1620 这是我的1620驱动程序,可就是调不通,大侠们看看阿
#include "config.h"
#define rs 0x04
#define rw 0x08
#define ep 0x10
uint32 P0;
uint8 dis1[] = {"welcome!"};
uint8 dis2[] = {"www.willar.com"};
void DelayNS(uint32 dly)
{ uint32 i;
for(; dly>0; dly--)
for(i=0; i<1; i++);
void delay(uint8 ms)
{ // 延时子程序
uint8 i;
while(ms--)
for(i = 0; i< 250; i++)
DelayNS(0);
DelayNS(0);
uint32 lcd_status()
uint32 i;
i=IO0PIN;
i=i>>5;
i=i & 0xFF;
return i;
uint8 lcd_bz()
{ // 测试LCD忙碌状态
uint8 result;
IO0CLR=rs;
IO0SET=rw|ep;
DelayNS(0);
DelayNS(0);
P0=lcd_status();
result = (uint8)(P0 & 0x80);
IO0CLR=ep;
return result;
void lcd_wcmd(uint32 cmd)
{ // 写入指令数据到LCD
uint32 Ncmd;
Ncmd=~cmd;
Ncmd=Ncmd & 0xFF;
cmd=cmd<<5;
Ncmd=Ncmd<<5;
while(lcd_bz());
IO0CLR=rs|rw|ep;
DelayNS(0);
IO0SET=cmd;
IO0CLR=Ncmd;
DelayNS(0);
DelayNS(0);
IO0SET=ep;
DelayNS(0);
DelayNS(0);
IO0CLR=ep;
void lcd_pos(uint8 pos)
{ //设定显示位置
lcd_wcmd(pos | 0x80);
void lcd_wdat(uint32 dat)
{ //写入字符显示数据到LCD
uint32 Ndat;
while(lcd_bz());
Ndat=~dat;
Ndat=Ndat & 0xFF;
dat=dat<<5;
Ndat=Ndat<<5;
IO0SET=rs;
IO0CLR=rw | ep;
IO0SET=dat;
IO0CLR=Ndat;
Ndat=IO0SET;
DelayNS(0);
DelayNS(0);
IO0SET=ep;
DelayNS(0);
DelayNS(0);
IO0CLR=ep;
void lcd_init(void)
{ //LCD初始化设定
lcd_wcmd(0x38); //
delay(1);
lcd_wcmd(0x0C); //
delay(1);
lcd_wcmd(0x06); //
delay(1);
lcd_wcmd(0x01); //清除LCD的显示内容
delay(1);
int main (void)
{// add user source code
uint8 i;
PINSEL0 = 0x00000000;
PINSEL1 = 0x00000000; // 设置管脚连接,P0.16设置为EINT0,P0.20设置为EINT3
IO0DIR=0x1FFC;
lcd_init(); // 初始化LCD
delay(10);
lcd_pos(4); // 设置显示位置为第一行的第5个字符
i = 0;
// while(dis1[i] != '\0')
// { // 显示字符"welcome!"
lcd_wdat(0x27);
// i++;
lcd_pos(0x41); // 设置显示位置为第二行第二个字符
// i = 0;
// while(dis2[i] != '\0')
lcd_wdat(0x27); // 显示字符" www.willar.com "
// i++;
while(1);
return 0;
答 1: ```````````我用的是EasyARM2119大侠们救救我
#define rs 0x04
#define rw 0x08
#define ep 0x10
uint32 P0;
{ uint32 i;
for(; dly>0; dly--)
for(i=0; i<1; i++);
{ // 延时子程序
uint8 i;
while(ms--)
DelayNS(0);
DelayNS(0);
uint32 lcd_status()
uint32 i;
i=IO0PIN;
i=i>>5;
i=i & 0xFF;
return i;
uint8 lcd_bz()
{ // 测试LCD忙碌状态
uint8 result;
IO0CLR=rs;
IO0SET=rw|ep;
DelayNS(0);
DelayNS(0);
P0=lcd_status();
IO0CLR=ep;
return result;
{ // 写入指令数据到LCD
uint32 Ncmd;
Ncmd=~cmd;
Ncmd=Ncmd & 0xFF;
cmd=cmd<<5;
Ncmd=Ncmd<<5;
while(lcd_bz());
IO0CLR=rs|rw|ep;
DelayNS(0);
IO0SET=cmd;
IO0CLR=Ncmd;
DelayNS(0);
DelayNS(0);
IO0SET=ep;
DelayNS(0);
DelayNS(0);
IO0CLR=ep;
{ //设定显示位置
{ //写入字符显示数据到LCD
uint32 Ndat;
while(lcd_bz());
Ndat=~dat;
Ndat=Ndat & 0xFF;
dat=dat<<5;
Ndat=Ndat<<5;
IO0SET=rs;
IO0CLR=rw | ep;
IO0SET=dat;
IO0CLR=Ndat;
Ndat=IO0SET;
DelayNS(0);
DelayNS(0);
IO0SET=ep;
DelayNS(0);
DelayNS(0);
IO0CLR=ep;
void lcd_init(void)
{ //LCD初始化设定
lcd_wcmd(0x38); //
delay(1);
lcd_wcmd(0x0C); //
delay(1);
lcd_wcmd(0x06); //
delay(1);
delay(1);
int main (void)
uint8 i;
IO0DIR=0x1FFC;
delay(10);
i = 0;
lcd_wdat(0x27);
// i++;
// i = 0;
// i++;
while(1);
return 0;
