213x 213x系列的头文件在哪里有下载?
答 1:
这个就行呀/***********************************************************************/
/* This file is part of the uVision/ARM development tools */
/* Copyright KEIL ELEKTRONIK GmbH 2002-2004 */
/* LPC213X.H: Header file for Philips LPC2132 / LPC2138 */
#ifndef __LPC213x_H
#define __LPC213x_H
/* Vectored Interrupt Controller (VIC) */
#define VICIRQStatus (*((volatile unsigned long *) 0xFFFFF000))
#define VICFIQStatus (*((volatile unsigned long *) 0xFFFFF004))
#define VICRawIntr (*((volatile unsigned long *) 0xFFFFF008))
#define VICIntSelect (*((volatile unsigned long *) 0xFFFFF00C))
#define VICIntEnable (*((volatile unsigned long *) 0xFFFFF010))
#define VICIntEnClr (*((volatile unsigned long *) 0xFFFFF014))
#define VICSoftInt (*((volatile unsigned long *) 0xFFFFF018))
#define VICSoftIntClr (*((volatile unsigned long *) 0xFFFFF01C))
#define VICProtection (*((volatile unsigned long *) 0xFFFFF020))
#define VICVectAddr (*((volatile unsigned long *) 0xFFFFF030))
#define VICDefVectAddr (*((volatile unsigned long *) 0xFFFFF034))
#define VICVectAddr0 (*((volatile unsigned long *) 0xFFFFF100))
#define VICVectAddr1 (*((volatile unsigned long *) 0xFFFFF104))
#define VICVectAddr2 (*((volatile unsigned long *) 0xFFFFF108))
#define VICVectAddr3 (*((volatile unsigned long *) 0xFFFFF10C))
#define VICVectAddr4 (*((volatile unsigned long *) 0xFFFFF110))
#define VICVectAddr5 (*((volatile unsigned long *) 0xFFFFF114))
#define VICVectAddr6 (*((volatile unsigned long *) 0xFFFFF118))
#define VICVectAddr7 (*((volatile unsigned long *) 0xFFFFF11C))
#define VICVectAddr8 (*((volatile unsigned long *) 0xFFFFF120))
#define VICVectAddr9 (*((volatile unsigned long *) 0xFFFFF124))
#define VICVectAddr10 (*((volatile unsigned long *) 0xFFFFF128))
#define VICVectAddr11 (*((volatile unsigned long *) 0xFFFFF12C))
#define VICVectAddr12 (*((volatile unsigned long *) 0xFFFFF130))
#define VICVectAddr13 (*((volatile unsigned long *) 0xFFFFF134))
#define VICVectAddr14 (*((volatile unsigned long *) 0xFFFFF138))
#define VICVectAddr15 (*((volatile unsigned long *) 0xFFFFF13C))
#define VICVectCntl0 (*((volatile unsigned long *) 0xFFFFF200))
#define VICVectCntl1 (*((volatile unsigned long *) 0xFFFFF204))
#define VICVectCntl2 (*((volatile unsigned long *) 0xFFFFF208))
#define VICVectCntl3 (*((volatile unsigned long *) 0xFFFFF20C))
#define VICVectCntl4 (*((volatile unsigned long *) 0xFFFFF210))
#define VICVectCntl5 (*((volatile unsigned long *) 0xFFFFF214))
#define VICVectCntl6 (*((volatile unsigned long *) 0xFFFFF218))
#define VICVectCntl7 (*((volatile unsigned long *) 0xFFFFF21C))
#define VICVectCntl8 (*((volatile unsigned long *) 0xFFFFF220))
#define VICVectCntl9 (*((volatile unsigned long *) 0xFFFFF224))
#define VICVectCntl10 (*((volatile unsigned long *) 0xFFFFF228))
#define VICVectCntl11 (*((volatile unsigned long *) 0xFFFFF22C))
#define VICVectCntl12 (*((volatile unsigned long *) 0xFFFFF230))
#define VICVectCntl13 (*((volatile unsigned long *) 0xFFFFF234))
#define VICVectCntl14 (*((volatile unsigned long *) 0xFFFFF238))
#define VICVectCntl15 (*((volatile unsigned long *) 0xFFFFF23C))
/* Pin Connect Block */
#define PINSEL0 (*((volatile unsigned long *) 0xE002C000))
#define PINSEL1 (*((volatile unsigned long *) 0xE002C004))
#define PINSEL2 (*((volatile unsigned long *) 0xE002C014))
/* General Purpose Input/Output (GPIO) */
#define IOPIN0 (*((volatile unsigned long *) 0xE0028000))
#define IOSET0 (*((volatile unsigned long *) 0xE0028004))
#define IODIR0 (*((volatile unsigned long *) 0xE0028008))
#define IOCLR0 (*((volatile unsigned long *) 0xE002800C))
#define IOPIN1 (*((volatile unsigned long *) 0xE0028010))
#define IOSET1 (*((volatile unsigned long *) 0xE0028014))
#define IODIR1 (*((volatile unsigned long *) 0xE0028018))
#define IOCLR1 (*((volatile unsigned long *) 0xE002801C))
/* Memory Accelerator Module (MAM) */
#define MAMCR (*((volatile unsigned char *) 0xE01FC000))
#define MAMTIM (*((volatile unsigned char *) 0xE01FC004))
#define MEMMAP (*((volatile unsigned char *) 0xE01FC040))
/* Phase Locked Loop (PLL) */
#define PLLCON (*((volatile unsigned char *) 0xE01FC080))
#define PLLCFG (*((volatile unsigned char *) 0xE01FC084))
#define PLLSTAT (*((volatile unsigned short*) 0xE01FC088))
#define PLLFEED (*((volatile unsigned char *) 0xE01FC08C))
/* VPB Divider */
#define VPBDIV (*((volatile unsigned char *) 0xE01FC100))
/* Power Control */
#define PCON (*((volatile unsigned char *) 0xE01FC0C0))
#define PCONP (*((volatile unsigned long *) 0xE01FC0C4))
/* External Interrupts */
#define EXTINT (*((volatile unsigned char *) 0xE01FC140))
#define INTWAKE (*((volatile unsigned char *) 0xE01FC144))
#define EXTMODE (*((volatile unsigned char *) 0xE01FC148))
#define EXTPOLAR (*((volatile unsigned char *) 0xE01FC14C))
/* Reset */
#define RSID (*((volatile unsigned char *) 0xE01FC180))
/* Code Security / Debugging */
#define CSPR (*((volatile unsigned char *) 0xE01FC184))
/* Timer 0 */
#define T0IR (*((volatile unsigned long *) 0xE0004000))
#define T0TCR (*((volatile unsigned long *) 0xE0004004))
#define T0TC (*((volatile unsigned long *) 0xE0004008))
#define T0PR (*((volatile unsigned long *) 0xE000400C))
#define T0PC (*((volatile unsigned long *) 0xE0004010))
#define T0MCR (*((volatile unsigned long *) 0xE0004014))
#define T0MR0 (*((volatile unsigned long *) 0xE0004018))
#define T0MR1 (*((volatile unsigned long *) 0xE000401C))
#define T0MR2 (*((volatile unsigned long *) 0xE0004020))
#define T0MR3 (*((volatile unsigned long *) 0xE0004024))
#define T0CCR (*((volatile unsigned long *) 0xE0004028))
#define T0CR0 (*((volatile unsigned long *) 0xE000402C))
#define T0CR1 (*((volatile unsigned long *) 0xE0004030))
#define T0CR2 (*((volatile unsigned long *) 0xE0004034))
#define T0CR3 (*((volatile unsigned long *) 0xE0004038))
#define T0EMR (*((volatile unsigned long *) 0xE000403C))
#define T0CTCR (*((volatile unsigned long *) 0xE0004070))
/* Timer 1 */
#define T1IR (*((volatile unsigned long *) 0xE0008000))
#define T1TCR (*((volatile unsigned long *) 0xE0008004))
#define T1TC (*((volatile unsigned long *) 0xE0008008))
#define T1PR (*((volatile unsigned long *) 0xE000800C))
#define T1PC (*((volatile unsigned long *) 0xE0008010))
#define T1MCR (*((volatile unsigned long *) 0xE0008014))
#define T1MR0 (*((volatile unsigned long *) 0xE0008018))
#define T1MR1 (*((volatile unsigned long *) 0xE000801C))
#define T1MR2 (*((volatile unsigned long *) 0xE0008020))
#define T1MR3 (*((volatile unsigned long *) 0xE0008024))
#define T1CCR (*((volatile unsigned long *) 0xE0008028))
#define T1CR0 (*((volatile unsigned long *) 0xE000802C))
#define T1CR1 (*((volatile unsigned long *) 0xE0008030))
#define T1CR2 (*((volatile unsigned long *) 0xE0008034))
#define T1CR3 (*((volatile unsigned long *) 0xE0008038))
#define T1EMR (*((volatile unsigned long *) 0xE000803C))
#define T1CTCR (*((volatile unsigned long *) 0xE0008070))
/* Pulse Width Modulator (PWM) */
#define PWMIR (*((volatile unsigned long *) 0xE0014000))
#define PWMTCR (*((volatile unsigned long *) 0xE0014004))
#define PWMTC (*((volatile unsigned long *) 0xE0014008))
#define PWMPR (*((volatile unsigned long *) 0xE001400C))
#define PWMPC (*((volatile unsigned long *) 0xE0014010))
#define PWMMCR (*((volatile unsigned long *) 0xE0014014))
#define PWMMR0 (*((volatile unsigned long *) 0xE0014018))
#define PWMMR1 (*((volatile unsigned long *) 0xE001401C))
#define PWMMR2 (*((volatile unsigned long *) 0xE0014020))
#define PWMMR3 (*((volatile unsigned long *) 0xE0014024))
#define PWMMR4 (*((volatile unsigned long *) 0xE0014040))
#define PWMMR5 (*((volatile unsigned long *) 0xE0014044))
#define PWMMR6 (*((volatile unsigned long *) 0xE0014048))
#define PWMCCR (*((volatile unsigned long *) 0xE0014028))
#define PWMCR0 (*((volatile unsigned long *) 0xE001402C))
#define PWMCR1 (*((volatile unsigned long *) 0xE0014030))
#define PWMCR2 (*((volatile unsigned long *) 0xE0014034))
#define PWMCR3 (*((volatile unsigned long *) 0xE0014038))
#define PWMEMR (*((volatile unsigned long *) 0xE001403C))
#define PWMPCR (*((volatile unsigned long *) 0xE001404C))
#define PWMLER (*((volatile unsigned long *) 0xE0014050))
/* Universal Asynchronous Receiver Transmitter 0 (UART0) */
#define U0RBR (*((volatile unsigned char *) 0xE000C000))
#define U0THR (*((volatile unsigned char *) 0xE000C000))
#define U0IER (*((volatile unsigned char *) 0xE000C004))
#define U0IIR (*((volatile unsigned char *) 0xE000C008))
#define U0FCR (*((volatile unsigned char *) 0xE000C008))
#define U0LCR (*((volatile unsigned char *) 0xE000C00C))
#define U0MCR (*((volatile unsigned char *) 0xE000C010))
#define U0LSR (*((volatile unsigned char *) 0xE000C014))
#define U0MSR (*((volatile unsigned char *) 0xE000C018))
#define U0SCR (*((volatile unsigned char *) 0xE000C01C))
#define U0DLL (*((volatile unsigned char *) 0xE000C000))
#define U0DLM (*((volatile unsigned char *) 0xE000C004))
/* Universal Asynchronous Receiver Transmitter 1 (UART1) */
#define U1RBR (*((volatile unsigned char *) 0xE0010000))
#define U1THR (*((volatile unsigned char *) 0xE0010000))
#define U1IER (*((volatile unsigned char *) 0xE0010004))
#define U1IIR (*((volatile unsigned char *) 0xE0010008))
#define U1FCR (*((volatile unsigned char *) 0xE0010008))
#define U1LCR (*((volatile unsigned char *) 0xE001000C))
#define U1MCR (*((volatile unsigned char *) 0xE0010010))
#define U1LSR (*((volatile unsigned char *) 0xE0010014))
#define U1MSR (*((volatile unsigned char *) 0xE0010018))
#define U1SCR (*((volatile unsigned char *) 0xE001001C))
#define U1DLL (*((volatile unsigned char *) 0xE0010000))
#define U1DLM (*((volatile unsigned char *) 0xE0010004))
/* I2C Interface 0 */
#define I20CONSET (*((volatile unsigned char *) 0xE001C000))
#define I20STAT (*((volatile unsigned char *) 0xE001C004))
#define I20DAT (*((volatile unsigned char *) 0xE001C008))
#define I20ADR (*((volatile unsigned char *) 0xE001C00C))
#define I20SCLH (*((volatile unsigned short*) 0xE001C010))
#define I20SCLL (*((volatile unsigned short*) 0xE001C014))
#define I20CONCLR (*((volatile unsigned char *) 0xE001C018))
/* I2C Interface 1 */
#define I21CONSET (*((volatile unsigned char *) 0xE005C000))
#define I21STAT (*((volatile unsigned char *) 0xE005C004))
#define I21DAT (*((volatile unsigned char *) 0xE005C008))
#define I21ADR (*((volatile unsigned char *) 0xE005C00C))
#define I21SCLH (*((volatile unsigned short*) 0xE005C010))
#define I21SCLL (*((volatile unsigned short*) 0xE005C014))
#define I21CONCLR (*((volatile unsigned char *) 0xE005C018))
/* SPI0 (Serial Peripheral Interface 0) */
#define S0SPCR (*((volatile unsigned char *) 0xE0020000))
#define S0SPSR (*((volatile unsigned char *) 0xE0020004))
#define S0SPDR (*((volatile unsigned char *) 0xE0020008))
#define S0SPCCR (*((volatile unsigned char *) 0xE002000C))
#define S0SPTCR (*((volatile unsigned char *) 0xE0020010))
#define S0SPTSR (*((volatile unsigned char *) 0xE0020014))
#define S0SPTOR (*((volatile unsigned char *) 0xE0020018))
#define S0SPINT (*((volatile unsigned char *) 0xE002001C))
/* SSP Controller */
#define SSPCR0 (*((volatile unsigned short* ) 0xE0068000))
#define SSPCR1 (*((volatile unsigned char * ) 0xE0068004))
#define SSPDR (*((volatile unsigned short* ) 0xE0068008))
#define SSPSR (*((volatile unsigned char * ) 0xE006800C))
#define SSPCPSR (*((volatile unsigned char * ) 0xE0068010))
#define SSPIMSC (*((volatile unsigned char * ) 0xE0068014))
#define SSPRIS (*((volatile unsigned char * ) 0xE0068018))
#define SSPMIS (*((volatile unsigned char * ) 0xE006801C))
#define SSPICR (*((volatile unsigned char * ) 0xE0068020))
#define SSPDMACR (*((volatile unsigned char * ) 0xE0068024))
/* Real Time Clock */
#define ILR (*((volatile unsigned char *) 0xE0024000))
#define CTC (*((volatile unsigned short*) 0xE0024004))
#define CCR (*((volatile unsigned char *) 0xE0024008))
#define CIIR (*((volatile unsigned char *) 0xE002400C))
#define AMR (*((volatile unsigned char *) 0xE0024010))
#define CTIME0 (*((volatile unsigned long *) 0xE0024014))
#define CTIME1 (*((volatile unsigned long *) 0xE0024018))
#define CTIME2 (*((volatile unsigned long *) 0xE002401C))
#define SEC (*((volatile unsigned char *) 0xE0024020))
#define MIN (*((volatile unsigned char *) 0xE0024024))
#define HOUR (*((volatile unsigned char *) 0xE0024028))
#define DOM (*((volatile unsigned char *) 0xE002402C))
#define DOW (*((volatile unsigned char *) 0xE0024030))
#define DOY (*((volatile unsigned short*) 0xE0024034))
#define MONTH (*((volatile unsigned char *) 0xE0024038))
#define YEAR (*((volatile unsigned short*) 0xE002403C))
#define ALSEC (*((volatile unsigned char *) 0xE0024060))
#define ALMIN (*((volatile unsigned char *) 0xE0024064))
#define ALHOUR (*((volatile unsigned char *) 0xE0024068))
#define ALDOM (*((volatile unsigned char *) 0xE002406C))
#define ALDOW (*((volatile unsigned char *) 0xE0024070))
#define ALDOY (*((volatile unsigned short*) 0xE0024074))
#define ALMON (*((volatile unsigned char *) 0xE0024078))
#define ALYEAR (*((volatile unsigned short*) 0xE002407C))
#define PREINT (*((volatile unsigned short*) 0xE0024080))
#define PREFRAC (*((volatile unsigned short*) 0xE0024084))
/* A/D Converter 0 (AD0) */
#define AD0CR (*((volatile unsigned long *) 0xE0034000))
#define AD0DR (*((volatile unsigned long *) 0xE0034004))
/* A/D Converter 1 (AD1) */
#define AD1CR (*((volatile unsigned long *) 0xE0060000))
#define AD1DR (*((volatile unsigned long *) 0xE0060004))
/* D/A Converter */
#define DACR (*((volatile unsigned long *) 0xE006C000))
/* Watchdog */
#define WDMOD (*((volatile unsigned char *) 0xE0000000))
#define WDTC (*((volatile unsigned long *) 0xE0000004))
#define WDFEED (*((volatile unsigned char *) 0xE0000008))
#define WDTV (*((volatile unsigned long *) 0xE000000C))
#endif // __LPC213x_H
答 2: 俺用的也是这个
#ifndef __LPC213x_H
#define __LPC213x_H
/* VPB Divider */
/* Power Control */
/* Reset */
/* Timer 0 */
/* Timer 1 */
/* D/A Converter */
/* Watchdog */
答 2: 俺用的也是这个
