ucos 请求帮助,简单的ucos但是无法实现???
想实现KEY1按键控制LED1闪烁,但是结果却KEY1不起作用,运行后LED1亮,按复位键LED1会闪烁。代码如下,还望各位帮忙,谢谢!
#include "Config.h"
#include "Target.h"
#define KEY1 (1<<16)
#define LED1 (1<<22)
#define OSStkLen 64
OS_STK task0Stk[OSStkLen];
OS_STK task1Stk[OSStkLen];
void task0(void *pdata);
void task1(void *pdata);
int main(void)
IO0DIR = LED1;
PINSEL0 =0x00000000;
OSInit();
OSTaskCreate(task0,(void *)0,&task0Stk[OSStkLen-1],4);
OSTaskCreate(task1,(void *)0,&task1Stk[OSStkLen-1],5);
OSStart();
return 0;
pdata=pdata;
TargetInit ();
for(;;)
OSTaskSuspend(OS_PRIO_SELF);
IO0CLR = LED1;
OSTimeDly(OS_TICKS_PER_SEC / 8);
IO0SET = LED1;
OSTimeDly(OS_TICKS_PER_SEC / 4);
IO0CLR = LED1;
IO0SET = LED1;
pdata = pdata;
for(;;)
OSTimeDly(OS_TICKS_PER_SEC / 50);
if((IO0PIN & KEY1) != 0)
continue;
continue;
OSTaskResume(4);
while((IO0PIN & KEY1) == 0)
} 答 1: 建议你先测试一下你的IO操作是否正确
#include "Config.h"
#include "Target.h"
#define OSStkLen 64
int main(void)
IO0DIR = LED1;
OSInit();
OSStart();
return 0;
pdata=pdata;
TargetInit ();
for(;;)
IO0CLR = LED1;
IO0SET = LED1;
IO0CLR = LED1;
IO0SET = LED1;
pdata = pdata;
for(;;)
continue;
continue;
OSTaskResume(4);
