easyarm2200 疑惑?easyarm2200开发板例子的修改
uCOS-II,根据开发板提供ex1_ARM修改,
修改mem_a.scf以及RelOutChip设置(选用mem_a.scf,入口地址0x80002000),JTAG设置(起始0x80002000,大小0x001FE000)后,将程序编译地址设置从0x80002000开始,调试时候却不能像未修改前那样运行,单步执行,在OSInit();的时候就跑不出来了,总是停在OSTaskSuspend ()里面的这几条语句上:
ptcb = OSTCBPrioTbl[prio];
if (ptcb == (OS_TCB *)0) {/* Task to suspend must exist */
OS_EXIT_CRITICAL();
return (OS_TASK_SUSPEND_PRIO);
请周公不吝指点!
mem_a.scf:
ROM_LOAD 0x80002000
ROM_EXEC 0x80002000
Startup.o (vectors, +First)
* (+RO)
IRAM 0x40000000
Startup.o (MyStacks)
STACKS_BOTTOM +0 UNINIT
Startup.o (StackBottom)
STACKS 0x40004000 UNINIT
Startup.o (Stacks)
ERAM 0x81000000
* (+RW,+ZI)
HEAP +0 UNINIT
Startup.o (Heap)
HEAP_BOTTOM 0x81080000 UNINIT
Startup.o (HeapTop)
} 答 1: 靠!你给我浮上去! 答 2: 周公怎么还不来! 答 3: 试试看,不敢保证对。IRAM 0x40000000
改成:
IRAM 0x40000040
OS_EXIT_CRITICAL();
请周公不吝指点!
mem_a.scf:
ROM_LOAD 0x80002000
ROM_EXEC 0x80002000
* (+RO)
IRAM 0x40000000
Startup.o (Stacks)
ERAM 0x81000000
* (+RW,+ZI)
HEAP +0 UNINIT
Startup.o (Heap)
Startup.o (HeapTop)
改成:
IRAM 0x40000040
