2132,MCU 大家好!我只想把2132当作一个高档MCU来用,我的问题见正文!
我如何设置启动?
我只想作一个高档的MCU来运行,没有嵌入式系统!
请问:
我如何设置启动?
以及如何做修改以及修改那里?
原文件如下:
;/****************************************Copyright (c)**************************************************
;** Guangzou ZLG-MCU Development Co.,LTD.
;** graduate school
;** http://www.zlgmcu.com
;**--------------File Info-------------------------------------------------------------------------------
;** File name: Startup.s
;** Last modified Date: 2004-09-17
;** Last Version: 1.0
;** Descriptions: The start up codes for LPC2100, including the initializing codes for the entry point of exceptions and the stacks of user tasks.
;** Every project should have a independent copy of this file for related modifications
;** Created by: Chenmingji
;** Created date: 2004-02-02
;** Version: 1.0
;** Descriptions: The original version
;** Modified by: Chenmingji
;** Modified date: 2004-09-17
;** Version: 1.01
;** Descriptions: Modified the bus setting to adapt for many common situations
;** Version: 1.02
;** Descriptions: Added codes to support the enciphering of the chip
;** Version: 1.04
;** Descriptions: Renewed the template, added codes to support more compilers
;** Modified by: Chenxibing
;** Modified date: 2004-12-09
;** Version: 1.05
;** Descriptions:
;define the stack size
;定义堆栈的大小
SVC_STACK_LEGTH EQU 0
FIQ_STACK_LEGTH EQU 0
IRQ_STACK_LEGTH EQU 256
ABT_STACK_LEGTH EQU 0
UND_STACK_LEGTH EQU 0
NoInt EQU 0x80
NoFIQ EQU 0x40
USR32Mode EQU 0x10
SVC32Mode EQU 0x13
SYS32Mode EQU 0x1f
IRQ32Mode EQU 0x12
FIQ32Mode EQU 0x11
IMPORT __use_no_semihosting_swi
;The imported labels
;引入的外部标号在这声明
IMPORT FIQ_Exception ;Fast interrupt exceptions handler 快速中断异常处理程序
IMPORT __main ;The entry point to the main function C语言主程序入口
IMPORT SysStation ;initialize the target board 目标板基本初始化
;The emported labels
;给外部使用的标号在这声明
EXPORT bottom_of_heap
EXPORT StackUsr
EXPORT Reset
EXPORT __user_initial_stackheap
CODE32
AREA vectors,CODE,READONLY
ENTRY
;interrupt vectors
;中断向量表
Reset
LDR PC, ResetAddr
LDR PC, UndefinedAddr
LDR PC, SWI_Addr
LDR PC, PrefetchAddr
LDR PC, DataAbortAddr
DCD 0xb9205f80
LDR PC, [PC, #-0xff0]
LDR PC, FIQ_Addr
ResetAddr DCD ResetInit
UndefinedAddr DCD Undefined
SWI_Addr DCD SoftwareInterrupt
PrefetchAddr DCD PrefetchAbort
DataAbortAddr DCD DataAbort
Nouse DCD 0
IRQ_Addr DCD 0
FIQ_Addr DCD FIQ_Handler
;未定义指令
Undefined
B Undefined
;软中断
SoftwareInterrupt
; B SoftwareInterrupt
;//增加开/关中断处理 Chenxibing-2004-02-09
CMP R0, #4
LDRLO PC, [PC, R0, LSL #2]
MOVS PC, LR
SwiFunction
DCD IRQDisable ;0
DCD IRQEnable ;1
DCD FIQDisable ;2
DCD FIQEnable ;3
IRQDisable
;关IRQ中断
MRS R0, SPSR
ORR R0, R0, #NoInt
MSR SPSR_c, R0
MOVS PC, LR
IRQEnable
;开IRQ中断
MRS R0, SPSR
BIC R0, R0, #NoInt
MSR SPSR_c, R0
MOVS PC, LR
FIQDisable
;关FIQ中断
MRS R0, SPSR
ORR R0, R0, #NoFIQ
MSR SPSR_c, R0
MOVS PC, LR
FIQEnable
;开FIQ中断
MRS R0, SPSR
BIC R0, R0, #NoFIQ
MSR SPSR_c, R0
MOVS PC, LR
;// Changed 2004-12-09
;取指令中止
PrefetchAbort
B PrefetchAbort
;取数据中止
DataAbort
B DataAbort
;快速中断
FIQ_Handler
STMFD SP!, {R0-R3, LR}
BL FIQ_Exception
LDMFD SP!, {R0-R3, LR}
SUBS PC, LR, #4
;** unction name 函数名称: InitStack
;** Descriptions 功能描述: Initialize the stacks 初始化堆栈
;** input parameters 输 入: None 无
;** Returned value 输 出 : None 无
;** Used global variables 全局变量: None 无
;** Calling modules 调用模块: None 无
;** Created by 作 者: Chenmingji 陈明计
;** Created Date 日 期: 2004/02/02 2004年2月2日
;** Modified by 修 改:
;** Modified date 日 期:
InitStack
MOV R0, LR
;Build the SVC stack
;设置管理模式堆栈
MSR CPSR_c, #0xd3
LDR SP, StackSvc
;Build the IRQ stack
;设置中断模式堆栈
MSR CPSR_c, #0xd2
LDR SP, StackIrq
;Build the FIQ stack
;设置快速中断模式堆栈
MSR CPSR_c, #0xd1
LDR SP, StackFiq
;Build the DATAABORT stack
;设置中止模式堆栈
MSR CPSR_c, #0xd7
LDR SP, StackAbt
;Build the UDF stack
;设置未定义模式堆栈
MSR CPSR_c, #0xdb
LDR SP, StackUnd
;Build the SYS stack
;设置系统模式堆栈
MSR CPSR_c, #0xdf
LDR SP, =StackUsr
MOV PC, R0
;** unction name 函数名称: ResetInit
;** Descriptions 功能描述: RESET 复位入口
;** Modified by 修 改: Chenmingji 陈明计
;** Modified date 日 期: 2004/02/02 2004年3月3日
ResetInit
BL InitStack ;初始化堆栈 Initialize the stack
BL SysStation ;目标板基本初始化 Initialize the target board
;跳转到c语言入口 Jump to the entry point of C program
B __main
;** unction name 函数名称: __user_initial_stackheap
;** Descriptions 功能描述: Initial the function library stacks and heaps, CAN not deleted! 库函数初始化堆和栈,不能删除
;** input parameters 输 入: reference by function library 参考库函数手册
;** Returned value 输 出 : reference by function library 参考库函数手册
;** Modified by
;** Modified date
LDR r0,=bottom_of_heap
; LDR r1,=StackUsr
MOV pc,lr
StackSvc DCD SvcStackSpace + (SVC_STACK_LEGTH - 1)* 4
StackIrq DCD IrqStackSpace + (IRQ_STACK_LEGTH - 1)* 4
StackFiq DCD FiqStackSpace + (FIQ_STACK_LEGTH - 1)* 4
StackAbt DCD AbtStackSpace + (ABT_STACK_LEGTH - 1)* 4
StackUnd DCD UndtStackSpace + (UND_STACK_LEGTH - 1)* 4
;** unction name 函数名称: CrpData
;** Descriptions 功能描述: encrypt the chip
;** Created Date 日 期: 2004/03/27 2004年3月27日
IF :DEF: EN_CRP
IF . >= 0x1fc
INFO 1,"\nThe data at 0x000001fc must be 0x87654321.\nPlease delete some source before this line."
ENDIF
CrpData
WHILE . < 0x1fc
NOP
WEND
CrpData1
DCD 0x87654321 ;/*When the Data is 为0x87654321,user code be protected. 当此数为0x87654321时,用户程序被保护 */
ENDIF
;/* 分配堆栈空间 */
AREA MyStacks, DATA, NOINIT, ALIGN=2
SvcStackSpace SPACE SVC_STACK_LEGTH * 4 ;Stack spaces for Administration Mode 管理模式堆栈空间
IrqStackSpace SPACE IRQ_STACK_LEGTH * 4 ;Stack spaces for Interrupt ReQuest Mode 中断模式堆栈空间
FiqStackSpace SPACE FIQ_STACK_LEGTH * 4 ;Stack spaces for Fast Interrupt reQuest Mode 快速中断模式堆栈空间
AbtStackSpace SPACE ABT_STACK_LEGTH * 4 ;Stack spaces for Suspend Mode 中止义模式堆栈空间
UndtStackSpace SPACE UND_STACK_LEGTH * 4 ;Stack spaces for Undefined Mode 未定义模式堆栈
AREA Heap, DATA, NOINIT
bottom_of_heap SPACE 1
AREA Stacks, DATA, NOINIT
StackUsr
END
;** End Of File
我不需要软件中断!
另外我如何修改我的目标板程序?
原文如下:
** graduate school
** File name: target.c
** Descriptions: header file of the specific codes for LPC2100 target boards
** Every project should include a copy of this file, user may modify it as needed
** Version: 1.0
** Version: 1.01
** Descriptions: Renewed the template, added more compiler supports
** Modified by:
** Modified date:
** Version:
** Descriptions:
#define IN_TARGET
#include "LPC2132.h"
#include "config.h"
** Function name: IRQ_Exception
** Descriptions: interrupt exceptional handler , change it as needed
** input parameters: None
** Returned value: None
** Used global variables: None
** Calling modules: None
** Created Date: 2004/02/02
** Modified by:
** Modified date:
void __irq IRQ_Exception(void)
while(1); // change it to your code 这一句替换为自己的代码
** Function name: FIQ_Exception
** Descriptions: Fast interrupt exceptional handler , change it as needed
** Modified by:
** Modified date:
void FIQ_Exception(void)
** Function name: TargetInit
** Descriptions: Initialize the target board; it is called in a necessary place, change it as
** needed
** Modified by:
** Modified date:
void TargetInit(void)
/* 添加自己的代码 */
/* Add your codes here */
** Function name: TargetResetInit
** Descriptions: Initialize the target board before running the main() function; User may
** change it as needed, but may not deleted it.
** Modified by:
** Modified date:
void TargetResetInit(void)
#ifdef __DEBUG_RAM
MEMMAP = 0x2; //remap
#endif
#ifdef __DEBUG_FLASH
MEMMAP = 0x1; //remap
#endif
#ifdef __IN_CHIP
#endif
/* 设置系统各部分时钟 */
/* Set system timers for each component */
PLLCON = 1;
#if (Fpclk / (Fcclk / 4)) == 1
VPBDIV = 0;
#endif
#if (Fpclk / (Fcclk / 4)) == 2
VPBDIV = 2;
#endif
#if (Fpclk / (Fcclk / 4)) == 4
VPBDIV = 1;
#endif
#if (Fcco / Fcclk) == 2
PLLCFG = ((Fcclk / Fosc) - 1) | (0 << 5);
#endif
#if (Fcco / Fcclk) == 4
PLLCFG = ((Fcclk / Fosc) - 1) | (1 << 5);
#endif
#if (Fcco / Fcclk) == 8
PLLCFG = ((Fcclk / Fosc) - 1) | (2 << 5);
#endif
#if (Fcco / Fcclk) == 16
PLLCFG = ((Fcclk / Fosc) - 1) | (3 << 5);
#endif
PLLFEED = 0xaa;
PLLFEED = 0x55;
while((PLLSTAT & (1 << 10)) == 0);
PLLCON = 3;
PLLFEED = 0xaa;
PLLFEED = 0x55;
/* 设置存储器加速模块 */
/* Set memory accelerater module*/
MAMCR = 0;
#if Fcclk < 20000000
MAMTIM = 1;
#else
#if Fcclk < 40000000
MAMTIM = 2;
#else
MAMTIM = 3;
#endif
#endif
MAMCR = 2;
/* 初始化VIC */
/* initialize VIC*/
VICIntEnClr = 0xffffffff;
VICVectAddr = 0;
VICIntSelect = 0;
/* 添加自己的代码 */
** 以下为一些与系统相关的库函数的实现
** 具体作用请ads的参考编译器与库函数手册
** 用户可以根据自己的要求修改
** The implementations for some library functions
** For more details, please refer to the ADS compiler handbook and The library
** function manual
** User could change it as needed
//#include "rt_sys.h"
//#include "stdio.h"
/* Chxb */
#include <rt_sys.h>
#include <stdio.h>
#pragma import(__use_no_semihosting_swi)
int __rt_div0(int a)
a = a;
return 0;
int fputc(int ch,FILE *f)
ch = ch;
f = f;
return 0;
int fgetc(FILE *f)
f = f;
return 0;
int _sys_close(FILEHANDLE fh)
fh = fh;
return 0;
int _sys_write(FILEHANDLE fh, const unsigned char * buf,
unsigned len, int mode)
fh = fh;
buf = buf;
len =len;
mode = mode;
return 0;
int _sys_read(FILEHANDLE fh, unsigned char * buf,
fh = fh;
buf = buf;
len =len;
mode = mode;
return 0;
void _ttywrch(int ch)
ch = ch;
int _sys_istty(FILEHANDLE fh)
fh = fh;
return 0;
int _sys_seek(FILEHANDLE fh, long pos)
fh = fh;
return 0;
int _sys_ensure(FILEHANDLE fh)
fh = fh;
return 0;
long _sys_flen(FILEHANDLE fh)
fh = fh;
return 0;
int _sys_tmpnam(char * name, int sig, unsigned maxlen)
name = name;
sig = sig;
maxlen = maxlen;
return 0;
void _sys_exit(int returncode)
returncode = returncode;
char *_sys_command_string(char * cmd, int len)
cmd = cmd;
len = len;
return 0;
** End Of File
如果我只作一般的MCU来运行怎么修改?
请大家不要见笑,小弟刚学!还希望得到大家的支持! 答 1: 最好直接用Keil,拿来就做MCU用 答 2: 感谢 hotpower你的程序我运行不了!
不知道为什么?
能否告诉我如何设置啊?
答 3: 用周立公的启动一样可以阿 里面有用做MCU,用多UC/OS。。。模板阿。
如果你觉得不会改,对照那里改。 答 4: 哈哈,现在感觉ARM和MCU一样好用,甚至更好~~~没必要照别人的思路去学~~~瞎想才是硬道理~~~ 答 5: 如果用ADS,ZLG书有例程。直接用摸班,不用修改。还是买本书,买个班子吧。很快就上手了。 答 6: 同意hotpower老师的"瞎想"我们真的需要点瞎想精神啊!!!~~~
今天去支持一个客户,当给出解决方案是,他问了我一个问题,让我久久不能平静:我们完全按照芯片手册上的参考电路做的,怎么会错?
... 答 7: terrence被吓倒了把很多人都喜欢来这个“完全”。。。 答 8: 硬件可以完全软件呢? 答 9: re要是只用作一般mcu
keil 环境下觉得好用一些,带上其startup文件就可以了.. 答 10: 好用才是硬道理!
请问:
我如何设置启动?
以及如何做修改以及修改那里?
原文件如下:
;** graduate school
;** Version: 1.0
;** Version: 1.01
;** Version: 1.02
;** Version: 1.04
;** Version: 1.05
;** Descriptions:
;定义堆栈的大小
NoInt EQU 0x80
NoFIQ EQU 0x40
USR32Mode EQU 0x10
SVC32Mode EQU 0x13
SYS32Mode EQU 0x1f
IRQ32Mode EQU 0x12
FIQ32Mode EQU 0x11
;引入的外部标号在这声明
;给外部使用的标号在这声明
EXPORT StackUsr
EXPORT Reset
CODE32
ENTRY
;interrupt vectors
;中断向量表
Reset
LDR PC, ResetAddr
LDR PC, SWI_Addr
DCD 0xb9205f80
LDR PC, FIQ_Addr
Nouse DCD 0
IRQ_Addr DCD 0
;未定义指令
Undefined
B Undefined
;软中断
SoftwareInterrupt
CMP R0, #4
MOVS PC, LR
SwiFunction
DCD IRQDisable ;0
DCD IRQEnable ;1
DCD FIQDisable ;2
DCD FIQEnable ;3
IRQDisable
;关IRQ中断
MRS R0, SPSR
ORR R0, R0, #NoInt
MSR SPSR_c, R0
MOVS PC, LR
IRQEnable
;开IRQ中断
MRS R0, SPSR
BIC R0, R0, #NoInt
MSR SPSR_c, R0
MOVS PC, LR
FIQDisable
;关FIQ中断
MRS R0, SPSR
ORR R0, R0, #NoFIQ
MSR SPSR_c, R0
MOVS PC, LR
FIQEnable
;开FIQ中断
MRS R0, SPSR
BIC R0, R0, #NoFIQ
MSR SPSR_c, R0
MOVS PC, LR
;取指令中止
PrefetchAbort
B PrefetchAbort
;取数据中止
DataAbort
B DataAbort
;快速中断
FIQ_Handler
BL FIQ_Exception
SUBS PC, LR, #4
InitStack
MOV R0, LR
;设置管理模式堆栈
MSR CPSR_c, #0xd3
LDR SP, StackSvc
;设置中断模式堆栈
MSR CPSR_c, #0xd2
LDR SP, StackIrq
;设置快速中断模式堆栈
MSR CPSR_c, #0xd1
LDR SP, StackFiq
;设置中止模式堆栈
MSR CPSR_c, #0xd7
LDR SP, StackAbt
;设置未定义模式堆栈
MSR CPSR_c, #0xdb
LDR SP, StackUnd
;设置系统模式堆栈
MSR CPSR_c, #0xdf
LDR SP, =StackUsr
MOV PC, R0
ResetInit
B __main
;** Modified by
;** Modified date
; LDR r1,=StackUsr
MOV pc,lr
IF :DEF: EN_CRP
IF . >= 0x1fc
ENDIF
CrpData
WHILE . < 0x1fc
NOP
WEND
CrpData1
ENDIF
;/* 分配堆栈空间 */
StackUsr
END
;** End Of File
我不需要软件中断!
另外我如何修改我的目标板程序?
原文如下:
** graduate school
** Version: 1.0
** Version: 1.01
** Modified by:
** Modified date:
** Version:
** Descriptions:
#define IN_TARGET
#include "config.h"
** Modified by:
** Modified date:
** Modified by:
** Modified date:
** needed
** Modified by:
** Modified date:
/* 添加自己的代码 */
** Modified by:
** Modified date:
#ifdef __DEBUG_RAM
#endif
#endif
#ifdef __IN_CHIP
#endif
/* 设置系统各部分时钟 */
PLLCON = 1;
VPBDIV = 0;
#endif
VPBDIV = 2;
#endif
VPBDIV = 1;
#endif
#endif
#endif
#endif
#endif
PLLFEED = 0xaa;
PLLFEED = 0x55;
PLLCON = 3;
PLLFEED = 0xaa;
PLLFEED = 0x55;
/* 设置存储器加速模块 */
MAMCR = 0;
MAMTIM = 1;
#else
MAMTIM = 2;
#else
MAMTIM = 3;
#endif
#endif
MAMCR = 2;
/* 初始化VIC */
/* initialize VIC*/
VICVectAddr = 0;
VICIntSelect = 0;
/* 添加自己的代码 */
** 用户可以根据自己的要求修改
** function manual
/* Chxb */
#include <rt_sys.h>
#include <stdio.h>
a = a;
return 0;
ch = ch;
f = f;
return 0;
int fgetc(FILE *f)
f = f;
return 0;
fh = fh;
return 0;
fh = fh;
buf = buf;
len =len;
mode = mode;
return 0;
fh = fh;
buf = buf;
len =len;
mode = mode;
return 0;
ch = ch;
fh = fh;
return 0;
fh = fh;
return 0;
fh = fh;
return 0;
fh = fh;
return 0;
name = name;
sig = sig;
maxlen = maxlen;
return 0;
cmd = cmd;
len = len;
return 0;
** End Of File
如果我只作一般的MCU来运行怎么修改?
不知道为什么?
能否告诉我如何设置啊?
