S3C44B0 求助:各位大大, S3C44B0 怎么播放音频,谢谢!
请教:
各位大哥,我买了块 44B0 的开发板,带音频输出,可是它给的测试代码只能在 RAM 里拨放拨放,我希望能在 flash 里拨放,各位大哥,那要代码要怎么写呢?还有 怎么把 *.wave 文件弄到 flash 里面去?
这是给的测试代码:
#include "44b.h"
#include "def.h"
#include "iis.h"
#include "utils.h"
typedef struct tWAVEFORMATEX{
U16 wFormatTag;
U16 nChannels;
U32 nSamplesPerSec;
U32 nAvgBytesPerSec;
U16 nBlockAlign;
U16 wBitsPerSample;
U16 cbSize;
}WAVEFORMATEX, *LPWAVEFORMATEX;
#define WAVE_FORMAT_PCM 0x0001
void __irq BDMA0_Done(void);
void Init_4334(void)
Function: 播放1M以下的wav文件,采用DMA方式
Input : addr----------wav文件起始地址
samplesize----wav文件长度
Return :
说明 :
void Play_SmallWave(U32 addr, U32 size)
unsigned char *pWave;
U32 samplesize;
U32 save_PLLCON;
// ChangePllValue(0x69,0x17,0x0); //MCLK=45.1584MHz <-- 5.6448MHz*8
save_PLLCON = rPLLCON;
rPLLCON = (0x69<<12)|(0x17<<4)|0;
SerialChgBaud(115200);
pISR_BDMA0=(unsigned)BDMA0_Done;
rINTMSK=~(BIT_GLOBAL|BIT_BDMA0);
pWave=(unsigned char *)addr;
pWave+=0x28; //指向wav采样长度
samplesize=*(pWave+0) | *(pWave+1)<<8 | *(pWave+2)<<16 | *(pWave+3)<<24;
pWave+=4; //指向wav数据
samplesize=(samplesize>>1)<<1;
printf("\nsample start:0x%x",pWave);
printf("\nsample size:0x%x",samplesize);
Init_4334();
/****** IIS Initialize ******/
rIISCON=0x22; //Tx DMA enable,Rx idle,prescaler enable
rIISMOD=0x89; //Master,Tx,L-ch=low,iis,16bit ch.,codeclk=256fs,lrck=32fs
// rIISPSR=0x11; //Prescaler_A/B enable, value=1
rIISPSR=0x33; //Prescaler_A/B enable, value=3
rIISFCON=0xa00; //Tx/Rx DMA,Tx/Rx FIFO --> start piling....
/****** BDMA0 Initialize ******/
rBDISRC0=(1<<30)+(1<<28)+(U32)pWave; //Half word,inc,pWave
rBDIDES0=(1<<30)+(3<<28)+((U32)rIISFIF); //M2IO,fix,IISFIF
rBDICNT0=(1<<30)+(1<<26)+(3<<22)+(1<<21)+(0<<20)+samplesize;
rBDICNT0 |= (1<<20);//enable
//iis,reserve,done_int,auto-reload/start,DMA enable,COUNT
rBDCON0 = 0x0<<2;
printf("\nNow play the wave file ...");
printf("\nPush any key to exit!!!");
/****** IIS Tx Start ******/
rIISCON |=0x1;
while(!getkey());
/****** IIS Tx Stop ******/
rIISCON=0x0; //IIS stop
rBDICNT0=0x0; //BDMA stop
rINTMSK=BIT_GLOBAL;
//ChangePllValue(136, 8, 1);//Fin=10MHz, Fout=72MHz
rPLLCON = save_PLLCON;
rI_ISPC=BIT_BDMA0; //clear pending bit
WrUTXH0('#');
Function: 播放1M以上的wav文件,采用normal方式
Return :
说明 :
void Play_BigWave(U32 addr, U32 size)
int i;
unsigned short *pSteroWave;
U32 samplesize,start;
U32 save_PLLCON;
LPWAVEFORMATEX pWav;
if(!download_len)
return;
pWav = (LPWAVEFORMATEX)(addr+0x14);
if(pWav->wFormatTag!=WAVE_FORMAT_PCM) {
puts("Supported PCM format only\n");
return;
if(pWav->nChannels!=2) {
puts("Support stereo wave only\n");
return;
printf("Sample rate =%dHz\n", pWav->nSamplesPerSec);
pWave+=4;
start=(U32)(unsigned char *)pWave; //指向wav数据
pSteroWave=(U16 *)start;
Init_4334();
rIISCON=0x02; //Tx DMA disable,Rx idle,prescaler enable
rIISFCON=0x200; //Tx/Rx normal,Tx FIFO enable--> start piling....
printf("\nPush ESC key to exit!!!");
rIISCON |=0x1;
while(getkey()!=ESC_KEY)
if(IIS_FIFOREADY)
for(i=0;i<8;i++)
*rIISFIF = *pSteroWave++;
// printf("\n0x%x:0x%x",pSteroWave,*pSteroWave);
if( ((U32)pSteroWave-start) > samplesize )
// printf("\n0x%x-0x%x=0x%x:0x%x",pSteroWave,start,((U32)pSteroWave-start),samplesize);
WrUTXH0('#');
SerialTxEmpty();
//ChangePllValue(0x2a,0x3,0x1);//Fin=10MHz, Fout=50MHz
void IISMain(void)
Play_BigWave(download_addr, download_len);
需要怎么修改啊?
谢谢! 答 1: 期待! 答 2: 找一下我的贴子找一下我的贴子, 标题里有一个"郁闷"
C语言中这样引用:
extern int welcome;
wave_play(&welcome);
wav文件使用汇编包含, 例如welcome.s
AREA wave, data, readonly
welcome
incbin welcome.wav
end
这是给的测试代码:
#include "44b.h"
#include "def.h"
#include "iis.h"
#include "utils.h"
U16 wFormatTag;
U16 nChannels;
U32 nSamplesPerSec;
U16 nBlockAlign;
U16 wBitsPerSample;
U16 cbSize;
Return :
说明 :
U32 samplesize;
U32 save_PLLCON;
pWave+=4; //指向wav数据
Init_4334();
rBDCON0 = 0x0<<2;
rIISCON |=0x1;
while(!getkey());
rINTMSK=BIT_GLOBAL;
WrUTXH0('#');
Return :
说明 :
int i;
U32 save_PLLCON;
if(!download_len)
return;
return;
return;
pWave+=4;
Init_4334();
rIISCON |=0x1;
if(IIS_FIFOREADY)
for(i=0;i<8;i++)
WrUTXH0('#');
SerialTxEmpty();
void IISMain(void)
需要怎么修改啊?
C语言中这样引用:
extern int welcome;
welcome
incbin welcome.wav
end
| 为遥控小车巧添功能被打赏¥26元 | |
