uclinux,web,boa 请教:uclinux下的web服务器boa的配置问题
我最近刚刚调试uclinux下的boa软件。设置了boa.conf文件,同时把它和mime.types放在/usr/web/下面,可是启动boa(boa -c /usr/web)之后,再windows下无法连接网页
,页面上显示:
HTTP 500 - 内部服务器错误
Internet Explorer
我的boa.conf文件内容如下:
# Boa v0.94 configuration file
# File format has changed little from 0.92
# version changes are noted in the comments
# The Boa configuration file is parsed with a lex/yacc or flex/bison
# generated parser. If it reports an error, the line number will be
# provided; it should be easy to spot. The syntax of each of these
# rules is very simple, and they CAN occur in any order. Where possible
# these directives mimic those of NCSA httpd 1.3; I saw no reason to
# introduce gratuitous differences.
# The "ServerRoot" is not in this configuration file. It CAN be compiled
# into the server (see defines.h) or specified on the command line with
# the -c option, for example:
# boa -c /usr/local/boa
# Port: The port Boa runs on. The default port for http servers is 80.
# If it is less than 1024, the server must be started as root.
Port 80
# User: The name or UID the server should run as.
# Group: The group name or GID the server should run as.
User 0
Group 0
# ServerAdmin: The email address where server problems should be sent.
# Note: this is not currently used.
#ServerAdmin root@localhost
# ErrorLog: The location of the error log file. If this does not start
# with /, it is considered relative to the server root.
# Set to /dev/null if you don't want errors logged.
#by hj ErrorLog /var/log/boa/error_log
#Errorlog /dev/null
# AccessLog: The location of the access log file. If this does not
# start with /, it is considered relative to the server root.
# Comment out or set to /dev/null (less effective) to disable
# Access logging.
#by hj AccessLog /var/log/boa/access_log
# RefererLog: The location of the referer log file. If this does not
# referer logging.
#by hj RefererLog /var/log/boa/referer_log
# AgentLog: The location of the agent log file. If this does not
# User-Agent logging.
#by hj AgentLog /var/log/boa/agent_log
# VerboseCGILogs: this is just a logical switch.
# Comment out to disable.
#VerboseCGILogs
# ServerName: the name of this server that should be sent back to
# clients if different than that returned by gethostname -- often
# this is www.foo.bar.
#ServerName www.your.org.here
#ServerName http://192.168.0.12
# DocumentRoot: The root directory of the HTML documents.
DocumentRoot /usr/web
# ChRoot: Boa root '/' directory. This is useful to improve security of
# your system. Don't forget that ALL DIRECTORIES used by boa except logs
# must be in this directory. If you need cgi scripts, you must copy shared
# libraries to this directory (see ldconfig(8) for more info)
#Chroot /var
# UserDir: The name of the directory which is appended onto a user's home
# directory if a ~user request is recieved.
UserDir public_html
# DirectoryIndex: Name of the file to use as a pre-written HTML
# directory index. Please MAKE AND USE THESE FILES. On the
# fly creation of directory indexes CAN be _slow_.
DirectoryIndex index.html
DirectoryMaker /usr/local/sbin/boa_indexer
# LocalCodepage: Local codepage. This is send to client in 'Content-Type:'
# header by default.
#LocalCodepage iso-8859-1
# Codepage: Load codepage conversion table from file. This table will be used
# on-the-fly conversion.
#Codepage us-ascii /usr/lib/boa/iso-8859-2/us-ascii
# CodepageByURL: Specify URL prefix codepage. This command is used for manual
# codepage selection. For example, http://www.cz.boa.org/asc/document.html
# converts /document.html to us-ascii
#CodepageByURL /asc us-ascii
# CodepageByBrowser: Specify codepage by $USER_AGENT. This command is used for
# automatic codepage selection. You CAN use characters '*' and '?' in browser
# string. For example, "CodepageByBrowser Lynx/* us-ascii" will send for Lynx
# users all documents in us-ascii.
#CodepageByBrowser Lynx/* us-ascii
# KeepAliveMax: Number of KeepAlive requests to allow per connection
# Comment out, or set to 0 to disable keepalive processing
KeepAliveMax 100
# KeepAliveTimeout: seconds to wait before keepalive connection times out
KeepAliveTimeout 10
# MimeTypes: This is the file that is used to generate mime type pairs
# and Content-Type fields for boa.
MimeTypes /usr/web/mime.types
# DefaultType: MIME type used if the file extension is unknown, or there
# is no file extension.
DefaultType text/plain
# AddType: adds types without editing mime.types
# Example: AddType type extension [extension ...]
# Uncomment the next line if you want .cgi files to execute from anywhere
AddType application/x-httpd-cgi cgi
# Redirect, Alias, and ScriptAlias all have the same semantics -- they
# match the beginning of a request and take appropriate action. Use
# Redirect for other servers, Alias for the same server, and ScriptAlias
# to enable directories for script execution.
# Redirect allows you to tell clients about documents which used to exist in
# your server's namespace, but do not anymore. This allows you to tell the
# clients where to look for the relocated document.
# Example: Redirect /bar http://elsewhere/feh/bar
# Aliases: Aliases one path to another.
# Example: Alias /path1/bar /path2/foo
#Alias /doc /usr/doc
# ScriptAlias: Maps a virtual path to a directory for serving scripts
# Example: ScriptAlias /htbin/ /www/htbin/
## by hj ScriptAlias /cgi-bin/ /usr/lib/cgi-bin/
ScriptAlias /cgi-bin/ /usr/web/cgi-bin/
# VirtualHost: Maps a virtual host to a directory.
# Example: VirtualHost cz.boa.org /html/htdocs/boa/
#VirtualHost www.second.company.com /var/www/second_company/
# Auth: HTTP Basic authorization. Format is "Auth <Directory> <PasswdFile>".
# Password file should be readable _ONLY_ by root or trusted user(s). This file
# is opened before boa gives out privs.
# Example: Auth /secret /var/www/secret.passwd
#Auth /internal /etc/internal.passwd
答 1: re自己顶
,页面上显示:
HTTP 500 - 内部服务器错误
Internet Explorer
我的boa.conf文件内容如下:
Port 80
User 0
Group 0
#Errorlog /dev/null
# Access logging.
# referer logging.
#VerboseCGILogs
#Chroot /var
UserDir public_html
KeepAliveMax 100
KeepAliveTimeout 10
答 1: re自己顶
| 2026年“我要开发板活动”第三季,开始了! | |
