8019,ARP,UDP,ICMP,TCP 怪!我的8019驱动为什么能收ARP,UDP包,却收不到ICMP TCP呢?
在44b0+ucos下做lwip的移植,问题多多啊!
我也不知道怎么搞得,奇怪了,我的8019驱动为什么能收ARP,UDP包,却收不到ICMP 和TCP包!!
ARP已经通了,而中断对icmp (ping)和tcp (telnet)却不理??我是用Ethereal抓的包。
各位碰到没有,帮我想想问题出在那儿了!!多谢!!
答 1: 同样是数据包,差距咋这么大呢!!即然能正确接收ARP UDP包,说明我的8019驱动应该是好的吧?怎么会有这种问题???
ping 172.16.4.15 这个ip不存在,发4个ARP包,都能接收并处理;
ping 17727 17727 当作主机名,发3个NBNS包,nbns是udp,能收到;
ping 172.16.4.18 8019 的ip,发4个ICMP包,网卡根本不中断;
telnet 172.16.4.18 7 发3个TCP包,没反应:(
兄弟们帮忙分析一下,想不通啊!!多谢
答 2: 把驱动源代码贴出,这样才好帮你改,这样说鬼知道是什么问题 答 3: 应该是软件问题,好好找找。 答 4: 是skyeye 杨晔的驱动驱动太长了,能把人看晕的
下面是8019中断的代码,我就在这里设断点,ARP UCP包能中断,而icmp和tcp就停不下来。????
void __irq ne2k_isr(void)
u8_t isr,curr,bnry;
struct netif *netif;
rI_ISPC =BIT_EINT1;
//close nic
//******************** add by maokor for debug ,2005.6.17*******
outb(CMD_PAGE2 | CMD_NODMA | CMD_STOP,NE_CR);
isr = inb(NE_IMR);
//*****************************************************888888
//in PAGE0
outb(CMD_PAGE0 | CMD_NODMA | CMD_STOP,NE_CR);
isr = inb(NE_ISR);
// ram overflow interrupt
if (isr & ISR_OVW) {
outb(ISR_OVW,NE_ISR); // clear interrupt
// ne2k_overflowProcess(); //yangye :no overflow now
// error transfer interrupt ,NIC abort tx due to excessive collisions
if (isr & ISR_TXE) {
outb(ISR_TXE,NE_ISR); // clear interrupt
//temporarily do nothing
// Rx error , reset BNRY pointer to CURR (use SEND PACKET mode)
if (isr & ISR_RXE) {
outb(ISR_RXE,NE_ISR); // clear interrupt
outb(CMD_PAGE1 | CMD_NODMA | CMD_STOP,NE_CR);
curr = inb(NE_CURR);
outb(curr, NE_BNRY);
//got packet with no errors
if (isr & ISR_PRX) {
outb(ISR_PRX, NE_ISR); // clear interrupt
outb(CMD_PAGE1 | CMD_NODMA | CMD_STOP, NE_CR);
outb(CMD_PAGE0 | CMD_NODMA | CMD_STOP, NE_CR);
bnry = inb(NE_BNRY);
//yangye 2003-1-21
//get more than one packet until receive buffer is empty
while(curr != bnry){
ne2k_recv_packet(rtl8019if_netif);
//Transfer complelte, do nothing here
if( isr & ISR_PTX){
PRINT("ne2k_isr: is ISR_PTX\n");
outb(ISR_PTX, NE_ISR); // clear interrupt
outb(0xff, NE_ISR); // clear ISR
//open nic for next packet
outb(CMD_PAGE0 | CMD_NODMA | CMD_RUN, NE_CR);
答 5: 8019 有bug,千万要注意可以参考linux下的驱动,那个是修正bug的,千万不要用没有经过实践验证的代码。 答 6: 啊!多谢各位回复!
wangkj:8019有bug?能具体说说吗,skyeye的驱动好像也有人移植成功过! 答 7: 可能是mac地址不对我对比了一下,发现这几种包的区别是目的mac不同,arp是广播的就能受到。难道是网卡的mac设置不对?
8019发送的arp回复包中的mac地址是直接读寄存器的还是程序设置的?怎么会错呢?
我把arp包贴出来,兄弟们帮我分析一下,另外这个包有校验错误(incorrect, should be 0xaf8108fa)不知哪里错了?
No. Time Source Destination Protocol Info
65 1436.867353 25:01:00:ea:5d:00 172.16.4.10 ARP 172.16.4.18 is at 25:01:00:ea:5d:00
Frame 65 (64 bytes on wire, 64 bytes captured)
Ethernet II, Src: 25:01:00:ea:5d:00, Dst: 00:05:5d:02:14:db
Destination: 00:05:5d:02:14:db (172.16.4.10)
Source: 25:01:00:ea:5d:00 (25:01:00:ea:5d:00)
Type: ARP (0x0806)
Trailer: 000000000000000000000000000000000000
Frame check sequence: 0xc4be25b7 (incorrect, should be 0xaf8108fa)
Address Resolution Protocol (reply)
Hardware type: Ethernet (0x0001)
Protocol type: IP (0x0800)
Hardware size: 6
Protocol size: 4
Opcode: reply (0x0002)
Sender MAC address: 25:01:00:ea:5d:00 (25:01:00:ea:5d:00)
Sender IP address: 172.16.4.18 (172.16.4.18)
Target MAC address: 00:05:5d:02:14:db (172.16.4.10)
Target IP address: 172.16.4.10 (172.16.4.10)
答 8: 发现mac地址没有正确保存,才错误发现个问题,帮我看看!
struct RTL8019if {
struct eth_addr *ethaddr;
packed struct eth_addr {
u8_t addr[6];
} PACK_STRUCT_STRUCT;
static void
low_level_init(struct netif * netif)
u8_t i, isr;
struct RTL8019if *rtl8019if,rtl8019;
u8_t mac_addr[6];
mac_addr[0]=inb(NE_PAR0);
mac_addr[1]=inb(NE_PAR1);
mac_addr[2]=inb(NE_PAR2);
mac_addr[3]=inb(NE_PAR3);
mac_addr[4]=inb(NE_PAR4);
mac_addr[5]=inb(NE_PAR5);
/* make up an address. */
rtl8019if->ethaddr->addr[0] = mac_addr[0];
rtl8019if->ethaddr->addr[1] = mac_addr[1];
rtl8019if->ethaddr->addr[2] = mac_addr[2];
rtl8019if->ethaddr->addr[3] = mac_addr[3];
rtl8019if->ethaddr->addr[4] = mac_addr[4];
rtl8019if->ethaddr->addr[5] = mac_addr[5];
rtl8019=*rtl8019if;
mac_addr数组读值正确 ,但是 赋值给rtl8019if->ethaddr->addr时没有成功,sdt中查看变量rtl8019值,只能看到->ethaddr是0x00000000。是数据结构packed的问题吗?多谢!
兄弟们帮忙分析一下,想不通啊!!多谢
u8_t isr,curr,bnry;
rI_ISPC =BIT_EINT1;
//close nic
isr = inb(NE_IMR);
//in PAGE0
isr = inb(NE_ISR);
//yangye 2003-1-21
if( isr & ISR_PTX){
Type: ARP (0x0806)
Hardware size: 6
Protocol size: 4
struct RTL8019if {
u8_t addr[6];
static void
u8_t i, isr;
u8_t mac_addr[6];
rtl8019=*rtl8019if;
| 为遥控小车巧添功能被打赏¥26元 | |
