ucos2,76,430 ucos2.76到430的问题
出现这样的错误,请问如何?
谢谢!
Error[e16]: Segment DATA16_Z (size: 0xe4e align: 0x1) is too long for segment definition. At least 0x64d more bytes needed. The problem occurred while processing
the segment placement command "-Z(DATA)DATA16_I,DATA16_Z,DATA16_N,HEAP+_HEAP_SIZE=0200-0A00", where at the moment of placement the available
memory ranges were "CODE:200-a00"
Reserved ranges relevant to this placement:
CODE:200-a00 DATA16_I
Total number of errors: 1
Total number of warnings: 2 答 1: 你的0初始化数据都将近4K了,你用的芯片内存是多少呢?2k肯定不行了 答 2: 谢谢帮助
1、请问在哪里看到的初始化数据的?我查过源代码里没有 DATA16_Z这个东西啊
2、我做的是ucos2。76的,一直遇到这个,请问可以帮忙?
谢谢 答 3: 还有我移植了2.56没有什么问题,内核2k,ram 900B,2.76就不行,始终出上面的提示不知道是什么原因 答 4: hehe
终于搞定了 答 5: 编译后为
3 112 bytes of CODE memory
1 136 bytes of DATA memory (+ 3 absolute )
380 bytes of CONST memory
Total number of errors: 0
Total number of warnings: 0 答 6: 您好。我也是遇到同样的问题。你可以告诉我你是怎么解决的吗?
我的邮箱是:liuzexi2002126.com
谢谢!
终于搞定了 答 5: 编译后为
