Multi,ICE,XXX,ICE,LPC2000,MCU 请教用Multi-ICE或XXX-ICE调过LPC2000系列MCU的朋友!
我在使用techorICE V5调试LPC2000系列MCU时出现了Data Abort的错误。
调试环境如下: Windows2000 Profession + ADS V1.2 (build with 844 and 848)
硬件环境为 : 周立功的EasyARM2104板(板载LPC2106)/ Keil公司的MCB2130(板载LPC2138) + techorICE V5
调试例程全部用汇编写,如下:
; Code Section TargetInit
AREA TargetInit, CODE, READONLY
CODE32
ENTRY
Reset_Handler ; Reset handler
InitPLL ; ----- Setup PLL -----
IF (PLL_EN /= 0)
LDR R0, =PLL_BASE
MOV R1, #0xAA
MOV R2, #0x55
; Configure and enable PLL
LDR R3, =PLLCFG_VAL
STR R3, [R0, #PLLCFG_OFS]
MOV R3, #PLLCON_PLLE
STR R3, [R0, #PLLCON_OFS]
STR R1, [R0, #PLLFEED_OFS]
STR R2, [R0, #PLLFEED_OFS]
; Wait and PLL locked
PLL_Loop LDR R3, [R0, #PLLSTAT_OFS]
ANDS R3, R3, #PLLSTAT_PLOCK
BEQ PLL_Loop
; Switch to PLL clock
MOV R3, #(PLLCON_PLLE + PLLCON_PLLC)
ENDIF ; ----- End of Setup PLL -----
InitMAM ; ----- Setup MAM -----
IF (MAM_EN /= 0)
LDR R0, =MAM_BASE
MOV R1, #MAMTIM_VAL
STR R1, [R0, #MAMTIM_OFS]
MOV R1, #MAMCR_VAL
STR R0, [R0, #MAMCR_OFS]
ENDIF ; ----- End of Setup MAM -----
REMAP ; ----- Setup Interrupt Remap -----
IF (RAM_REMAP_EN /= 0)
MOV R0, #0x40000000
LDR R1, =Vectors
LDMIA R1!, {R2-R9}
STMIA R0!, {R2-R9}
LDMIA R1!, {R2-R9}
STMIA R0!, {R2-R9}
LDR R0, =MEMMAP ; Do remap
MOV R1, #0x02
STR R1, [R0]
ENDIF ; ----- End of Setup Interrupt Remap -----
InitStack ; ----- Setup Stack for Each Mode -----
MOV R0, LR
; Enter Supervisor mode and set its stack pointer
MSR CPSR_c, #(MODE_SVC :OR: CPSR_IRQ_BIT :OR: CPSR_FIQ_BIT)
LDR SP, Stack_SVC
; Enter IRQ mode and set its stack pointer
MSR CPSR_c, #(MODE_IRQ :OR: CPSR_IRQ_BIT :OR: CPSR_FIQ_BIT)
LDR SP, Stack_IRQ
; Enter FIQ mode and set its stack pointer
MSR CPSR_c, #(MODE_FIQ :OR: CPSR_IRQ_BIT :OR: CPSR_FIQ_BIT)
LDR SP, Stack_FIQ
; Enter Abort mode and set its stack pointer
MSR CPSR_c, #(MODE_ABT :OR: CPSR_IRQ_BIT :OR: CPSR_FIQ_BIT)
LDR SP, Stack_ABT
; Enter UNDEF mode and set its stack pointer
MSR CPSR_c, #(MODE_UND :OR: CPSR_IRQ_BIT :OR: CPSR_FIQ_BIT)
LDR SP, Stack_UND
; Enter User mode and set its stack pointer
MSR CPSR_c, #MODE_SYS
LDR SP, Stack_USR
MOV R0, #(MODE_USR :OR: CPSR_IRQ_BIT :OR: CPSR_FIQ_BIT)
IF (FIQ_EN = 1)
BIC R0, R0, #CPSR_FIQ_BIT
ENDIF
IF (IRQ_EN = 1)
BIC R0, R0, #CPSR_IRQ_BIT
ENDIF
MSR CPSR_c, R0
B .
Stack_USR DCD UsrStackSpace + (USR_Stack_Size - 1) * 4
Stack_SVC DCD SvcStackSpace + (SVC_Stack_Size - 1) * 4
Stack_IRQ DCD IrqStackSpace + (IRQ_Stack_Size - 1) * 4
Stack_FIQ DCD FiqStackSpace + (FIQ_Stack_Size - 1) * 4
Stack_ABT DCD AbtStackSpace + (ABT_Stack_Size - 1) * 4
Stack_UND DCD UndStackSpace + (UND_Stack_Size - 1) * 4
; Data Section MyStacks
AREA MyStacks, DATA, NOINIT, ALIGN = 3
UsrStackSpace SPACE USR_Stack_Size * 4
SvcStackSpace SPACE SVC_Stack_Size * 4
IrqStackSpace SPACE IRQ_Stack_Size * 4
FiqStackSpace SPACE FIQ_Stack_Size * 4
AbtStackSpace SPACE ABT_Stack_Size * 4
UndStackSpace SPACE UND_Stack_Size * 4
END
出现的问题是:如果首先用Multi-ICE Server或板上的复位按键复位系统,向AXD中Load调试映象文件后,调试时总是出现Data Abort的错误,AXD一句都调试不下去。我对照了ARM公司的Multi-ICE User Guide和我的仿真器供应商给出的FAQ,还是找不出原因。
一个细节的问题是:如果我的代码中使能了地址重映射,那么在首次将该代码load进入目标系统的RAM后退出AXD,再启动AXD并load该image后,便可以进行调试了;如果在代码中没有使能地址重映射,那么无论将对应的image载入多少次,都无法调试,错误都是Data Abort。
在此请教众位用过Multi-ICE或国产XXX-ICE的朋友,在调LPC2000时是否遇到过这个问题?
谢谢! 答 1: 说明一下!我的工程中已经设定了RW_BASE=0x40003000, RO_BASE = 0x40000040,映象文件也可以从ADS集成环境中成功载入到目标系统中,并且AXD调试器在载入映象后也没有报任何错误,可就是无法仿真下去! 答 2: 我用过ws-120调试过2129/2292,没碰见你说的问题啊!内部ram调试,用周立功的模板就可以的! 答 3: laoshan朋友能不能提供一下您的调试例程!lndlty55@yahoo.com.cn
谢谢! 答 4: 我下载了ZLG的模块,还是不行!2104和2100的都用了,不行!
我直接就用的是里面的asm for lpc2100的工程模块.同样的错误!
我的仿真器供应商说原厂的Multi-ICE也有这个问题,是真的吗?
调试例程全部用汇编写,如下:
CODE32
ENTRY
IF (PLL_EN /= 0)
LDR R0, =PLL_BASE
MOV R1, #0xAA
MOV R2, #0x55
LDR R3, =PLLCFG_VAL
BEQ PLL_Loop
IF (MAM_EN /= 0)
LDR R0, =MAM_BASE
MOV R1, #MAMTIM_VAL
MOV R1, #MAMCR_VAL
MOV R0, #0x40000000
LDR R1, =Vectors
LDMIA R1!, {R2-R9}
STMIA R0!, {R2-R9}
LDMIA R1!, {R2-R9}
STMIA R0!, {R2-R9}
MOV R1, #0x02
STR R1, [R0]
MOV R0, LR
LDR SP, Stack_SVC
LDR SP, Stack_IRQ
LDR SP, Stack_FIQ
LDR SP, Stack_ABT
LDR SP, Stack_UND
LDR SP, Stack_USR
IF (FIQ_EN = 1)
ENDIF
IF (IRQ_EN = 1)
ENDIF
MSR CPSR_c, R0
B .
END
| 为遥控小车巧添功能被打赏¥26元 | |
