430,PWM 请问用430能否产生PWM波形?
请问各位老师MSP43O系列的单片机有带PWM输出模块的吗?如果没有的话,怎么才能输出12位的PWM波形?谢谢各位
答 1:
当然可以产生PWM波,你可以用timeA输出功能产生。
答 2:
请问能给在下一个例子程序吗?
答 3:
可以到TI网站或利尔达网站找!
答 4:
// MSP-FET430P140 Demo - Timer_a PWM TA1-2 upmode, DCO SMCLK
// Description; This program will generate a two PWM outputs on P1.2/1.3 using
// Timer_A in an upmode. The value in CCR0, defines the period and the
// values in CCR1 and CCR2 the duty PWM cycles. Using ~ 800kHz SMCLK as TACLK,
// the timer period is ~ 640us with a 75% duty cycle on P1.2 and 25% on P1.3.
// ACLK = na, SMCLK = MCLK = TACLK = default DCO ~ 800kHz.
// MSP430F149
// /|\| XIN|-
// --|RST XOUT|-
// | P1.2|--> CCR1 - 75% PWM
// | P1.3|--> CCR2 - 25% PWM
// M.Buccini
// Texas Instruments, Inc
// September 2003
// Built with IAR Embedded Workbench Version: 1.26B
// January 2004
// Updated for IAR Embedded Workbench Version: 2.21B
#include <msp430x14x.h>
void main(void)
WDTCTL = WDTPW + WDTHOLD; // Stop WDT
P1DIR |= 0x0C; // P1.2 and P1.3 output
P1SEL |= 0x0C; // P1.2 and P1.3 TA1/2 otions
CCR0 = 512-1; // PWM Period
CCTL1 = OUTMOD_7; // CCR1 reset/set
CCR1 = 384; // CCR1 PWM duty cycle
CCTL2 = OUTMOD_7; // CCR2 reset/set
CCR2 = 128; // CCR2 PWM duty cycle
TACTL = TASSEL_2 + MC_1; // SMCLK, up mode
_BIS_SR(LPM0_bits); // Enter LPM0
} 答 5: 谢谢了 答 6: 在MSP编译器中有示例程序。
// MSP430F149
// /|\| XIN|-
// --|RST XOUT|-
// M.Buccini
// September 2003
// January 2004
void main(void)
