共3条
usb,isp1581 usb isp1581调试遇到问题,请给予帮助。
我用LPC2214控制ISP1581,采用通用处理器连接方式。现在的问题是:ID能够读出来。上位机也提示了有USB设备插入,但是不识别。
调试发现:
1、如果D- D+上不串连电阻,上位机不能识别有USB出入,我加了20欧姆电阻后,上位机能够识别到有设备插入。
2、当单片机发现USB中断产生,读取USB的中断寄存器,发现始终为0。我怀疑是否USB初始化有问题,但是无法确定,希望大家给予帮助。
初始化程序如下:
void ISP1581_ResetDevice(void)
U_Mode |=0x80;
do
U_Mode =0x10;
U_Mode =0x00;
U_Mode =0x10;
delayMs(10);
if(U_ChipIDL==0x8151) //只识别一部分ID号,都识别也
break; //能通过
}while(1);
U_Mode |=0x8d;
U_IntConf=0x54;
U_IntEnH=0x00;
U_IntEnL=0x0d39;
USB_Init();
void USB_Init(void)
U_IntL = 0x0ffff;//ÇåÖжÏ
U_IntH = 0x0ffff;
U_TestMode = 0x00;
U_TestMode = 0x00;
U_EptIndex = 0x02;// ¶Ëµã1 OUT
U_EptPSize = 0x40;// 64
U_EptIndex = 0x03;// ¶Ëµã1 IN
U_EptIndex = 0x04;// ¶Ëµã2 OUT
U_EptPSize = 0x400;// 1024
U_EptIndex = 0x05;// ¶Ëµã2 IN
U_EptIndex = 0x06;// ¶Ëµã3 OUT
U_EptIndex = 0x07;// ¶Ëµã3 IN
U_EptType = 0x0017;
U_EptIndex = 0x03;// ¶Ëµã1 OUT
U_EptType = 0x0017;
U_EptIndex = 0x04;// ¶Ëµã1 IN
U_EptType = 0x0016;
U_EptIndex = 0x05;// ¶Ëµã2 OUT
U_EptType = 0x0016;
U_EptIndex = 0x06;// ¶Ëµã2 IN
U_EptType = 0x0015;
U_EptIndex = 0x07;// ¶Ëµã2 IN
U_EptType = 0x0015;
U_EptType |= 0x0800;
U_Adrss = 0x80;//¼¤»î USB µØÖ·0
USB中断处理程序
void USB_Task_Handler(void)
unsigned short IntrptStatueL,IntrptStatueH;
unsigned short len,j;
unsigned short temp;
IntrptStatueL = U_IntL; //
IntrptStatueH = U_IntH;
U0THR=IntrptStatueH>>8; //发送到串口,方便调试
while(!(U0LSR &0x40)); //
U0THR=IntrptStatueL;
U0THR=IntrptStatueL>>8;
U_IntL = IntrptStatueL;//ÇåÖжϱêÖ¾
U_IntH = IntrptStatueH;
发现串口接收到的是 0X00 0X00 0X00 0X00
然后就没有了中断信号。
答 1: 进展中断状态已经可以收到了,低16位的分别如下:
00 08 00 01 00 20 00 18 00 08 00 01 00 00 00 00 00 00 00 01 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 01 00 00 00 00 00 00 00 01 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 01 00 00 00 00 00 00 00 01 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 08 然后就没有发生中断了。没有枚举成功。有谁在做1581?
调试发现:
初始化程序如下:
U_Mode |=0x80;
do
U_Mode =0x10;
U_Mode =0x00;
U_Mode =0x10;
delayMs(10);
break; //能通过
}while(1);
U_Mode |=0x8d;
U_IntConf=0x54;
U_IntEnH=0x00;
U_IntEnL=0x0d39;
USB_Init();
void USB_Init(void)
U_IntH = 0x0ffff;
U_TestMode = 0x00;
U_TestMode = 0x00;
U_EptType = 0x0017;
U_EptType = 0x0017;
U_EptType = 0x0016;
U_EptType = 0x0016;
U_EptType = 0x0015;
U_EptType = 0x0015;
USB中断处理程序
然后就没有了中断信号。
共3条
| 2026年“我要开发板活动”第三季,开始了! | |
