1/1															1							跳转至页
		ARM,ARTX,RealView ARM水鸟外部中断ARTX之RealView C++笔记
HotPower@126.com 2006.2.18 于西安大雁塔村队部
http://blog.21ic.com/blog.asp?name=hotpower
/* This file is part of the CA ARM C Compiler package */
/* Copyright KEIL ELEKTRONIK GmbH 2002 - 2004 */
/* MAIN.CPP: Demonstration of various interrupt functions */
#include <LPC213x.H> // Philips Peripheral Registers
#include <LPC213xDEF.H> //ARM菜鸟HotPower创建定义文件(最新为情人节修改版)
*具有特权保护的用户非向量中断,它只能在VICProtection=0时在用户模式下调用,比SWI更安全
extern "C"
void Undef_Handler(void) __irq{
if (VICIRQStatus & (unsigned long)(1 << VICIntSel_SoftInt31)) {
IOPIN1 ^= (1 << P1_19); //取反P1.19
EXTINT = (unsigned char)(1 << VICIntSel_SoftInt31); //清除VICIntSel_SoftInt31中断标志
VICSoftIntClr = (unsigned long)(1 << VICIntSel_SoftInt31);
VICVectAddr = 0;
extern "C"
void IRQ_Handler (void) __irq{//VICIntSelect=0且VICVectCntl0~VICVectCntl15都未中断使能
unsigned long temp;
temp = VICIRQStatus;
if (temp & (1 << VICIntSel_EINT0)) {
IOPIN1 ^= (1 << P1_16); //取反P1.16
EXTINT = (1 << EINT0); //清除INT0中断标志
else if (temp & (1 << VICIntSel_EINT1)) {
IOPIN1 ^= (1 << P1_17); //取反P1.17
while(EXTINT & (1 << EINT1)) {
EXTINT = (1 << EINT1); //清除INT1中断标志
else if (temp & (1 << VICIntSel_EINT2)) {
IOPIN1 ^= (1 << P1_18); //取反P1.18
EXTINT = (1 << EINT2); //清除INT2中断标志
else if (temp & (1 << VICIntSel_EINT3)) {
EXTINT = (1 << EINT3); //清除INT3中断标志
else {//其他干扰源
//再次填入干扰处理代码
VICSoftIntClr = temp;//抗击无效VICSoftInt=XXX的入侵
VICVectAddr = 0;
extern "C"
void EINT0IRQ (void) __irq{//IRQ中断函数EINT0IRQ被挂接在VICVectCntl0
__enable_irq();
if (VICIRQStatus & (1 << VICIntSel_EINT0)) {
VICSoftIntClr = (1 << VICIntSel_EINT0);
VICVectAddr = 0;
extern "C"
void EINT1IRQ (void) __irq{//IRQ中断函数EINT1IRQ被挂接在VICVectCntl1
if (VICIRQStatus & (1 << VICIntSel_EINT1)) {
IOSET1 = (1 << P1_17); //P1.17=1
IOCLR1 = (1 << P1_17); //P1.17=0
VICSoftIntClr = (1 << VICIntSel_EINT1);
VICVectAddr = 0;
extern "C"
void EINT2IRQ (void) __irq{//IRQ中断函数EINT2IRQ被挂接在VICVectCntl2
if (VICIRQStatus & (1 << VICIntSel_EINT2)) {
VICSoftIntClr = (1 << VICIntSel_EINT2);
VICVectAddr = 0;
extern "C"
void EINT3IRQ (void) __irq{//IRQ中断函数EINT3IRQ被挂接在VICVectCntl3
if (VICIRQStatus & (1 << VICIntSel_EINT3)) {
VICSoftIntClr = (1 << VICIntSel_EINT3);
VICVectAddr = 0;
extern "C"
void FIQ_Handler (void) __irq{//VICIntSelect非0
unsigned long temp;
temp = VICFIQStatus;
else {//其他干扰源
//再次填入干扰处理代码
VICVectAddr = 0;
extern "C" int __swi(0) myfunc1 (int i1, long i2);
extern "C" int __SWI_0 (int i1, long i2){
return (i1 / i2);
extern "C" int __swi(1) myfunc2 (int i1);
extern "C" int __SWI_1 (int i1) {
return (i1<<4);
extern "C" void __swi(2) SetVICProtection(unsigned long val);
extern "C" void __SWI_2 (unsigned long val){
VICProtection = val;//VICProtection可以随意置'1',但清'0'必须在管理模式下
extern "C" __inline void __enable_IRQ(void)
int tmp;
__asm
MRS tmp, SPSR
BIC tmp, tmp, #0x80
MSR SPSR_cxsf, tmp
extern "C" __inline void __disable_IRQ(void)
int tmp;
__asm
MRS tmp, SPSR
ORR tmp, tmp, #0x80
MSR SPSR_cxsf, tmp
extern "C" void __swi(3) Enable_IRQ(void);
extern "C" void __SWI_3 (void) {
__enable_IRQ();
extern "C" void __swi(4) Disable_IRQ(void);
extern "C" void __SWI_4 (void) {//最大的SWI数
__disable_IRQ();
注意:在Keil RealView编译器软中断SWI.S通用代码中应该进行以下设置
Artx_SETUP EQU 0;0-在非ARTX上运行 1-在ARTX上运行
Store_SPSR EQU 1;0-在非ARTX上可以修改I/F
; 1-在非ARTX上不可以修改I/F,即对Disable_IRQ()函数无效
Swi_COUNT EQU 4 + 1;__SWI_4(在ARTX时至少取Swi_COUNT=8+1)
int res;
int main (void)
for(int i =0; i < 10; i ++) {
IODIR1 = i;
// __enable_irq();//RV自带的只能在特权模式下使用
// __disable_irq();//RV自带的只能在特权模式下使用
Disable_IRQ();//关向量中断
__nop();//RV自带NOP
Enable_IRQ();//开向量中断
IODIR1 = (1 << P1_23) | (1 << P1_22) | (1 << P1_21) | (1 << P1_20)
|(1 << P1_19) | (1 << P1_18) | (1 << P1_17) | (1 << P1_16);//设置LED输出方式
PINSEL0 |= (P0_14_EINT1 << P0_14_PINSEL) //选择P0.14为INT1外部中断引脚
// | (P0_7_EINT2 << P0_7_PINSEL) //选择P0.7为INT2外部中断引脚
| (P0_15_EINT2 << P0_15_PINSEL); //选择P0.15为INT2外部中断引脚
// | (P0_9_EINT3 << P0_9_PINSEL) //选择P0.9也为INT3外部中断引脚
// | (P0_1_EINT0 << P0_1_PINSEL) //选择P0.1也为INT0外部中断引脚
// | (P0_3_EINT1 << P0_3_PINSEL); //选择P0.3也为INT1外部中断引脚
PINSEL1 |= (P0_16_EINT0 << P0_16_PINSEL) //选择P0.16为INT0外部中断引脚
| (P0_20_EINT3 << P0_20_PINSEL); //选择P0.20也为INT3外部中断引脚
// | (P0_30_EINT3 << P0_30_PINSEL);//选择P0.30也为INT3外部中断引脚(Keil仿真不了)
EXTPOLAR &= ~((1 << EXTPOLAR0) //INT0为低电平有效
| (1 << EXTPOLAR1) //INT1为低电平有效
| (1 << EXTPOLAR2) //INT2为低电平有效
| (1 << EXTPOLAR3));//INT3为低电平有效
EXTPOLAR |= (1 << EXTPOLAR0); //INT0为高电平有效
EXTMODE |= (1 << EXTMODE0) //设置INT0为边沿触发
| (1 << EXTMODE2) //设置INT2为边沿触发
| (1 << EXTMODE3);//设置INT3为边沿触发
EXTMODE &= ~(1 << EXTMODE1);//设置INT1为电平触发
VICVectCntl0 = VICIntSel_Enable//使能IRQ中断
| VICIntSel_EINT0;//获取EINT0的IRQ级别
VICVectAddr0 = (unsigned long) EINT0IRQ;//取INT0中断服务地址
VICVectCntl1 = VICIntSel_Enable//使能IRQ中断
| VICIntSel_EINT1;//获取EINT1的IRQ级别
VICVectAddr1 = (unsigned long)EINT1IRQ;//取INT1中断服务地址
VICVectCntl2 = VICIntSel_Enable//使能IRQ中断
| VICIntSel_EINT2;//获取EINT2的IRQ级别
VICVectAddr2 = (unsigned long)EINT2IRQ;//取INT2中断服务地址
VICVectCntl3 = VICIntSel_Enable//使能IRQ中断
| VICIntSel_EINT3;//获取EINT3的IRQ级别
VICVectAddr3 = (unsigned long)EINT3IRQ;//取INT3中断服务地址
VICVectCntl4 = VICIntSel_Enable//使能IRQ中断
| VICIntSel_SoftInt31;//获取VICIntSel_SoftInt31的IRQ级别
VICVectAddr4 = (unsigned long)Undef_Handler;//取VicInt31中断服务地址
// VICVectCntl0 &= ~VICIntSel_Enable;//放弃EINT0的IRQ级别,获取默认中断级别
// VICVectCntl1 &= ~VICIntSel_Enable;//放弃EINT1的IRQ级别,获取默认中断级别
// VICVectCntl2 &= ~VICIntSel_Enable;//放弃EINT2的IRQ级别,获取默认中断级别
// VICDefVectAddr = (long)IRQ_Handler;//取默认中断服务地址
VICIntSelect = 0;//全部中断为IRQ中断或默认中断
VICIntSelect = (1 << VICIntSel_EINT3); //设置EINT3为FIQ中断
VICIntSelect = (1 << VICIntSel_EINT0) //设置EINT0为FIQ中断
| (1 << VICIntSel_EINT1) //设置EINT1为FIQ中断
| (1 << VICIntSel_EINT2) //设置EINT2为FIQ中断
| (1 << VICIntSel_EINT3);//设置EINT2为FIQ中断
EXTINT = (1 << EINT0) | (1 << EINT1) | (1 << EINT2) | (1 << EINT3); //清除INT中断标志
// VICSoftIntClr = 0xffffffff;//清除所有软中断标志
VICSoftIntClr = (1 << VICIntSel_EINT0) //清除EINT0软中断标志
| (1 << VICIntSel_EINT1) //清除EINT1软中断标志
| (1 << VICIntSel_EINT2) //清除EINT2软中断标志
| (1 << VICIntSel_EINT3);//清除EINT3软中断标志
VICIntEnable = (1 << VICIntSel_EINT0) //使能EINT0中断
| (1 << VICIntSel_EINT1) //使能EINT1中断
| (1 << VICIntSel_EINT2) //使能EINT2中断
| (1 << VICIntSel_EINT3);//使能EINT3中断
VICIntEnable |= (unsigned long)(1 << VICIntSel_SoftInt31);//使能VICIntSel_SoftInt31中断
SetVICProtection(1);//打开特权保护,阻止VICSoftInt软中断
VICSoftInt = (1 << VICIntSel_EINT0);//(VICIntEnable & (1 << VICIntSel_EINT0))使能才能软中断
SetVICProtection(0);//关闭特权保护,允许VICSoftInt软中断
VICSoftInt = (1 << VICIntSel_EINT1);//(VICIntEnable & (1 << VICIntSel_EINT1))使能才能软中断
VICSoftInt = (1 << VICIntSel_EINT2);//(VICIntEnable & (1 << VICIntSel_EINT2))使能才能软中断
VICSoftInt = (1 << VICIntSel_EINT3);//(VICIntEnable & (1 << VICIntSel_EINT3))使能才能软中断
VICSoftInt = (unsigned long)(1 << VICIntSel_SoftInt31);//(VICIntEnable & (1 << VICIntSel_SoftInt31))使能才能软中断
res = myfunc1 (10, 2); // call SWI functions
res += myfunc2 (res);
while (1) { // endless loop
__nop();
答 1: 我怎么看好像和C一样啊?我怎么看好像和C一样啊? 答 2: 哈哈,只是不加C++的演示部分,主要为了测试通用SWI.S文件看看这个像吗??? 答 3: Store_SPSR=0/1时用Disable_IRQ()关向量中断的帖图这里今天晕图,给个链接吧...
extern "C"
VICVectAddr = 0;
extern "C"
unsigned long temp;
else {//其他干扰源
//再次填入干扰处理代码
VICVectAddr = 0;
extern "C"
__enable_irq();
VICVectAddr = 0;
extern "C"
VICVectAddr = 0;
extern "C"
VICVectAddr = 0;
extern "C"
VICVectAddr = 0;
extern "C"
unsigned long temp;
else {//其他干扰源
//再次填入干扰处理代码
VICVectAddr = 0;
return (i1 / i2);
return (i1<<4);
int tmp;
__asm
MRS tmp, SPSR
BIC tmp, tmp, #0x80
MSR SPSR_cxsf, tmp
int tmp;
__asm
MRS tmp, SPSR
ORR tmp, tmp, #0x80
MSR SPSR_cxsf, tmp
__enable_IRQ();
__disable_IRQ();
int res;
int main (void)
IODIR1 = i;
__nop();//RV自带NOP
__nop();
1/1															1							跳转至页
