AT29LV160 一个AT29LV160的程序,非常简单!
/* This file is part of the ARM Toolchain package */
/* Copyright KEIL ELEKTRONIK GmbH 2003 - 2004 */
/* FlashDev.C: Flash Programming Functions adapted */
/* for AM29F160DT (16-bit Bus) */
#include "..\FlashOS.H" // FlashOS Structures
#define M8(adr) (*((volatile unsigned char *) (adr)))
#define M16(adr) (*((volatile unsigned short *) (adr)))
#define M32(adr) (*((volatile unsigned long *) (adr)))
#define STACK_SIZE 64 // Stack Size
union fsreg { // Flash Status Register
struct b {
unsigned int q0:1;
unsigned int q1:1;
unsigned int q2:1;
unsigned int q3:1;
unsigned int q4:1;
unsigned int q5:1;
unsigned int q6:1;
unsigned int q7:1;
} b;
unsigned int v;
} fsr;
unsigned long base_adr;
* Check if Program/Erase completed
* Parameter: adr: Block Start Address
* Return Value: 0 - OK, 1 - Failed
int Polling (unsigned long adr) {
unsigned int q6;
fsr.v = M16(adr);
q6 = fsr.b.q6;
do {
fsr.v = M16(adr);
if (fsr.b.q6 == q6) return (0); // Done
q6 = fsr.b.q6;
} while (fsr.b.q5 == 0); // Check for Timeout
fsr.v = M16(adr);
q6 = fsr.b.q6;
fsr.v = M16(adr);
M16(adr) = 0xF0; // Reset Device
return (1); // Failed
* Initialize Flash Programming Functions
* Parameter: adr: Device Base Address
* clk: Clock Frequency (Hz)
int Init (unsigned long adr, unsigned long clk) {
base_adr = adr;
return (0);
* De-Initialize Flash Programming Functions
int UnInit (void) {
return (0);
* Erase complete Flash Memory
int EraseChip (void) {
// Start Chip Erase Command
M16(base_adr + 0xAAA) = 0xAA;
M16(base_adr + 0x554) = 0x55;
M16(base_adr + 0xAAA) = 0x80;
M16(base_adr + 0xAAA) = 0x10;
return (Polling(base_adr)); // Wait until Erase completed
* Erase Sector in Flash Memory
* Parameter: adr: Sector Address
int EraseSector (unsigned long adr) {
// Start Erase Sector Command
M16(adr) = 0x30;
do {
fsr.v = M16(adr);
} while (fsr.b.q3 == 0); // Wait for Sector Erase Timeout
return (Polling(adr)); // Wait until Erase completed
* Program Page in Flash Memory
* Parameter: adr: Page Start Address
* sz: Page Size
* buf: Page Data
int ProgramPage (unsigned long adr, unsigned long sz, unsigned char *buf) {
int i;
for (i = 0; i < ((sz+1)/2); i++) {
// Start Program Command
M16(base_adr + 0xAAA) = 0xA0;
M16(adr) = *((unsigned short *) buf);
if (Polling(adr) != 0) return (1);
buf += 2;
adr += 2;
return (0);
/* FlashDev.C: Device Description for AM29F160DT (16-bit Bus) */
struct FlashDevice const FlashDevice = {
FLASH_DRV_VERS, // Driver Version, do not modify!
"AM29F160DT Flash", // Device Name
EXT16BIT, // Device Type
0x000000, // Device Start Address
0x200000, // Device Size in Bytes (2MB)
1024, // Programming Page Size
0, // Reserved, must be 0
0xFF, // Initial Content of Erased Memory
100, // Program Page Timeout 100 mSec
3000, // Erase Sector Timeout 3000 mSec
// Specify Size and Address of Sectors
0x10000, 0x000000, // Sector Size 64kB (31 Sectors)
0x08000, 0x1F0000, // Sector Size 32kB (1 Sector)
0x02000, 0x1F8000, // Sector Size 8kB (2 Sectors)
0x04000, 0x1FC000, // Sector Size 16kB (1 Sector)
SECTOR_END
答 1: regood!
struct b {
unsigned int q0:1;
unsigned int q1:1;
unsigned int q2:1;
unsigned int q3:1;
unsigned int q4:1;
unsigned int q5:1;
unsigned int q6:1;
unsigned int q7:1;
} b;
unsigned int v;
} fsr;
unsigned int q6;
fsr.v = M16(adr);
q6 = fsr.b.q6;
do {
fsr.v = M16(adr);
q6 = fsr.b.q6;
fsr.v = M16(adr);
q6 = fsr.b.q6;
fsr.v = M16(adr);
base_adr = adr;
return (0);
int UnInit (void) {
return (0);
M16(adr) = 0x30;
do {
fsr.v = M16(adr);
* sz: Page Size
* buf: Page Data
int i;
buf += 2;
adr += 2;
return (0);
SECTOR_END
答 1: regood!
| 2026年“我要开发板活动”第三季,开始了! | |
