MSP,TS430PZ100,rev 在哪里下载MSP-TS430PZ100 rev:1.2的原理图?
买仿真器时配套的评估板的原理图哪里下啊?
板的编号:
找了www.ti.com没有,在IAR的
EW430_user_guide.pdf 里P189有提及:
HARDWARE INSTALLATION, MSP-FET430PXX0
('P120, 'P140, 'P410, 'P440)
1 Use the 25-conductor cable to connect the FET Interface module to the parallel port of
your PC.
2 Use the 14-conductor cable to connect the FET Interface module to the Target Socket
module.
3 Ensure that the MSP430 device is securely seated in the socket, and that its pin 1
(indicated with a circular indentation on the top surface) aligns with the 1 mark on the
PCB.
4 Ensure that the two jumpers (LED and Vcc) near the 2x7 pin male connector are in
place.
谢谢!:confused: 答 1: 找到了,谢谢!
在MSP430-FET user guide.pdf
板的编号:
your PC.
module.
PCB.
place.
硬核工程师专属补给计划——填盲盒 | |
“我踩过的那些坑”主题活动——第002期 | |
【EEPW电子工程师创研计划】技术变现通道已开启~ | |
【EEPW在线】E起听工程师的声音! | |
高校联络员开始招募啦!有惊喜!! | |
送您一块开发板,2025年“我要开发板活动”又开始了! |
