44BLIB,nbsp,nbsp 各位大哥,请您帮我看看这段段 44BLIB.C 代码,谢谢!
* NAME : 44BLIB.C *
#include "44b.h"
#include "44blib.h"
#include "def.h"
#include "option.h"
#include <stdarg.h>
#include <string.h>
#include <stdlib.h>
#include <stdio.h>
#include <ctype.h>
#define STACKSIZE 0xa00 //SVC satck size(do not use user stack)
#define HEAPEND (_ISR_STARTADDRESS-STACKSIZE-0x500) // = 0xc7ff000
//SVC Stack Area:0xc(e)7ff000-0xc(e)7ffaff
extern char Image$$RW$$Limit[];
void *mallocPt=Image$$RW$$Limit;
void Port_Init(void)
//ADB V1.0 B/D Status
//USB D12SUSPD
// PC0
//LED D0 D1 D2
// PC1 PC2 PC3
//KEY K0 K1 K2 K3
// PG4 PG5 PG6 PG7
//CAUTION:Follow the configuration order for setting the ports.
// 1) setting value
// 2) setting control register
// 3) configure pull-up resistor.
//16bit data bus configuration
//PORT A GROUP
//rPCONA[9:0]
//|BIT9 |.......................................................|BIT0
//|ADDR24|ADDR23|ADDR22|ADDR21|ADDR20|ADDR19|ADDR18|ADDR17|ADDR16|ADDR0
//| 0| 1| 1| 1| 1| 1| 1| 1| 1| 1
rPCONA=0x1ff;
//PORT B GROUP
//rPCONB[10:0]
//|BIT10|....................................................|BIT0
//|nGCS5|nGCS4|nGCS3|nGCS2|nGCS1|nWBE3|nWBE2|nSRAS|nSCAS|SCLK|SCKE
//| 1| 1| 1| 1| 1| 1| 1| 1| 1| 1| 1
rPDATB=0x3ff;
rPCONB=0x3ff;
//PORT C GROUP
//BUSWIDTH=16
//PORT C GROUP
//rPCONC[31:0]
//|GPC15|....................................................................| GPC0
//|BIT31|....................................................................| BIT0
//|nCTS0|nRTS0|RXD1|TXD1|nCTS1|nRTS1|nEL|nDISP|VD4|VD6|VD5|VD7|LED2|LED1|LED0|D12SUSPD
//| 00| 00| 11| 11| 00| 00| 01| 01| 11| 11| 11| 11| 01| 01| 01| 01
//rPUPC[15:0]
//| 0| 0| 1| 1| 0| 0| 0| 0| 1| 1| 1| 1| 0| 0| 0| 0
rPDATC=0xffff; //All I/O Is High
rPCONC=0x0f05ff55;
rPUPC=0x30f0; //PULL UP RESISTOR should be enabled to I/O
//PORT D GROUP
//rPCOND
//| BIT15|.........................|BIT0
//|VFRAME|VM|VLINE|VCLK|VD3|VD2|VD1|VD0
//| 10|10| 10| 10| 10| 10| 10| 10
rPDATD=0xff;
rPCOND= 0x0;
rPUPD = 0x0;
//These pins must be set only after CPU's internal LCD controller is enable
//rPCOND=0xaaaa;
//rPUPD=0xff;
//PORT E GROUP
//rPCONE
//| BIT17 |..............................|BIT0
//|CODECLK|PE7|PE6|BEEP|PE4|PE3|RXD0|TXD0| PE0
//| 10| 01| 01| 01| 01| 01| 10| 10| 00
//|rPUPE[7:0]
// | 0| 0| 0| 0| 0| 1| 1| 0
rPDATE=0x1ff; //All I/O Is High
rPCONE=0x25568; //All NC is INPUT
rPUPE=0x0ff; //PE8 do not have programmable pull-up resistor.
//PORT F GROUP
//rPCONF[21:0]
//| BIT21|....................................| BIT0
//|IISCLK|PF7|IISDO|IISLRCK|PF4|PF3|PF2|IICSDA|IICSCL
//| 100|000| 100| 100| 00| 00| 00| 10| 10
//rPUPF[8:0]
//| 1| 0| 1| 1| 0| 0| 0| 1| 1
rPDATF=0x1ff; //All I/O Is High
rPCONF=0x20900a;//All NC is INPUT
rPUPF=0x163;
//PORT G GROUP
//rPCONG[15:0]
//|BIT15|....................................| BIT0
//| KEY3|KEY2|KEY1|KEY0|EXINT3|EXINT2|NET_INT|USB_INT
//| 11| 11| 11| 11| 11| 11| 11| 11
rPDATG=0xff;
rPCONG=0x00ff; //KEY0~KEY3定义为I/O,采用查询方式
//rPCONG=0xffff,KEY0~KEY3定义为中断,
rPUPG=0x0; //should be enabled
rSPUCR=0x7; //D15-D0 pull-up disable
rEXTINT=0x0; //All EXTINT0-7 Low level interrupt
//Define the Non_Cache area
rNCACHBE0=(((Non_Cache_End)>>12)<<16)|((Non_Cache_Start)>>12);
各位大哥:
问题1:
这两句话分别定义的什么?
问题2:
rPCONA=0x1ff; 定义的是什么?
问题3:
rPDATB=0x3ff;
rPCONB=0x3ff;
分别定义的是什么呢?
问题4:
rPCONC=0x0f05ff55;
rPUPC=0x30f0;
分别定义的是什么呢?
问题5:
rPDATD=0xff;
rPCOND= 0x0;
rPUPD = 0x0;
分别定义的是什么呢?
问题6:
分别定义的是什么啊?
问题8:
44BLIB.C
这段程序的主要目的是什么啊?
谢谢各位大哥! 答 1: 各位老大,小弟在期望啊~~各位老大,小弟在期望啊~~
答 2: 我晕死了你不说这是应用在什么上面的程序
鬼才晓得是干什么的 答 3: re:javie :
这是我买的开发板给的一个测试程序(按键测试程序)
其中的一段小程序! 答 4: 大哥啊你的开发板上的芯片是什么系列的啊?
三星的?
不过这种测试程序经常是很难看懂的
答 5: 不是吧,这个看不懂?就是44b的寄存器设置啊。主要是GPIO的主要是gpio的功能选择,内部上拉选择,初始电平设置等。另外,除了问题1,其他的不是“定义”,是赋值。问题1分别是堆栈大小和栈顶地址。 答 6: 太感谢 zkking 和 javie 了~~太感谢 zkking 和 javie 了~~!
懂拉~
* NAME : 44BLIB.C *
#include "44b.h"
#include "44blib.h"
#include "def.h"
#include "option.h"
#include <stdarg.h>
#include <string.h>
#include <stdlib.h>
#include <stdio.h>
#include <ctype.h>
//USB D12SUSPD
// PC0
//LED D0 D1 D2
// PC1 PC2 PC3
//KEY K0 K1 K2 K3
// PG4 PG5 PG6 PG7
// 1) setting value
//PORT A GROUP
//rPCONA[9:0]
rPCONA=0x1ff;
//PORT B GROUP
//rPCONB[10:0]
rPDATB=0x3ff;
rPCONB=0x3ff;
//PORT C GROUP
//BUSWIDTH=16
//PORT C GROUP
//rPCONC[31:0]
//rPUPC[15:0]
rPCONC=0x0f05ff55;
//PORT D GROUP
//rPCOND
rPDATD=0xff;
rPCOND= 0x0;
rPUPD = 0x0;
//rPCOND=0xaaaa;
//rPUPD=0xff;
//PORT E GROUP
//rPCONE
//|rPUPE[7:0]
//PORT F GROUP
//rPCONF[21:0]
//rPUPF[8:0]
rPUPF=0x163;
//PORT G GROUP
//rPCONG[15:0]
rPDATG=0xff;
各位大哥:
问题1:
这两句话分别定义的什么?
问题2:
问题3:
rPDATB=0x3ff;
rPCONB=0x3ff;
分别定义的是什么呢?
问题4:
rPCONC=0x0f05ff55;
rPUPC=0x30f0;
分别定义的是什么呢?
问题5:
rPDATD=0xff;
rPCOND= 0x0;
rPUPD = 0x0;
分别定义的是什么呢?
问题6:
分别定义的是什么啊?
问题8:
44BLIB.C
这段程序的主要目的是什么啊?
三星的?
不过这种测试程序经常是很难看懂的
懂拉~
| 为遥控小车巧添功能被打赏¥26元 | |
