数
答 3: SST39VF160 的我的程序也可以用在SST39VF160的是可以的.
但在am29lv160dt就不行,代码如下:
void bAM29VF160SectorErase(INT32U uiAddr)
WRITE_FLASH(0x555, 0xAA);
WRITE_FLASH(0x2AA, 0x55);
WRITE_FLASH(0x555, 0x80);
} 答 4: 我用过没问题啊//--------------------------------
//Erase all data on chip
void chip_erase( void )
SFRPAGE = 0x0F ;
CE_H() ;
WE_H() ;
OE_H() ;
out_byte( 0xAAA, 0xAA );
out_byte( 0x555, 0x55 );
out_byte( 0xAAA, 0x80 );
out_byte( 0xAAA, 0x10 );
wait_ready1();
//Erase a sector
void sec_erase( ulong addre )
SFRPAGE = 0x0F ;
CE_H() ;
WE_H() ;
OE_H() ;
out_byte( addre, 0x30 );
wait_ready2();
这是下面的代码,请高手看看有没有写错。
P_U16 Temp;
U32 i=35000000;
*Temp = 0x80;
*Temp = 0xAA;
*Temp = 0x55;
Temp = base_addr;
*Temp = 0x30;
while(i--);//Delay
SFRPAGE = 0x0F ;
CE_H() ;
WE_H() ;
OE_H() ;
wait_ready1();
//Erase a sector
SFRPAGE = 0x0F ;
CE_H() ;
WE_H() ;
OE_H() ;
wait_ready2();
