mx31 谁准备用i.mx31,真猛啊
CPU Complex
ARM1136JF-S
128 KB L2 unified cache
Jazelle® Java acceleration
Vector floating point coprocessor (VFP)
Smart Speed Switch
Multimedia
VGA MPEG-4 HW encode
Graphics acceleration (i.MX31 only)
Image Processing Unit (IPU)
CMOS/CCD sensor interface
Resize, color space conversion
Deblocking, deringing, blending
Display/TV controller
External Memory Interface (EMI)
SDRAM 16/32-bit, 133 MHz
Mobile DDR 16/32-bit, 266 MHz
NAND Flash 8/16-bit
PSRAM
Advanced Power Management
Automatic Dynamic Voltage and Frequency Scaling (DVFS)
Dynamic Process Temperature Compensation (DPTC)
Active well-bias • Power gating Connectivity
High Speed USB OTG, 2 Hosts
2 x MMC/SD, 2 x Memory Stick ProTM
PCMCIA/CF
ATA-6 (HDD) interface
Audio MUX
IrDA, fast IrDA, keypad
Configuable SPI x 2, SSI/I2S x 2, UART x 5
Performance
CPU complex: starting at 532 MHz
System: 133 MHz @ 1.2V-1.6V (0.9V in Standby mode)
Technology
457 ball, 0.5 mm pitch MAPBGA
90 nm CMOS
答 1: reimx31比imx21多出ATA接口,MPEG4升级至VGA,主频提高到532,内核由ARM926ej-s升级到ARM1136JF-S,功能强大,适合game box等高短多媒体应用,我们公司已经出了imxl和imx21,imx31已在计划中。
ARM1136JF-S
Smart Speed Switch
Multimedia
NAND Flash 8/16-bit
PSRAM
PCMCIA/CF
Audio MUX
Performance
Technology
90 nm CMOS
硬核工程师专属补给计划——填盲盒 | |
“我踩过的那些坑”主题活动——第002期 | |
【EEPW电子工程师创研计划】技术变现通道已开启~ | |
【EEPW在线】E起听工程师的声音! | |
高校联络员开始招募啦!有惊喜!! | |
送您一块开发板,2025年“我要开发板活动”又开始了! |
