at91sam7s64 at91sam7s64的程序问题求救!真心谢谢各位!!急!
我想问的是,AT91SAM7S64的I/O口平常输出的低电平吗?下面是我的程序!为什么我读按件的制没有起作用呢,我的目的是按一个键对应的LED亮,就这么简单,为什么LED一上电就一直亮,下面是我的程序!请知道的给我查下错误谢谢!
#include "AT91SAM7S64.h"
#include "Board.h"
unsigned int Key_Val;
unsigned int key;
int main(void)
unsigned int delay;
*AT91C_PMC_SCER = 1;
*AT91C_PMC_PCER = SW_MASK; //使能PIO口时钟
*AT91C_PIOA_PER = LED_MASK | SW_MASK;//使能4个LED与4个KEY脚I/O口功能
*AT91C_PIOA_OER = LED_MASK; //使能4个LED管脚的输出功能
*AT91C_PIOA_ODR = SW_MASK; //使能4个KEY管脚的输入功能
*AT91C_PIOA_PPUER = SW_MASK;
*AT91C_PIOA_IFER = SW_MASK;
while (1)
Key_Val = *AT91C_PIOA_PDSR;//注:读I/O口电平时,需使能PIO的时钟控制器寄存器(AT91C_PMC_PCER)
if (Key_Val & SW1)
*AT91C_PIOA_SODR = LED1;
else
*AT91C_PIOA_CODR = LED1;
if (Key_Val & SW2)
*AT91C_PIOA_SODR = LED2;
if (!(Key_Val & SW2))
*AT91C_PIOA_CODR = LED2;
if (Key_Val & SW3)
*AT91C_PIOA_SODR = LED3;
else
*AT91C_PIOA_CODR = LED3;
if (Key_Val & SW4)
*AT91C_PIOA_SODR = LED4;
else
*AT91C_PIOA_CODR = LED4;
还有一个串口程序,我感觉是对,用串口调试工具收码就是没有!能否帮我看下原因吗?程序如下:
#include "Board.h"
#define RXRDY (unsigned int) 0x1 //接收器准备好标志位,0为未接收到完整字符,1为接收器(US_RHR)有数据未被读取
#define TXRDY ((unsigned int) 0x1 << 1) //发送器准备好标志位,1为发送器(US_THR)内无数据
#define TXEMPTY ((unsigned int) 0x1 << 9) //发送器空标志位,1为发送器(US_THR)内无数据,复位时或USART禁止时此位为0,发送使能命令(US_CR中)可以将其置位
unsigned char RBuff[256];
unsigned char index;
int main(void)
unsigned int i;
unsigned int delay;
*AT91C_CKGR_MOR = 0x701; //使能主振荡器和设置起振时间,可以检查CKGR_MCFR(0xfffffc20)进行确认
*AT91C_PMC_MCKR = 0x01; //选择Mster Clock is main clock divided by 0,Processor Clock is the Mster Clock
*AT91C_PMC_PCKR = 0x11;
*AT91C_PMC_SCER = 0x1; //使能系统时钟寄存器的处理器时钟
*AT91C_PMC_PCDR = 0xffffffff; //禁止所有外围时钟
*AT91C_PMC_PCER = 0x60; //使能USART0时钟
*AT91C_PIOA_PDR = US_RXD_PIN | US_TXD_PIN | US_RTS_PIN | US_CTS_PIN;//禁止该两个管脚的I/O口功能
*AT91C_PIOA_ASR = US_RXD_PIN | US_TXD_PIN | US_RTS_PIN | US_CTS_PIN;//将该两个I/O口分配给外围A,即RXD0和TXD0
*AT91C_US0_CR = 0x10c; //复位接收器和发送器,使能接收与发送,复位状态位
*AT91C_US0_MR = 0x000008c0; //正常的UART模式,选择时钟为MCK,8位长度,无校验,1位停止位,
*AT91C_US0_IDR = 0xf3fff; //禁止所有UART相关的中断
*AT91C_US0_BRGR = 30; //Baudrate = SelectedClock/(8(2-Over)CD) = MCK/16CD = 18432000/(16*30) = 38400
//*AT91C_US0_CR = 0x15c;
*AT91C_US0_CR = 0x50; //使能发送与接收
index = 0;
*AT91C_US0_THR = 1;
while (1)
for (i = 0; i < 256; i++)
if ((*AT91C_US0_CSR) & TXEMPTY) //判断发送器是否为空
*AT91C_US0_THR = i; //空,则发送数据
for (delay = 0; delay < 0xfff; delay++);
/if ((*AT91C_US0_CSR) & RXRDY)
// RBuff[index++] = *AT91C_US0_RHR;
} 答 1: 怎么没有人回复呢?大家帮我看下好吗?程序问题
#include "Board.h"
unsigned int key;
int main(void)
unsigned int delay;
while (1)
if (Key_Val & SW1)
else
if (Key_Val & SW2)
if (Key_Val & SW3)
else
if (Key_Val & SW4)
else
#include "Board.h"
int main(void)
unsigned int i;
unsigned int delay;
index = 0;
*AT91C_US0_THR = 1;
while (1)
硬核工程师专属补给计划——填盲盒 | |
“我踩过的那些坑”主题活动——第002期 | |
【EEPW电子工程师创研计划】技术变现通道已开启~ | |
【EEPW在线】E起听工程师的声音! | |
高校联络员开始招募啦!有惊喜!! | |
送您一块开发板,2025年“我要开发板活动”又开始了! |
