FLASH 【原创】FLASH操作函数
int flash_block_erase( int block_num)
int i;
unsigned char *p;
if( block_num==0) return FLASH_BLOCKNUM_ERR;
if( block_num<MAX_BLOCK)
_DINT();
WDTCTL = WDTPW + WDTHOLD;
FCTL3=FWKEY;
while( FCTL3 & BUSY)
i++;
if (i>30000)
FCTL3=FWKEY+LOCK;
return FLASH_WRITE_ERR;
// FCTL2=FWKEY+SSEL1+FN2;
FCTL1=FWKEY+ERASE;
while ( FCTL3 & WAIT)
i++;
if (i>30000)
FCTL3=FWKEY+LOCK;
p=(unsigned char * ) (0xff00-block_num*512);
*p=0x0ff;
i++;
if (i>30000)
FCTL3=FWKEY+LOCK;
_EINT();
return 0;
if (block_num==120)
_DINT();
FCTL3=FWKEY;
while ( FCTL3 & BUSY)
i++;
if (i>30000)
FCTL3=FWKEY+LOCK;
FCTL1=FWKEY+ERASE;
i++;
if (i>30000)
FCTL3=FWKEY+LOCK;
p=(unsigned char * ) 0x1080;
*p=0x0ff;
i++;
if (i>30000)
FCTL3=FWKEY+LOCK;
_EINT();
return 0;
if (block_num==121)
_DINT();
FCTL3=FWKEY;
i++;
if (i>30000)
FCTL3=FWKEY+LOCK;
FCTL1=FWKEY+ERASE;
i++;
if (i>30000)
FCTL3=FWKEY+LOCK;
p=(unsigned char * ) 0x1000;
*p=0x0ff;
i++;
if (i>30000)
FCTL3=FWKEY+LOCK;
_EINT();
return 0;
int flash_char_write (char *buf ,char content)
int i;
_DINT();
FCTL3=FWKEY;
i++;
if (i>30000)
{ FCTL3=FWKEY+LOCK;
FCTL1=FWKEY+WRT;
i++;
if (i>30000)
{ FCTL3=FWKEY+LOCK;
*buf =content;
i++;
if (i>30000)
{ FCTL3=FWKEY+LOCK;
FCTL1=FWKEY;
FCTL3=FWKEY+LOCK;
_EINT();
return 0;
int flash_block_write( unsigned char *dest ,unsigned char *source ,int buf_size)
unsigned char content;
int err_no;
while ( buf_size--)
content= *source;
err_no=flash_char_write( dest,content);
if (err_no!=0) return err_no;
source++;
dest++;
return 0;
} 答 1: 最好能加上注释,要不然看得头大。 答 2: 是啊,同意楼上的见解,给我们加点关键注释吧 答 3: 函数名字那么明白,就不要注释了吧 答 4: 好像缺了头文件 答 5: 加点注释!锻炼一下文采嘛! 答 6: void erase_seg(unsigned char segment) //擦除某一段的子程序,可以单独使用
unsigned int *flash_ptr;
_DINT(); //关闭中断
FCTL2 = FWKEY+FSSEL0+FN0; //选择FLASH的擦写时钟
switch(segment)
case 'A':flash_ptr=(unsigned int *)0x1000;break;//information segment A
case 'B':flash_ptr=(unsigned int *)0x1080;break;//information segment B
case 1:flash_ptr=(unsigned int *)0xFC00;break;//main segment 1
case 2:flash_ptr=(unsigned int *)0xFA00;break;//main segment 2
case 3:flash_ptr=(unsigned int *)0xF800; //main segment 3
default:break;
FCTL1=FWKEY+ERASE; //使能擦除操作
FCTL3=FWKEY; //FLASH解锁
*flash_ptr=0; //空写,启动擦除
FCTL1=FWKEY; //关闭擦除操作
FCTL3=FWKEY+LOCK; //FLASH锁定
_EINT(); //打开中断
int i;
unsigned char *p;
_DINT();
FCTL3=FWKEY;
i++;
if (i>30000)
FCTL3=FWKEY+LOCK;
FCTL1=FWKEY+ERASE;
i++;
if (i>30000)
FCTL3=FWKEY+LOCK;
*p=0x0ff;
i++;
if (i>30000)
FCTL3=FWKEY+LOCK;
_EINT();
return 0;
if (block_num==120)
_DINT();
FCTL3=FWKEY;
i++;
if (i>30000)
FCTL3=FWKEY+LOCK;
FCTL1=FWKEY+ERASE;
i++;
if (i>30000)
FCTL3=FWKEY+LOCK;
*p=0x0ff;
i++;
if (i>30000)
FCTL3=FWKEY+LOCK;
_EINT();
return 0;
if (block_num==121)
_DINT();
FCTL3=FWKEY;
i++;
if (i>30000)
FCTL3=FWKEY+LOCK;
FCTL1=FWKEY+ERASE;
i++;
if (i>30000)
FCTL3=FWKEY+LOCK;
*p=0x0ff;
i++;
if (i>30000)
FCTL3=FWKEY+LOCK;
_EINT();
return 0;
int i;
_DINT();
FCTL3=FWKEY;
i++;
if (i>30000)
{ FCTL3=FWKEY+LOCK;
FCTL1=FWKEY+WRT;
i++;
if (i>30000)
{ FCTL3=FWKEY+LOCK;
*buf =content;
i++;
if (i>30000)
{ FCTL3=FWKEY+LOCK;
FCTL1=FWKEY;
FCTL3=FWKEY+LOCK;
_EINT();
return 0;
int err_no;
while ( buf_size--)
content= *source;
source++;
dest++;
return 0;
_DINT(); //关闭中断
switch(segment)
default:break;
_EINT(); //打开中断
| 为遥控小车巧添功能被打赏¥26元 | |
