SPI,AT45DB081 关于SPI口和AT45DB081连接的问题!
#define SPIbaud 5000000 //5M
void Spi_iic(void)//初始化,对吗???
uint32 a;
SPI_SPCCR =8; //(Fpclk/SPIbaud)&0xfe; //时钟计数 7.5M
a =SPI_SPSR;
SPI_SPINT =1; //中断寄存器
SPI_SPCR =0x30; //控制寄存器,main mode
uint8 Read_AT_status(void)读状态读不出???
IOCLR = 1<<ATCS; //片选AT45DB161
while((SPIRW(0x57)&0x80)==0)DelayNS(1); //
IOSET = 1<<ATCS; //释放AT45DB161
return 1;
指点一下。芯片确保是好的 答 1: 放一段程序吧。读写没优化过,但保证能用INT8U AT45DBBuf[528];
static OS_EVENT* AT45DBSem;
void AT45DBInit(void)
#if OS_CRITICAL_METHOD == 3
OS_CPU_SR cpu_sr;
#endif
AT45DBSem = OSSemCreate(1);
OS_ENTER_CRITICAL();
PCONP |= 0x00000100;
PINSEL0 &= 0xFFFF00FF;
PINSEL0 |= 0x00005500;
IO0DIR |= AT45DB_CS;
IO0SET = AT45DB_CS;
OS_EXIT_CRITICAL();
void AT45DBRead(INT16U u16_page)
OS_CPU_SR cpu_sr;
#endif
INT16U u16_cnt;
INT8U u8_err;
OSSemPend(AT45DBSem,0,&u8_err);
S0PCR = 0x38;
S0PCCR = FPCLK/2000000*2;
IO0CLR = AT45DB_CS;
S0PDR = 0x52;
while(0 == (S0PSR&0x80));
S0PDR = (INT8U)(u16_page>>6);
S0PDR = ((INT8U)(u16_page))<<2;
S0PDR = 0x00;
S0PDR = 0x00;
S0PDR = 0x00;
S0PDR = 0x00;
S0PDR = 0x00;
for(u16_cnt=0;u16_cnt<528;u16_cnt++)
S0PDR = 0x00;
AT45DBBuf[u16_cnt] = S0PDR;
IO0SET = AT45DB_CS;
OS_EXIT_CRITICAL();
OSSemPost(AT45DBSem);
void AT45DBWrite(INT16U u16_page)
OS_CPU_SR cpu_sr;
#endif
INT16U u16_cnt;
INT8U u8_err;
S0PCR = 0x38;
IO0CLR = AT45DB_CS;
S0PDR = 0x82;
S0PDR = ( (INT8U)(u16_page))<<2;
S0PDR = 0x00;
S0PDR = AT45DBBuf[u16_cnt];
IO0SET = AT45DB_CS;
OS_EXIT_CRITICAL();
OSTimeDly(20);
} 答 2: 谢谢!我参考参考!
uint32 a;
a =SPI_SPSR;
return 1;
OS_CPU_SR cpu_sr;
#endif
IO0SET = AT45DB_CS;
OS_EXIT_CRITICAL();
OS_CPU_SR cpu_sr;
#endif
INT16U u16_cnt;
INT8U u8_err;
S0PCR = 0x38;
IO0CLR = AT45DB_CS;
S0PDR = 0x52;
S0PDR = 0x00;
S0PDR = 0x00;
S0PDR = 0x00;
S0PDR = 0x00;
S0PDR = 0x00;
S0PDR = 0x00;
IO0SET = AT45DB_CS;
OS_EXIT_CRITICAL();
OS_CPU_SR cpu_sr;
#endif
INT16U u16_cnt;
INT8U u8_err;
S0PCR = 0x38;
IO0CLR = AT45DB_CS;
S0PDR = 0x82;
S0PDR = 0x00;
IO0SET = AT45DB_CS;
OS_EXIT_CRITICAL();
OSTimeDly(20);
} 答 2: 谢谢!我参考参考!
【EEPW电子工程师创研计划】技术变现通道已开启~ | |
【EEPW在线】E起听工程师的声音! | |
“我踩过的那些坑”主题活动——第001期 | |
高校联络员开始招募啦!有惊喜!! | |
打赏了!打赏了!打赏了! |
打赏帖 | |
电流检测模块MAX4080S被打赏10分 | |
多组DCTODC电源方案被打赏50分 | |
【我踩过的那些坑】STM32cubeMX软件的使用过程中的“坑”被打赏50分 | |
新手必看!C语言精华知识:表驱动法被打赏50分 | |
【我踩过的那些坑】杜绑线问题被打赏50分 | |
【我踩过的那些坑】STM32的硬件通讯调试过程的“坑”被打赏50分 | |
【我踩过的那些坑】晶振使用的问题被打赏100分 | |
【我踩过的那些坑】电感选型错误导致的处理器连接不上被打赏50分 | |
【我踩过的那些坑】工作那些年踩过的记忆深刻的坑被打赏10分 |
